    RepRapFirmware 3.0 first official beta is out
    Beta Firmware
    15
    132
    9.0k
    • tdybare69undefined
      tdybare69
      I NEED HELP MY SD CARD CRASHED. HOW DO I START WITH A BLANK SD CARD.
      A Former User? T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
        A Former User @tdybare69
        @tdybare69 said in RepRapFirmware 3.0 first official beta is out:
        You start by turning off your Caps Lock. Then you format the SD card, download Raspbian - write the image to the SD card, and add the Duet3D repository and install DuetSoftwareFramework according to the Wiki. (Or wait for the Duet3d guys to make the image available as a download)
        wget -q https://pkg.duet3d.com/duet3d.gpg
        wget -q https://pkg.duet3d.com/duet3d-unstable.list
        sudo mv duet3d.gpg /etc/apt/trusted.gpg.d/
        sudo mv duet3d-unstable.list /etc/apt/sources.list.d/duet3d-unstable.list
        sudo chown root:root /etc/apt/trusted.gpg.d/duet3d.gpg
        sudo chown root:root /etc/apt/sources.list.d/duet3d-unstable.list
        sudo apt-get install apt-transport-https
        sudo apt-get update
        tdybare69undefined 1 Reply Last reply Reply Quote 1
        • jannauundefined
          jannau
          The only option I currently see is start with a new Raspbian image and install Duet Software Framework as described here: https://duet3d.dozuki.com/Wiki/Duet_3_prototype_guide_for_OEMs
          I'm currently doing that since my Duet3 apparently came without SD card and it seems to work. I have not connected any Hardware to the Duet yet.
            T3P3Tony administrators @tdybare69
            @tdybare69 I have just finished writing the documentation to help with this:
            https://duet3d.dozuki.com/Wiki/SBC_Setup_for_Duet_3
            Please let me know how you get on.
            @bearer thankfully we have the SD image so hopefully it will be a bit quicker now. Also welcome feedback on the linked documentation.
              T3P3Tony administrators @jannau
              @jannau I am surprised your Duet 3 came without an SD card, I will pass that on. Please see this documentation:
              Feedback welcome I have just written it!
                A Former User
                Looks good at a glance, minor formatting glitch in the list way at the bottom, has visible [code] tags.
                DuetPi.img 3.2G - this could probably be compressed to save some bandwidth and or time.
                Edit:
                You will need at least an 8Gb class 10 SD card.
                If using a larger card you may wish to expand the filesystem to utilize the adittional space. Run sudo raspi-config nonint do_expand_rootfs to expand the filesystem to span the whole card.
                One this is complete Windows may prompt you to format the disk. Do not do this, it is because Windows does not recognise one of the partitions on the image.
                Once
                Create a new file named “wpa_supplicant.conf” (exact naming is critical, do not have a ".txt" at the end of the file).
                This file already exists in the image btw
                In a text editor add the following:
                country=GB
                Replacing the SSID_OF_NETWORK with your wifi SSID and PASSWORD_OF_NETWORK with your password.
                Save and safely eject the SD card
                Might be obvious to some, but changing the country code for compliance with wifi certifications might be mentioned here. Which channel the driver will allow the wifi chip to use is dependent on this setting. Two letter country code from https://en.wikipedia.org/wiki/ISO_3166-1#Officially_assigned_code_elements
                If none of these steps work see the Troubleshooting Duet 3 - SBC communications documentation.
                dead link
                Image Size and compression: DuetPi.img 3,447,717,888 vs DuetPi.img.bz2 864,099,605 - maybe not everyone is living in purgatory with a 4Mbit downstream. Also consider adding MD5/SHA1 signature files to help verify the download.
                tdybare69undefined 1 Reply Last reply Reply Quote 0
                  tdybare69 @A Former User
                  @bearer WHERE DO I GET THE DUET 3D REPOSITORY.
                    tdybare69 @tdybare69
                    i got it working the hard way but it is missing files. i am going to try your way. then maybe i can get the bltouch to work
                    i keep getting a m280invalid servo index 5 in m280 command.
                      @tdybare69 can you start a new thread with the specific issue.
                      If by "missing files" you mean the printer configuration for your printer, you do need to generate that yourself, looking at the issues you are reporting i would start by checking.
                      https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_M280
                      and you will need to setup the specific pin you are using for the BL touch servo using M950.
                        tdybare69 @T3P3Tony
                        @T3P3Tony i have plugged it in according to the diagram. black and white on the probe 2 right pins. the red on pin1 , brown on pin 2, and the orange on pin 8.
                          tdybare69
                          no i mean there is no override file,or deploy.g, or retaract.g. those r just the ones i know about. i am new to this.
                            there is one guy at matter hackers that ben helping but they dont deal with bl touches alot.
                              @bearer said in RepRapFirmware 3.0 first official beta is out:
                              here is my config.g file.
                              ; generated by RepRapFirmware Configuration Tool v2.0.4 on Tue Sep 17 2019 19:45:33 GMT-0400 (Eastern Daylight Time)
                              M550 P"Turnigy" ; set printer name
                              M667 S1 ; select CoreXY mode
                              M552 S1 ; enable network
                              M586 P0 S1 ; enable HTTP
                              M586 P1 S0 ; disable FTP
                              M586 P2 S0 ; disable Telnet
                              M569 P2 S0 ; physical drive 2 goes backwards
                              M92 X80.00 Y80.00 Z400.00 E97.00 ; set steps per mm
                              M566 X600.00 Y600.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
                              M203 X18000.00 Y18000.00 Z180.00 E1500.00 ; set maximum speeds (mm/min)
                              M201 X3000.00 Y3000.00 Z100.00 E10000.00 ; set accelerations (mm/s^2)
                              M906 X950 Y950 Z950 E950 I30 ; set motor currents (mA) and motor idle factor in per cent
                              M84 S30 ; Set idle timeout
                              M208 X330 Y330 Z400 S0 ; set axis maxima
                              M574 X1 Y1 Z1 S0 ; set active low and disabled endstops
                              M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
                              M558 P5 H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
                              G31 P500 X73 Y35 Z2.5 ; set Z probe trigger value, offset and trigger height
                              M556 S50 X0 Y0 Z0 ; set orthogonal axis compensation parameters
                              M106 P2 S1 I0 F500 H-1 ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
                              M563 P0 S"HotEnd" D0 H1 F0 ; define tool 0
                              • kraegarundefined
                                kraegar
                                A bit over 20 hours of printing later I'm reporting back that things have been very stable since getting the correct version running. No issues to report!
                                  dc42 administrators @tdybare69
                                  Those are settings for RepRapFirmware 2. They (and maybe other things in config.g) need to be changed for RepRapFirmware 3. See https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview.
                                    T3P3Tony administrators @kraegar
                                    @kraegar said in RepRapFirmware 3.0 first official beta is out:
                                    Thanks for the update.
                                    • Dougal1957undefined
                                      Dougal1957 @T3P3Tony
                                      @T3P3Tony I have run the update SW Stuff but mine is still reporting 1.0.3.1 and won't go to 1.0.3.3 or whatever it's supposed to is there any other steps that need to be done first and please KISS for this very uninformed new LINUX User?
                                      Doug
                                        A Former User @Dougal1957
                                        @Dougal1957 said in RepRapFirmware 3.0 first official beta is out:
                                        1.0.3.3 is in the unstable repo, which are you using?
                                        Official image uses stable repo, so thats limited to 1.0.3.1 until Duet3D put 10.3.3 in that. Or you could add the unstable repo:
                                        sudo bash -c "echo deb https://pkg.duet3d.com/ unstable armv7 >> /etc/apt/sources.list.d/duet3d-unstable.list"
                                        sudo apt update
                                        sudo apt upgrade duetsoftwareframework
                                        • smoki3undefined
                                          smoki3 @Marco Bona
                                          @Marco-Bona said in RepRapFirmware 3.0 first official beta is out:
                                          With this build I encounter problems with heater mapping. The values ​​found are -273 with the exception of the heated chamber which is correct.
                                          ; 9 _ HEATERS
                                          M308 S0 P"bed_temp" Y"thermistor" A"Bed thermistor" T100000 B3950
                                          M308 S1 P"spi.cs1" Y"rtd-max31865" P"spi.cs1" A"RTD1"
                                          M308 S2 P"spi.cs2" Y"rtd-max31865" A"RTD2"
                                          M308 S3 P"e2_temp" Y"thermistor" A"Chamber thermistor" T100000 B4725 C7.06e-8
                                          M950 H0 C"bed_heat" T0
                                          M950 H1 C"e0_heat" T1
                                          M950 H2 C"e1_heat" T2
                                          M950 H3 C"duex.e2heat" T3
                                          @smoki3 said in RepRapFirmware 3.0 first official beta is out:
                                          I have problems with the thermistors on this build on my Duet2Wifi. T0,T1 and Bed shows -273 °C. The thermistors on the duex5 are fine. They are defines as:
                                          ; Thermal Sensors
                                          M308 S0 P"bed_temp" Y"thermistor" T100000 B3950 R4700                    	; Set thermistor + ADC parameters for heater 0
                                          M308 S1 P"e0_temp" Y"thermistor" T100000 B4725 C7.060000e-8 R4700       	; Set thermistor + ADC parameters for heater 1
                                          M308 S2 P"e1_temp" Y"thermistor" T100000 B4725 C7.060000e-8 R4700       	; Set thermistor + ADC parameters for heater 2
                                          M308 S3 P"e2_temp" Y"thermistor" T100000 B4725 C7.060000e-8 R4700       	; Set thermistor + ADC parameters for heater 3
                                          M308 S4 P"e3_temp" Y"thermistor" T100000 B4725 C7.060000e-8 R4700       	; Set thermistor + ADC parameters for heater 4
                                          ; Hardware
                                          M950 H3 C"!exp.heater3" T3
                                          M950 H4 C"!exp.heater4" T4
                                          If I ask for the Statuts with M308 S1I get correct values:
                                          M308 S1
                                          Sensor 1 type Thermistor using pin e0temp, reading 22.1, last error: success, T:100000.0 B:4725.0 C:7.06e-8 R:4700.0 L:0 H:0
                                          Is there any solution to fix thermistor on Duet 2 Wifi?
                                          smoki3undefined dc42undefined 2 Replies Last reply Reply Quote 0
                                            Dougal1957 @A Former User
                                            sudo apt update
                                            Thankyou that's the bit I was missing now sorted
