    3DP1000 Duet Ethernet Conversion
    42
    2.7k
      deckingman @Cherno Alpha
      @cherno-alpha Fair enough.
      Cherno Alphaundefined 1 Reply Last reply Reply Quote 0
      • Cherno Alphaundefined
        Cherno Alpha @deckingman
        @deckingman Just checked out your blog. Insane printer and good luck at the show with the Duet 3 ( Which I just learned about on your site, so thanks for that).
        I might look at the Duet 3 for my scratchbuild project (when I get around to it).
        Ultimaker 2, Raise3d N2 Plus, 3DP1000, Creaform Go!Scan 50, Creaform Handyscan700
        • nhofundefined
          nhof
          @Cherno-Alpha The newer 3D platform machines run on duet controllers. Here is a link to the firmware config files which should be reasonably similar to your setup and may give you a starting point for settings (attachment to the link below).
          https://support.3dplatform.com/portal/kb/articles/workseries-firmware-update-process
          Note that the axis motors on the duet units are connected via the duet servo expansion board: https://www.filastruder.com/products/duet-expansion-board
          T3P3Tonyundefined Cherno Alphaundefined 2 Replies Last reply Reply Quote 0
            T3P3Tony administrators @nhof
            @nhof thanks
            @Cherno-Alpha also the Warwick Design + Make team upgraded theirs https://twitter.com/LizBish94/status/1136329317745614849
            So it can certainly be done!
              Cherno Alpha
              @nhof @T3P3Tony
              Thanks for the info.
              I saw that the newer ones have been changed over to duet boards, the main difference with mine i think is that my x/y/z axes are steppers rather than servos.
              Looking forward to getting this done as I think it will provide a much better 3d printing experience for me. Especially with a bondtech.
                Cherno Alpha
                @nhof ,
                With the expansion board [in case i need to purchase it as well], is it the cable and expansion board, or just the cable?
                nhofundefined 1 Reply Last reply Reply Quote 0
                • nhofundefined
                  nhof @Cherno Alpha
                  @cherno-alpha Shop page looks like you can buy it either way.
                    Cherno Alpha
                    The Duet Ethernet should be here tomorrow.
                    A few other items I will be doing to the printer is an enclosure for the print area. Pretty important for me as I do a lot of ABS printing (helps I make my own filament as well).
                    The next is the Z-Probe for mapping the bed. I had a look on this site and saw the Piezo sensors. They look to be pretty much perfect for my purposes. Mapping the 1m x 1m bed is pretty important especially if there is dips in the bed. Any one used the piezo sensors? They are mentioned on this page here. https://duet3d.dozuki.com/Wiki/Choosing_a_Z_probe . Once that or similar is installed, I will probably do 15 points on the bed to map it out. Essentially one measurement every 25cm.
                      A Former User
                      @cherno-alpha said in 3DP1000 Duet Ethernet Conversion:
                      beware if you'll be using the online configurator with power loss function
                      https://forum.duet3d.com/post/107325
                        Cherno Alpha @A Former User
                        @bearer Is this like the Power Resume Feature?
                        If so, I dont use it and I am not a fan of it for two reasons.
                        Firstly, if you are not nearby and everything cools down, the print will lift from the bed.
                        Secondly, the ones that I have tried re home before commencing again. They never go back to the exact same spot and is always off just a touch.
                        If the print shits itself, I just restart it.
                          A Former User @Cherno Alpha
                          yeah. but the online config tool has a bug and renders the config useless if you enable the power loss / resume function. but if you don't plan on using that then go forth and configure without worries:) with one less worry:)
                          Cherno Alphaundefined droftartsundefined 3 Replies Last reply Reply Quote 0
                            @bearer There will be plenty of worrying when configuring it. Never really done this type of thing before, but I have figured out most of the other things with printers. I am an expert on repairing my Raise3d machines 😄
                              droftarts administrators @A Former User
                              @bearer The Configurator code has been fixed on Github (and network has been put back at the beginning of config.g, so at least people should be able to connect to DWC), just waiting for the online configurator to be updated.
                                @bearer Actually, it's already been updated and M911 in config.g has double quotes around it, but you have to clear cache to make your browser use the latest version. From Christian:
                                Check for version 2.0.1
                                Can be seen on the start page. If it displays v2.0.0, clear your browser cache
                                And my mistake, the network code hasn't been moved back to the beginning yet.
                                  Cherno Alpha
                                  The Duet has arrived, I am looking at a piezo bed levelling system for this, is it fiddly to set up and is it reliable? Alternatively what is the most user friendly bed levelling system? The bed is glass.
                                    Phaedrux Moderator @Cherno Alpha
                                    @Cherno-Alpha said in 3DP1000 Duet Ethernet Conversion:
                                    Therein lies the rub. They're all pretty picky in some way or another. Pick your poison.
                                      Cherno Alpha @nhof
                                      @nhof Just looked at the expansion board and I need to get one, problem is the Australian reps dont have any at all so will have to get them from overseas. Yay for freight charges.
                                        Cherno Alpha
                                        Ok, so I have installed the duet ethernet, and the expansion board to go with it.
                                        The problem that I am encountering at the moment is with the Z axis.
                                        X and Y home and operate perfectly.
                                        Z is the issue.
                                        We have been able to get Z to home. Once home, if you press + 5mm it does not operate. If I go - 5mm it tries to drive the hotend through the printer.
                                        The Z dive height has been set to 0.
                                        To continue testing we have to manually wind the Z axis to try something new.
                                        Any suggestions to try would be great.
                                        Thanks,
                                        Brad
                                        • Dougal1957undefined
                                          Dougal1957
                                          try posting your config.g and homing files then we can all have a look and see if there is anything obvious.
                                            Why would you set it to 0?
                                            Have you seen this? https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCartesianPrinter#Section_Homing_Z
                                            We'd need to see your config and homing files.
