    RepRapFirmware 3.0 first official beta is out
    Beta Firmware
    15
    132
    9.3k
    • kraegarundefined
      kraegar
      Yep, already starting a print!
      Sorry, if I'd noticed M122 had a different version earlier I wouldn't have bothered till that was fixed!
      (It may be worth investigating how your updates work, since the CLI showed a later version than what was running, something didn't get overwritten properly)
        T3P3Tony administrators @kraegar
        @kraegar yes - i think we need to force stop the service before the update runs
        • kraegarundefined
          kraegar
          Is it possibly to query against the duet services from the CLI now? A diag script to list versions, compare the running version against the installed version, etc would be trivial, and handy if so. I'm sure more could be added to it over time, too.
          A Former User? T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
            A Former User @kraegar
            @kraegar said in RepRapFirmware 3.0 first official beta is out:
            maybe the link in this post has some inspiration; not been updated to reflect the new repository however https://github.com/chrishamm/DuetSoftwareFramework/issues/31#issuecomment-513701442
            if you meant to run g-code from the console you might want to look at this (CodeConsole is very unpolished)
            pi@duet3:/opt/dsf/bin $ sudo ./CodeConsole
            Connected!
            M115
            FIRMWARE_NAME: RepRapFirmware for Duet 3 ...
            beikeland created this issue in chrishamm/DuetSoftwareFramework
            closed M115 does not work on serial/USB #31
              @kraegar you can see what services are running in the normal linux way. but not what firmware is on the duet w/o writing a plugin for DSF (or as @bearer says use codeconsole)
              kraegarundefined 1 Reply Last reply Reply Quote 1
              • kraegarundefined
                kraegar @T3P3Tony
                @T3P3Tony Yeah, I meant querying the duet itself. I'll take a look at codeconsole, and the other threads. Sounds like there's been some good work done already, so I probably won't muddy the waters.
                • kraegarundefined
                  kraegar
                  Longest completed duet3 print @ 3h 5m without issue now that I'm running the latest software. I'll keep on testing!
                  • smoki3undefined
                    smoki3
                    I have problems with the thermistors on this build on my Duet2Wifi. T0,T1 and Bed shows -273 °C. The thermistors on the duex5 are fine. They are defines as:
                    ; Thermal Sensors
                    M308 S0 P"bed_temp" Y"thermistor" T100000 B3950 R4700                    	; Set thermistor + ADC parameters for heater 0
                    M308 S1 P"e0_temp" Y"thermistor" T100000 B4725 C7.060000e-8 R4700       	; Set thermistor + ADC parameters for heater 1
                    M308 S2 P"e1_temp" Y"thermistor" T100000 B4725 C7.060000e-8 R4700       	; Set thermistor + ADC parameters for heater 2
                    M308 S3 P"e2_temp" Y"thermistor" T100000 B4725 C7.060000e-8 R4700       	; Set thermistor + ADC parameters for heater 3
                    M308 S4 P"e3_temp" Y"thermistor" T100000 B4725 C7.060000e-8 R4700       	; Set thermistor + ADC parameters for heater 4
                    ; Hardware
                    M950 H0 C"bed_heat" T0
                    M950 H1 C"e0_heat" T1
                    M950 H2 C"e1_heat" T2
                    M950 H3 C"!exp.heater3" T3
                    M950 H4 C"!exp.heater4" T4
                    If I ask for the Statuts with M308 S1I get correct values:
                    M308 S1
                    Sensor 1 type Thermistor using pin e0temp, reading 22.1, last error: success, T:100000.0 B:4725.0 C:7.06e-8 R:4700.0 L:0 H:0
                    • tdybare69undefined
                      tdybare69
                      I NEED HELP MY SD CARD CRASHED. HOW DO I START WITH A BLANK SD CARD.
                        A Former User @tdybare69
                        @tdybare69 said in RepRapFirmware 3.0 first official beta is out:
                        You start by turning off your Caps Lock. Then you format the SD card, download Raspbian - write the image to the SD card, and add the Duet3D repository and install DuetSoftwareFramework according to the Wiki. (Or wait for the Duet3d guys to make the image available as a download)
                        wget -q https://pkg.duet3d.com/duet3d.gpg
                        wget -q https://pkg.duet3d.com/duet3d-unstable.list
                        sudo mv duet3d.gpg /etc/apt/trusted.gpg.d/
                        sudo mv duet3d-unstable.list /etc/apt/sources.list.d/duet3d-unstable.list
                        sudo chown root:root /etc/apt/trusted.gpg.d/duet3d.gpg
                        sudo chown root:root /etc/apt/sources.list.d/duet3d-unstable.list
                        sudo apt-get install apt-transport-https
                        sudo apt-get update
                        tdybare69undefined 1 Reply Last reply Reply Quote 1
                        • jannauundefined
                          jannau
                          The only option I currently see is start with a new Raspbian image and install Duet Software Framework as described here: https://duet3d.dozuki.com/Wiki/Duet_3_prototype_guide_for_OEMs
                          I'm currently doing that since my Duet3 apparently came without SD card and it seems to work. I have not connected any Hardware to the Duet yet.
                            T3P3Tony administrators @tdybare69
                            @tdybare69 I have just finished writing the documentation to help with this:
                            https://duet3d.dozuki.com/Wiki/SBC_Setup_for_Duet_3
                            Please let me know how you get on.
                            @bearer thankfully we have the SD image so hopefully it will be a bit quicker now. Also welcome feedback on the linked documentation.
                              T3P3Tony administrators @jannau
                              @jannau I am surprised your Duet 3 came without an SD card, I will pass that on. Please see this documentation:
                              Feedback welcome I have just written it!
                                A Former User
                                Looks good at a glance, minor formatting glitch in the list way at the bottom, has visible [code] tags.
                                DuetPi.img 3.2G - this could probably be compressed to save some bandwidth and or time.
                                Edit:
                                You will need at least an 8Gb class 10 SD card.
                                If using a larger card you may wish to expand the filesystem to utilize the adittional space. Run sudo raspi-config nonint do_expand_rootfs to expand the filesystem to span the whole card.
                                One this is complete Windows may prompt you to format the disk. Do not do this, it is because Windows does not recognise one of the partitions on the image.
                                Once
                                Create a new file named “wpa_supplicant.conf” (exact naming is critical, do not have a ".txt" at the end of the file).
                                This file already exists in the image btw
                                In a text editor add the following:
                                country=GB
                                Replacing the SSID_OF_NETWORK with your wifi SSID and PASSWORD_OF_NETWORK with your password.
                                Save and safely eject the SD card
                                Might be obvious to some, but changing the country code for compliance with wifi certifications might be mentioned here. Which channel the driver will allow the wifi chip to use is dependent on this setting. Two letter country code from https://en.wikipedia.org/wiki/ISO_3166-1#Officially_assigned_code_elements
                                If none of these steps work see the Troubleshooting Duet 3 - SBC communications documentation.
                                dead link
                                Image Size and compression: DuetPi.img 3,447,717,888 vs DuetPi.img.bz2 864,099,605 - maybe not everyone is living in purgatory with a 4Mbit downstream. Also consider adding MD5/SHA1 signature files to help verify the download.
                                tdybare69undefined 1 Reply Last reply Reply Quote 0
                                  tdybare69 @A Former User
                                  @bearer WHERE DO I GET THE DUET 3D REPOSITORY.
                                    tdybare69 @tdybare69
                                    i got it working the hard way but it is missing files. i am going to try your way. then maybe i can get the bltouch to work
                                    i keep getting a m280invalid servo index 5 in m280 command.
                                      @tdybare69 can you start a new thread with the specific issue.
                                      If by "missing files" you mean the printer configuration for your printer, you do need to generate that yourself, looking at the issues you are reporting i would start by checking.
                                      https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_M280
                                      and you will need to setup the specific pin you are using for the BL touch servo using M950.
                                        tdybare69 @T3P3Tony
                                        @T3P3Tony i have plugged it in according to the diagram. black and white on the probe 2 right pins. the red on pin1 , brown on pin 2, and the orange on pin 8.
                                          tdybare69
                                          no i mean there is no override file,or deploy.g, or retaract.g. those r just the ones i know about. i am new to this.
                                            there is one guy at matter hackers that ben helping but they dont deal with bl touches alot.
