    Duet 3 Mainboard 6HC - initial production run.
    243
    32.9k
    • gtj0undefined
      gtj0 @Dougal1957
      @Dougal1957 said in Duet 3 Mainboard 6HC - initial production run.:
      @T3P3Tony said in Duet 3 Mainboard 6HC - initial production run.:
      @Dougal1957 I expect we will do, will announce more next week.
      Thanks I will point him to this.
      Tell him to get to the back of the line. 🙂
      • gtj0undefined
        gtj0
        It's a little hard to tell from the renderings and pics but can someone confirm that the 26 pin connector polarity notch faces in towards the MPU?
          A Former User @gtj0
          @gtj0 said in Duet 3 Mainboard 6HC - initial production run.:
          Did you see the new Wiki? https://duet3d.dozuki.com/Wiki/SBC_Setup_for_Duet_3
          • gtj0undefined
            gtj0 @A Former User
            @bearer Yeah but you can't tell in those pics because the cable exits the IDC pins to the left (inwards) but then loops back through the strain relief towards the right and out. I can't see the notch.
              A Former User
              @gtj0 I suppose its not given the notch is on the left hand side in those pictures although the red stripe indicating pin 1 would suggest that, which side the cable exits shouldn't affect pin 1 and the notch.
              • gtj0undefined
                gtj0 @A Former User
                I've learned through bitter experience not to take for granted the relationship between the notch and pin 1. About 10 years ago I had a local company make me 100 10-pin cables and they didn't bother to follow my spec. Apparently 3 different people made the cables so I got 3 different orientations.
                Anyway, I'm experimenting with different cable lengths and right now I'm getting great results with a 300mm cable at a 1MHz clock rate but only if I alternate the signal lines with grounds. In fact it still looks great at 5HMz. I was toying with using some twisted pair as well but twisted pairs aren't all that effective in unbalanced circuits.
                  T3P3Tony administrators @gtj0
                  @gtj0 the 26 way header notch goes in, towards the center of the Duet 3 mainboard. The Duet 3 has a keyed header.
                  • gtj0undefined
                    gtj0 @T3P3Tony
                    Perfect. Thanks @T3P3Tony And what are you doing up so late?
                    • Danalundefined
                      Danal
                      Mine is here! Yay!
                      From reading this thread, and the new wiki, it is a little unclear to me if the included SD card is should already have an image on it. The one I received formatted, but empty. Installing the image now...
                      Edit update: Image installed, booted, connected via both Web and SSH, everything works just fine. Now, to pick a printer to receive this beauty... 🙂
                      Danal
                      • Dougal1957undefined
                        Dougal1957
                        Mine certainly had an image on else I would have been lost as I know very little about the way Linux interacts (I know a lot more now since I got this thing on Saturday)
                        Doug
                          A Former User @Dougal1957
                          Doug
                          Did the Duet 3 just get classified as a "gateway drug"? 😮
                          NoSkillzEngineerundefined 1 Reply Last reply Reply Quote 2
                            T3P3Tony administrators @Danal
                            @Danal it should have had the image, glad you got it working!
                            • gtj0undefined
                              gtj0
                              @T3P3Tony Have you guys tested to determine the maximum practical SPI clock rate the Duet3 can handle, irrespective of cable characteristics?
                                @gtj0 it is determined by cable length. With the cables we supply we expect at least 10Mhz will work well, Iam currently running 5Mhz with no issues and after TCT will try extended periods with 10Mhz.
                                The image comes with 1Mhz as a default - thats conservative but till allows for a high throughput.
                                PastThePointundefined 1 Reply Last reply Reply Quote 0
                                • PastThePointundefined
                                  PastThePoint @T3P3Tony
                                  Tony,
                                  I despise bothering you like this, but is there any news on any units being available? I've got cash in hand, and this would be PERFECT on the rig I am putting together!
                                  Doug instructed me to come bother you. 😁
                                  Thanks!
                                    dc42 administrators @PastThePoint
                                    @PastThePoint said in Duet 3 Mainboard 6HC - initial production run.:
                                    Tony,
                                    Thanks!
                                    Current plans are to ship the next batch in November, following EMC testing for CE/FCC certification and any resulting changes we need to make. We were planning to open a pre-order for that batch next week, but that may be difficult because of the TCT show.
                                    • NoSkillzEngineerundefined
                                      NoSkillzEngineer
                                      Received my Duet3 today......looking at this up close for the first time, as couple thoughts come to mind.
                                      (1) it's bigger than I expected. I actually prefer that it is a bit bigger because it gives the impression of more of a "motherboard" or "mainboard" which is what I wanted out of the Duet2 initially.
                                      (2) there are two different type of headers on this, the motor headers are significantly "beefier"
                                      (Kinda wish they were the same like tan-ish color though.....first world problems 😆)
                                      (3) lotta components on this board....getting me excited and I haven't even plugged it in yet!!!
                                      (4) there's two RJ45 ports on it?? Hmmm, okay, cool.
                                      (5) kinda wish someone would hit these with a fine file, knife, or like red or blue scotchbright before they got sent out, I have it here, I just wish I didn't have to, again, first world problems.
                                      Excited to use it!!!
                                      Thank you!
                                        NoSkillzEngineer @A Former User
                                        @bearer said in Duet 3 Mainboard 6HC - initial production run.:
                                        Doug
                                        It should have if it didn't 😂
                                          A Former User @NoSkillzEngineer
                                          @NoSkillzEngineer said in Duet 3 Mainboard 6HC - initial production run.:
                                          Thank you!
                                          x2 RJ 45 port's ?
                                          I received mine today and I thought it was an RJ45 & an RJ11
                                            A Former User
                                            Should be a RJ45 (8 pin) for Ethernet* and a RJ11 (6pin) for the CAN bus on the production board, but at a glance they look somewhat similar
                                            *) when used standalone firmware and SD card instead of RaspberryPi
