    3DP1000 Duet Ethernet Conversion
    42
    2.8k
      A Former User @Cherno Alpha
      @cherno-alpha said in 3DP1000 Duet Ethernet Conversion:
      @bearer Is this like the Power Resume Feature?
      yeah. but the online config tool has a bug and renders the config useless if you enable the power loss / resume function. but if you don't plan on using that then go forth and configure without worries:) with one less worry:)
      Cherno Alphaundefined droftartsundefined 3 Replies Last reply Reply Quote 0
      • Cherno Alphaundefined
        Cherno Alpha @A Former User
        @bearer There will be plenty of worrying when configuring it. Never really done this type of thing before, but I have figured out most of the other things with printers. I am an expert on repairing my Raise3d machines 😄
        Ultimaker 2, Raise3d N2 Plus, 3DP1000, Creaform Go!Scan 50, Creaform Handyscan700
          droftarts administrators @A Former User
          @bearer The Configurator code has been fixed on Github (and network has been put back at the beginning of config.g, so at least people should be able to connect to DWC), just waiting for the online configurator to be updated.
            @bearer Actually, it's already been updated and M911 in config.g has double quotes around it, but you have to clear cache to make your browser use the latest version. From Christian:
            Check for version 2.0.1
            Can be seen on the start page. If it displays v2.0.0, clear your browser cache
            And my mistake, the network code hasn't been moved back to the beginning yet.
              Cherno Alpha
              The Duet has arrived, I am looking at a piezo bed levelling system for this, is it fiddly to set up and is it reliable? Alternatively what is the most user friendly bed levelling system? The bed is glass.
                Phaedrux Moderator @Cherno Alpha
                @Cherno-Alpha said in 3DP1000 Duet Ethernet Conversion:
                Therein lies the rub. They're all pretty picky in some way or another. Pick your poison.
                https://duet3d.dozuki.com/Wiki/Choosing_a_Z_probe
                  Cherno Alpha @nhof
                  @nhof Just looked at the expansion board and I need to get one, problem is the Australian reps dont have any at all so will have to get them from overseas. Yay for freight charges.
                    Cherno Alpha
                    Ok, so I have installed the duet ethernet, and the expansion board to go with it.
                    The problem that I am encountering at the moment is with the Z axis.
                    X and Y home and operate perfectly.
                    Z is the issue.
                    We have been able to get Z to home. Once home, if you press + 5mm it does not operate. If I go - 5mm it tries to drive the hotend through the printer.
                    The Z dive height has been set to 0.
                    To continue testing we have to manually wind the Z axis to try something new.
                    Any suggestions to try would be great.
                    Thanks,
                    Brad
                    • Dougal1957undefined
                      Dougal1957
                      try posting your config.g and homing files then we can all have a look and see if there is anything obvious.
                        Why would you set it to 0?
                        Have you seen this? https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCartesianPrinter#Section_Homing_Z
                        We'd need to see your config and homing files.
                          Cherno Alpha
                          @Dougal1957 , @Phaedrux
                          Will post the data below,
                          We set it to 0 after the first time we were setting the other axes it tried to drive it down. It is only at 0 till we have it sorted.
                            Cherno Alpha
                            Z HOME
                            ; homez.g
                            ; called to home the Z axis
                            ; generated by RepRapFirmware Configuration Tool v2.0.4 on Tue Sep 17 2019 17:44:51 GMT+1000 (Australian Eastern Standard Time)
                            G91 ; relative positioning
                            G1 Z0 F6000 S2 ; lift Z relative to current position
                            G1 S1 Z-505 F3600 ; move Z down until the endstop is triggered
                            G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
                            ;G91 ; relative positioning
                            ;G1 S2 Z0 F100 ; lift Z relative to current position
                            ;G90 ; absolute positioning
                              Cherno Alpha
                              CONFIG FILE
                              ; generated by RepRapFirmware Configuration Tool v2.0.4 on Tue Sep 17 2019 17:44:50 GMT+1000 (Australian Eastern Standard Time)
                              M550 P"3DP Duet" ; set printer name
                              M552 P192.168.1.14 S1 ; enable network and set IP address
                              M553 P255.255.255.0 ; set netmask
                              M554 P192.168.1.1 ; set gateway
                              M586 P0 S1 ; enable HTTP
                              M586 P1 S0 ; disable FTP
                              M586 P2 S0 ; disable Telnet
                              M569 P5 S1 ; physical drive 5 goes forwards
                              M569 P6 S0 ; physical drive 6 goes backwards
                              M569 P7 S1 ; physical drive 7 goes forwards
                              M569 P4 S1 ; physical drive 4 goes forwards
                              M584 X5 Y6 Z7 E3:4 ; set drive mapping
                              M92 X128.00 Y128.00 Z1600.00 E420.00:420.00 ; set steps per mm
                              M566 X900.00 Y900.00 Z12.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
                              M203 X6000.00 Y6000.00 Z60.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
                              M201 X500.00 Y500.00 Z5.00 E250.00:250.00 ; set accelerations (mm/s^2)
                              M906 X800 Y800 Z800 E800:800 I30 ; set motor currents (mA) and motor idle factor in per cent
                              M84 S30 ; Set idle timeout
                              M208 X1000 Y1000 Z500 S0 ; set axis maxima
                              M574 X1 Y1 Z1 S0 ; set active low and disabled endstops
                              M558 P0 H0 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
                              M557 X100:800 Y100:800 S200 ; define mesh grid
                              M143 H0 S140 ; set temperature limit for heater 0 to 140C
                              M305 P2 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 2
                              M143 H2 S280 ; set temperature limit for heater 2 to 280C
                              M106 P0 S1 I0 F500 H1 T45 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
                              M106 P1 S1 I0 F500 H2 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                              M563 P1 D1 H2 F0 ; define tool 1
                                Cherno Alpha
                                HOME X
                                This Axis is functioning correctly, so I thought I would also post this as well just to provide further information.
                                ; homex.g
                                ; called to home the X axis
                                G1 S1 X-1005 F3600 ; move quickly to X axis endstop and stop there (first pass)
                                G1 X5 F6000 ; go back a few mm
                                G1 S1 X-1005 F300 ; move slowly to X axis endstop once more (second pass)
                                G1 Z0 F6000 S2 ; lower Z again
                                • nhofundefined
                                  nhof
                                  Does Z axis travel correctly normally?
                                  Note that the motors probably have a minimum pulse width of 3us, so you may have to guarantee this in order for the motors to run properly at higher step rates.
                                  Something like:
                                  M569 P5 S1 T3
                                  M569 P6 S1 T3
                                  M569 P6 S1 T3
                                  Depending on what machine you have the motors will either be these: https://www.applied-motion.com/sites/default/files/hardware-manuals/STM23R Hardware Manual 920-0056D.pdf
                                  or these: https://www.applied-motion.com/sites/default/files/hardware-manuals/TSM23P-Hardware Manual_920-0083B.pdf
                                  Just look at the connectors.
                                  Cherno Alphaundefined 1 Reply Last reply Reply Quote 0
                                    Cherno Alpha @nhof
                                    @nhof
                                    Thanks for the advice. I will have a look and test to see how that goes.
                                      Cherno Alpha
                                      A Bit of an update.
                                      After getting my mate to spend way to much time on it troubleshooting the problematic Z axis issue, he decided to make the nema 23s just motors instead of integrated steppers. Not long after I had a fully functioning Z axis. The X and Y axes are still the integrated stepper and work well.
                                      Printer is calibrated on the XYZ axes. Tested the extruder side as well all functioning. Only thing really left to do is put the bondtech on it and the usual bed calibrations etc. Then we are off and printing.
                                      Thanks for all the assistance in getting this up and running.
                                      Brad
                                        Cherno Alpha
                                        Some good news but also some bad news.
                                        Everything is working so to speak. Ran the first print, and I am getting layer shift on the X and Y axis on every layer. Different prints different direction.
                                        I am using Ideamaker as the slicer, I do not think this is the issue, but it is information.
                                        The X and Y axis are still controlled by the integrated steppers.
                                        As the print continues it gets progressively worse.
                                        See below for the config file.
                                        ; generated by RepRapFirmware Configuration Tool v2.0.4 on Tue Sep 24 2019 14:17:15 GMT+1000 (Australian Eastern Standard Time)
                                        M550 P"Unicorns are not Fucking Real" ; set printer name
                                        M584 X5 Y6 Z2 E3:4 ; set drive mapping
                                        M92 X128.25 Y128.25 Z1600.00 E425.00:425.00 ; set steps per mm
                                        M203 X6000.00 Y6000.00 Z300.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
                                        M906 X1000 Y1000 Z1600 E800:800 I30 ; set motor currents (mA) and motor idle factor in per cent
                                        M558 P0 H2 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
                                        M140 H-1 ; disable heated bed
                                          You should set your motor currents to be around 85% of the rated current for the motor.
                                          If it's already in that range I would ask if the printer is over extruding causing the nozzle to drag excessively?
                                          If that's not the case I would ask if the X and Y mechanism slides freely by hand with no linkage to the motors? Free of binding, rough travel, etc?
                                          • Antipastaundefined
                                            Antipasta
                                            Hi im the silly cat playing with this meany,
                                            so the current for the x and y axis is determined by the dip switches on the driver on the back of the steppers, (which i will check)
                                            The layer shift is every layer and can be either the x or y or both and normally one direction or the other., never a zig zag effect .. always in one direction. So a wall would come out at like 30deg from the bed, if it could print in air.
                                            The lead screws are a helical type with about 25mm per revolution (both axises) Z is a std 2mm lead screw, as by the config file the steps are only 128.25 i think this is due to the large pitch of 25mm.
                                            The layer shift is approx 2mm each shift this seems consistant each layer.
                                            So every layer it would seem it loses steps or gains steps.
                                            This is where it gets confusing, as if it were consistant in a direction it would make more sense.
                                            The X and Y are driven from the expansion board using step+ dir+ and ground.
                                            We are getting the correct movement when manually joging the gantry around ie: 500mm = 500mm
                                            I have not changed any dip switches on the stepper/drivers from when it was driven from the ramps1.4 board running marlin.
                                            The other thing im not 100% on was the micro stepping being now 32bit and the duets config lets you choose the micro step, could it be a conflict between the config and the drivers on the stepper motors, being micro stepped differently. I know micro stepping has some dips switches settings on the drivers on the steppers.
                                            One thing i have noticed, these steppers X and Y are (by the spec sheet) seem to be 5amp capable, they are being powered by a 48volt psu. Where the Duet2 is being powered by a 24volt psu, heat bed is a 240v unit ( it is 1000x1000)
                                            As a last resort i can remove the inbuilt driver from the steppers and just use the Duet drivers but im not sure the Duet would drive 3 additional steppers at 2.4 amps each with that 25mm pitch lead screw.
                                            Anyway any help ideas are greatfully accepted.
                                            Troy
