    Fan0/1 pegged together
    848
    • tblake84undefined
      tblake84 @PaulHew
      @PaulHew I am using Simplify3D for my slicer and I don't see where I can specify the fan designator but here is my full config.g:
      ; generated by RepRapFirmware Configuration Tool v2.0.3 on Thu Sep 05 2019 15:07:13 GMT-0400 (Eastern Daylight Time)
      G90                                                ; send absolute coordinates...
      M83                                                ; ...but relative extruder moves
      M550 P"Sidewinder X1"                              ; set printer name
      M552 S1                                            ; enable network
      M586 P0 S1                                         ; enable HTTP
      M586 P1 S1                                         ; enable FTP
      M586 P2 S1                                         ; enable Telnet
      M569 P0 S0 D3 V100                                 ; drive 0 (X) goes forwards
      M569 P1 S0 D3 V100                                 ; drive 1 (Y) goes forwards
      M569 P2 S1 D3 V100                                 ; drive 2 (Z) goes forwards
      M569 P3 S0 D3 V100                                 ; drive 3 (E0) goes forwards
      M584 X0 Y1 Z2 E3                                   ; set drive mapping
      ;;;M350 X16 Y16 Z16 E16 I1                            ; configure microstepping with interpolation
      M92 X80.12 Y80.12 Z399.78 E478.49                  ; set steps per mm (for 1/16 microstepping)
      M350 X128 Y128 Z128 E128 I0                        ; configure microstepping without interpolation
      M566 X800 Y800 Z50 E500                            ; set maximum instantaneous speed changes (mm/min)
      M203 X8000 Y8000 Z1000 E1200                       ; set maximum speeds (mm/min)
      M201 X500 Y500 Z20 E250                            ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800 I15                       ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                            ; Set idle timeout
      M208 X0:300 Y0:300 Z0:400                          ; set axis min:max
      M574 X1 Y1 S0                                      ; set active high endstops
      M307 H7 A-1 C-1 D-1                                ; disable heater 7 on PWM channel for BLTouch
      ; BLTouch Configuration
      M574 Z1 S2                                         ; set endstops controlled by probe
      M558 P9 H5 F120 T6000                              ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X30 Y-30 Z2.504                           ; set Z probe trigger value, offset and trigger height
      M557 X30:270 Y30:270 S25                           ; define mesh grid
      M305 P0 T100000 B4138 R4700                        ; set thermistor + ADC parameters for heater 0
      M143 H0 S120                                       ; set temperature limit for heater 0 to 120C
      M305 P1 T100000 B4138 R4700                        ; set thermistor + ADC parameters for heater 1
      M143 H1 S275                                       ; set temperature limit for heater 1 to 275C
      M106 P0 C"PartFan" S0.0 B0.1 I0 F500 H-1           ; set fan 1 (part cooling fan) value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 C"Hotend" S1.0 I0 F500 H1 T45              ; set fan 0 (hotend fan) value, PWM signal inversion and frequency. Thermostatic control is turned on monitoring heater one (hotend)
      M563 P0 S"Tool0" D0 H1 F-1                         ; define T0
      M572 D0 S0.05                                      ; enable pressure advance on T0
      G10 P0 X0 Y0 Z0                                    ; set T0 axis offsets
      G10 P0 R0 S0                                       ; set initial T0 active and standby temperatures to 0C
      ; Filament Runout Sensor
      M591 D0 P1 C3 S1                                   ; filament runout sensor for E0 connected to E0 endstop
      M501                                               ; load saved parameters from non-volatile memory
      T0                                                 ; select first tool
        Phaedrux Moderator @tblake84
        @tblake84 said in Fan0/1 pegged together:
        This should have F0 not F-1
        tblake84undefined 1 Reply Last reply Reply Quote 0
        • tblake84undefined
          tblake84 @Phaedrux
          @Phaedrux Thanks, I will try that in a bit. I think that was originally set when I went through the RepRap configuration tool so maybe I set something wrong there.
            Interesting. Could you post the config.json file that you got from the configurator?
            • tblake84undefined
              tblake84 @Phaedrux
              @Phaedrux Here you go (json is not a valid format for upload).
              {"board":"duetwifi10","firmware":2.03,"nvram":true,"auto_save":{"enabled":true,"save_threshold":10,"resume_threshold":11,"gcodes_to_run":"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"},"display":{"type":0,"encoder_steps":4,"spi_frequency":2000000,"menus":[{"name":"main","value":""}],"images":[]},"geometry":{"type":"cartesian","mins":[0,0,0],"maxes":[300,300,400],"delta_radius":105.6,"homed_height":250,"low_dive_height":false,"max_carriage_travel":260,"print_radius":85,"rod_length":215,"z_min":0},"drives":[{"direction":1,"microstepping":16,"microstepping_interpolation":true,"steps_per_mm":80,"instant_dv":15,"max_speed":100,"acceleration":500,"current":800,"driver":0,"endstop_type":1,"endstop_location":1},{"direction":1,"microstepping":16,"microstepping_interpolation":true,"steps_per_mm":80,"instant_dv":15,"max_speed":100,"acceleration":500,"current":800,"driver":1,"endstop_type":1,"endstop_location":1},{"direction":1,"microstepping":16,"microstepping_interpolation":true,"steps_per_mm":4000,"instant_dv":0.2,"max_speed":3,"acceleration":20,"current":800,"driver":2,"endstop_type":3,"endstop_location":1},{"direction":0,"microstepping":16,"microstepping_interpolation":true,"steps_per_mm":420,"instant_dv":2,"max_speed":20,"acceleration":250,"current":800,"driver":3}],"idle":{"used":true,"factor":30,"timeout":30},"homing_speed_fast":30,"homing_speed_slow":6,"travel_speed":100,"z_dive_height":5,"slow_homing":false,"probe":{"type":"bltouch","recovery_time":0.4,"trigger_height":2.5,"trigger_value":500,"x_offset":0,"y_offset":0,"speed":2,"deploy":false,"points":[{"x":0,"y":84.9,"z":0},{"x":73.53,"y":-42.45,"z":0},{"x":-73.53,"y":-42.45,"z":0},{"x":0,"y":0,"z":0}],"pwm_channel":7,"pwm_inverted":true},"bed_is_nozzle":false,"bed":{"present":true,"heater":0,"use_pid":false},"chamber":{"present":false,"heater":2,"use_pid":false},"heaters":[{"temp_limit":120,"scale_factor":100,"series":4700,"thermistor":100000,"beta":4138,"a":0.0005717725,"b":0.0002416626,"c":0,"channel":0},{"temp_limit":250,"scale_factor":100,"series":4700,"thermistor":100000,"beta":4138,"a":0.0005717725,"b":0.0002416626,"c":0,"channel":1}],"num_nozzles":1,"toolchange_wait_for_temperatures":true,"generate_t_code":true,"tools":[{"mix_ratio":[],"number":0,"name":"Tool0","extruders":[0],"heaters":[1],"fans":[],"x_offset":0,"y_offset":0,"z_offset":0}],"compensation_x_offset":15,"compensation_y_offset":15,"peripheral_points":3,"halfway_points":0,"calibration_factors":3,"probe_radius":85,"mesh":{"x_min":15,"x_max":215,"y_min":15,"y_max":195,"radius":85,"spacing":20},"home_first":false,"orthogonal":{"compensation":false,"height":50,"deviations":[0,0,0]},"network":{"enabled":true,"mac_address":"","name":"Sidewinder X1","password":"","ssid":"","ssid_password":"","dhcp":true,"ip":"192.168.1.20","netmask":"255.255.255.0","gateway":"192.168.1.254","protocols":{"http":true,"ftp":true,"telnet":true}},"fans":[{"name":"","value":100,"inverted":false,"frequency":500,"thermostatic":true,"heaters":[1],"trigger_temperature":45},{"name":"","value":0,"inverted":false,"frequency":500,"thermostatic":false,"heaters":[1],"trigger_temperature":45}],"custom_settings":""}
                T3P3Tony administrators @tblake84
                added it now
                • tblake84undefined
                  tblake84 @T3P3Tony
                  @T3P3Tony Thanks!
                  @Phaedrux Here is the file for easier searching.
                  config.json
                    It looks like no fan was selected for the tool. By default it does select Fan0. So maybe a misclick?
                    tblake84undefined 2 Replies Last reply Reply Quote 0
                    • tblake84undefined
                      tblake84 @Phaedrux
                      @Phaedrux Yeah, that's what I'm thinking. I have a print about to wrap up now so will test shortly.
                      • tblake84undefined
                        tblake84 @Phaedrux
                        @Phaedrux No dice on that fix.
                        Here is the relevant sections of my config.g:
                        M106 P0 C"PartFan" H-1                             ; set fan 0 (part cooling fan) value, PWM signal inversion and frequency. Thermostatic control is turned off
                        M106 P1 C"Hotend" S1.0 I0 F500 H1 T45              ; set fan 1 (hotend fan) value, PWM signal inversion and frequency. Thermostatic control is turned on monitoring heater one (hotend)
                        M563 P0 S"Tool0" D0 H1 F0                          ; define T0
                        I am still getting pegged F0 and F1; whatever I do to one fan (turn up/down/on/off) happens to the other un-commanded. However, they are now turning on correctly as expected but both seem to be respecting the latest fan command. When I start a print and the hotend warms to 45C, they both come on full blast (as F1 is commanded to do). Then, when my gcode commands the part cooling fan (F0) to come on 50% at layer three, they both throttle back to 50%. It's bizarre.
                          Just checking my own config to compare with and the M106 commands are pretty similar and my tool command doesn't even specify a fan since F0 is the default anyway.
                          They aren't actually wired together are they? 👅
                          • tblake84undefined
                            tblake84 @Phaedrux
                            @Phaedrux That's a valid question but no.... at least I don't think so. I am using an Artillery Sidewinder X1 which is famous for its use of ribbon cables in the wiring harness so it does have a bunch of breakout boards to convert the ribbon cables to the necessary XH2.5mm connectors. I didn't have this kind of issue with the original MKS board so I don't think there is any trace on the breakout board connecting the two but I will have to take a closer look.
                            In either event, the DWC does indicate that both fan controls move in sync; moving the slider for one fan moves the other to the same setting so my instinct says this is related to the Duet board/firmware.
                            Phaedruxundefined ZTrekundefined 2 Replies Last reply Reply Quote 0
                              So do PartFan and Hotend both show up with their own slider?
                              Try this:
                              Send M98 Pconfig.g in the gcode console. That will execute the config.g and any error messages should get echoed to the console.
                              Next try sending M106 P0 C"PartFan" H-1 and M106 P1 C"Hotend" S1.0 I0 F500 H1 T45 separately in the gcode console and testing the fans.
                              • tblake84undefined
                                tblake84 @Phaedrux
                                @Phaedrux I did that and I get no errors but I still have the issue.
                                One interesting thing to note is that only P0 has the correct name. P1 should be labeled 'Hotend' but instead it shows up in DWC as 'Tool Fan'.
                                  The Tool fan slider and the Part fan slider are the same thing.
                                  The tool fan slider is it's own separate thing because on machines with multiple tools each tool may have it's own fan, so that slider controls the fan of the currently selected tool.
                                  In your case with a single tool the PartFan slider and the Tool Fan slider are both controlling the same fan.
                                  Hotend won't show up as a slider because it is thermostatically controlled.
                                  If you heat the hotend up to 50c does the hotend fan turn on?
                                  • tblake84undefined
                                    tblake84 @Phaedrux
                                    @Phaedrux So I actually just reflashed the FW and it all behaves (somewhat) normally now but what you said certainly makes sense. Nevertheless, there must have been something wrong in the FW build I initially loaded onto it.
                                    I removed the fan names from my config.g and now I just have 'Tool Fan' and 'Fan0'. The tool fan slider does nothing and Fan0 operates the part cooling fan. If I heat the hotend up to 50c, the heatsink fan (tool fan?) kicks on/off as expected. Is there a way to get rid of 'Tool Fan' in DWC since I only have one hotend and it doesn't control anything?
                                      No you can't remove the tool fan slider.
                                      • ZTrekundefined
                                        ZTrek @tblake84
                                        @tblake84 In the SWX1 the 2 fans and the extruder all share the same wires.
