    RepRapFirmware 3.0 first official beta is out
    Beta Firmware
    15
    132
    9.4k
      dc42 administrators @gtj0
      @gtj0 said in RepRapFirmware 3.0 first official beta is out:
      Yeah I still have the issue with the Z height changing when homing XY when a heightmap is in effect.
      On my list to investigate, but may have to wait until after TCT.
      • gtj0undefined
        gtj0 @dc42
        @dc42 said in RepRapFirmware 3.0 first official beta is out:
        No problem. I'll nose around a bit this weekend.
        • kraegarundefined
          kraegar
          Odd one. Heater faulted halfway through a print. Print kept going, but shows 100% for a status (can't cancel it anymore). Obviously not extruding, just still moving. DWC went unresponsive on me, too. Really odd.
          No idea why the heater faulted yet.
          • wilrikerundefined
            wilriker @kraegar
            @kraegar This means this issue has not been fixed, yet. 😞
            EDIT: which version of DSF are you using? That might make my above assumption incorrect.
            Manuel
            My Tool Collection
            • Marco Bonaundefined
              Marco Bona
              With this build I encounter problems with heater mapping. The values ​​found are -273 with the exception of the heated chamber which is correct.
              ; 9 _ HEATERS
              M308 S0 P"bed_temp" Y"thermistor" A"Bed thermistor" T100000 B3950
              M308 S1 P"spi.cs1" Y"rtd-max31865" P"spi.cs1" A"RTD1"
              M308 S2 P"spi.cs2" Y"rtd-max31865" A"RTD2"
              M308 S3 P"e2_temp" Y"thermistor" A"Chamber thermistor" T100000 B4725 C7.06e-8
              M950 H0 C"bed_heat" T0
              M950 H1 C"e0_heat" T1
              M950 H2 C"e1_heat" T2
              M950 H3 C"duex.e2heat" T3
              T3P3Tonyundefined smoki3undefined 2 Replies Last reply Reply Quote 0
                T3P3Tony administrators @Marco Bona
                @Marco-Bona said in RepRapFirmware 3.0 first official beta is out:
                are you definitely using .cs1 and .cs2 not .cs0 and .cs1 (i.e you have one daughter board) also remove the second P value
                  @kraegar I recommend using DSF 1.0.3.3
                  Marco Bonaundefined kraegarundefined 2 Replies Last reply Reply Quote 0
                    Marco Bona @T3P3Tony
                    @t3p3tony
                    Sorry but the second P value was a bonding problem.
                    For DSF I realized that it was only for Duet3, I'm using Duet2. If it is to be installed where can I find the file?
                      @Marco-Bona No you are right DSF is only Duet 3
                      • kraegarundefined
                        kraegar @T3P3Tony
                        @T3P3Tony Thanks - I wasn't pointing to the unstable repo. Also, easy fix, but might trip up someone not linux savvy, you're missing a sudo on the apt-get install line of the instructions.
                        • kraegarundefined
                          kraegar
                          Failed again, at 14.50mm of an 80mm print. Reports it's 100% but definitely is not.
                          • kraegarundefined
                            kraegar
                            I'd only used systemctl to restart all the duet processes. Trying a print from a known reliable slice from my duet2, with a fresh boot on the latest software on the unstable branch.
                              @kraegar Please can you check the firmware viserion uning M115 and the versions on DSF you have through this command on the Rpi:
                              apt list 2>/dev/null | grep duet | awk -F'[/ ]' '{print $1" "$3 }'
                              (thanks @wilriker for the awk foo)
                              • kraegarundefined
                                kraegar
                                @T3P3Tony said in RepRapFirmware 3.0 first official beta is out:
                                FIRMWARE_NAME: RepRapFirmware for Duet 3 v0.5 FIRMWARE_VERSION: 3.0beta10 ELECTRONICS: Duet 3 prototype v0.5 FIRMWARE_DATE: 2019-09-12b1
                                duetcontrolserver 1.0.3.3
                                duetruntime 1.0.3.3
                                duetsd 1.0.2
                                duetsoftwareframework 1.0.3.3
                                duettools 1.0.3.3
                                duetwebcontrol 2.0.0-4
                                duetwebserver 1.1.0.0
                                • wilrikerundefined
                                  wilriker @T3P3Tony
                                  @bearer is the one to deserve credits for the awk-foo. I try to avoid awk where I can. 😁
                                  Manuel
                                  My Tool Collection
                                  A Former User? T3P3Tonyundefined 2 Replies Last reply Reply Quote 1
                                    A Former User @wilriker
                                    @wilriker said in RepRapFirmware 3.0 first official beta is out:
                                    you mean you don't want the blame? ... awkward! πŸ˜‚
                                    • kraegarundefined
                                      kraegar
                                      awk is great. Learn to love it πŸ™‚
                                      I meant to kick off a ~4 hour print. Grabbed the slice and didn't check it, closer to a ~14 hour print. I'm a bit over 2 hours into it. So, this should be a good test of the duet3 after a fresh startup, so far so good.
                                        T3P3Tony administrators @wilriker
                                        @wilriker , cheers sorry @bearer πŸ˜„
                                        • kraegarundefined
                                          kraegar
                                          Guess it's good I used the 14 hour slice, it froze about 12 hours in. It started to occasionally pause (could hear the stepper go still for a second or two), then it totally stopped moving and shut off the heaters. Wish I hadn't used my good filament, though!
                                          https://i.imgur.com/IuEyyvB.jpg?1
                                          • Dougal1957undefined
                                            Dougal1957
                                            OK Managed to get the Duet3 powered up and connected to the PI4 using the supplied image DWC came up on the Pi Monitor. so far so good. But how do I connect to it from elsewhere on my network I have tried to SSH in but don't have the Password for it and VNC doesn't want to connect either. I am guessing I need to set this up on the PI but being a total newby with Linux I could do with some pointers if someone could be so kind.
                                            Doug
