    RepRapFirmware 3.0 first official beta is out
    Beta Firmware
    15
    132
    9.3k
      T3P3Tony administrators @kraegar
      @kraegar said in RepRapFirmware 3.0 first official beta is out:
      A bit over 20 hours of printing later I'm reporting back that things have been very stable since getting the correct version running. No issues to report!
      Thanks for the update.
      • Dougal1957undefined
        Dougal1957 @T3P3Tony
        @T3P3Tony I have run the update SW Stuff but mine is still reporting 1.0.3.1 and won't go to 1.0.3.3 or whatever it's supposed to is there any other steps that need to be done first and please KISS for this very uninformed new LINUX User?
        Doug
          A Former User @Dougal1957
          @Dougal1957 said in RepRapFirmware 3.0 first official beta is out:
          1.0.3.3 is in the unstable repo, which are you using?
          Official image uses stable repo, so thats limited to 1.0.3.1 until Duet3D put 10.3.3 in that. Or you could add the unstable repo:
          sudo bash -c "echo deb https://pkg.duet3d.com/ unstable armv7 >> /etc/apt/sources.list.d/duet3d-unstable.list"
          sudo apt update
          sudo apt upgrade duetsoftwareframework
          • smoki3undefined
            smoki3 @Marco Bona
            @Marco-Bona said in RepRapFirmware 3.0 first official beta is out:
            With this build I encounter problems with heater mapping. The values ​​found are -273 with the exception of the heated chamber which is correct.
            ; 9 _ HEATERS
            M308 S0 P"bed_temp" Y"thermistor" A"Bed thermistor" T100000 B3950
            M308 S1 P"spi.cs1" Y"rtd-max31865" P"spi.cs1" A"RTD1"
            M308 S2 P"spi.cs2" Y"rtd-max31865" A"RTD2"
            M308 S3 P"e2_temp" Y"thermistor" A"Chamber thermistor" T100000 B4725 C7.06e-8
            M950 H0 C"bed_heat" T0
            M950 H1 C"e0_heat" T1
            M950 H2 C"e1_heat" T2
            M950 H3 C"duex.e2heat" T3
            @smoki3 said in RepRapFirmware 3.0 first official beta is out:
            I have problems with the thermistors on this build on my Duet2Wifi. T0,T1 and Bed shows -273 °C. The thermistors on the duex5 are fine. They are defines as:
            ; Thermal Sensors
            M308 S0 P"bed_temp" Y"thermistor" T100000 B3950 R4700                    	; Set thermistor + ADC parameters for heater 0
            M308 S1 P"e0_temp" Y"thermistor" T100000 B4725 C7.060000e-8 R4700       	; Set thermistor + ADC parameters for heater 1
            M308 S2 P"e1_temp" Y"thermistor" T100000 B4725 C7.060000e-8 R4700       	; Set thermistor + ADC parameters for heater 2
            M308 S3 P"e2_temp" Y"thermistor" T100000 B4725 C7.060000e-8 R4700       	; Set thermistor + ADC parameters for heater 3
            M308 S4 P"e3_temp" Y"thermistor" T100000 B4725 C7.060000e-8 R4700       	; Set thermistor + ADC parameters for heater 4
            ; Hardware
            M950 H3 C"!exp.heater3" T3
            M950 H4 C"!exp.heater4" T4
            If I ask for the Statuts with M308 S1I get correct values:
            M308 S1
            Sensor 1 type Thermistor using pin e0temp, reading 22.1, last error: success, T:100000.0 B:4725.0 C:7.06e-8 R:4700.0 L:0 H:0
            Is there any solution to fix thermistor on Duet 2 Wifi?
            smoki3undefined dc42undefined 2 Replies Last reply Reply Quote 0
              Dougal1957 @A Former User
              @bearer said in RepRapFirmware 3.0 first official beta is out:
              sudo apt update
              Thankyou that's the bit I was missing now sorted
              • smoki3undefined
                smoki3 @smoki3
                ; 9 _ HEATERS
                ; Thermal Sensors
                ; Hardware
                M308 S1
                since this commit :
                commit
                the temp sensors on duet 2 wifi are broken. The sensors on the duex5 are still working
                  dc42 administrators @smoki3
                  ; 9 _ HEATERS
                  ; Thermal Sensors
                  ; Hardware
                  M308 S1
                  Strange, it's working on my Duet WiFi-powered delta. The hot end uses a PT100 but the bed uses a thermistor.
                  If you run M98 Pconfig.g do you get any error messages?
                  smoki3undefined 1 Reply Last reply Reply Quote 0
                  • smoki3undefined
                    smoki3 @dc42
                    @dc42 Just warnings for overpowered heaters.
                    I compiled a build before the mentioned commit. There everything workings as it should. starting with this commit it's broken.
                    Oddly all my duex5 thermistors are working.
                    EDIT:
                    I get this on the new build:
                    Error: M307: Heater 1 not found
                    Error: M307: Heater 2 not found
                    Warning: M307: heater 3 appears to be over-powered. If left on at full power, its temperature is predicted to reach 741C.
                    Warning: M307: heater 4 appears to be over-powered. If left on at full power, its temperature is predicted to reach 592C.
                      I've just remembered, someone else reported a bug whereby if you get an over-powered message warning then it fails to set the heater model. I thought I fixed this before the beta 10 release not after, but I could be wrong.
                      • smoki3undefined
                        smoki3 @dc42
                        @dc42 I found the issue:
                        I have to declare the heaters with
                        M950 H0 C"bedheat" T0
                        instead off
                        But according to documentation both should work
                          instead off
                          Thanks, I found the problem in the source code. Will be fixed in next commit.
                          PS - the same bug was present when using M950 to declare a fan.
                          • tdybare69undefined
                            tdybare69 @dc42
                            @dc42 I AM USING 2.03
                              A Former User @tdybare69
                              @tdybare69 said in RepRapFirmware 3.0 first official beta is out:
                              You did read the title of this thread before posting right?
                              tdybare69undefined 1 Reply Last reply Reply Quote 0
                                tdybare69 @A Former User
                                @CaLviNx YOU MUST HAVE MISSED THE PART OF I AM NEW TO ALL THIS.
                                T3P3Tonyundefined A Former User? 2 Replies Last reply Reply Quote 0
                                  T3P3Tony administrators @tdybare69
                                  @tdybare69 please open a new thread to discuss your issue.
                                    @tdybare69
                                    Well to be brutally honest if you don't even have the cognitive power to read the title of a thread, you are in for a long hard road trying to get a Duet to work.
                                    Also little bit of advice on Internet etiquette. Capital letters are considered "shouting" there is no need for it.
                                    And as has been said please open a thread where you can can request assistance for the particular issue that you are encountering.
                                    Someone "might" be willing to take on the monumental task of trying to help you.
                                    tdybare69undefined 1 Reply Last reply Reply Quote 1
                                    • kraegarundefined
                                      kraegar
                                      I've had multiple days of completed prints, thought I was out of the woods, but then had another stop and report it's 100% only part way through the file. Checked the file's gcode, and it did upload all 100mm of the print, but it stopped at 41.6mm. No error or heater fault reported, both heaters shut off when it stopped.
                                      M122
                                      RepRapFirmware for Duet 3 v0.5 version 3.0beta10 running on Duet 3 prototype v0.5
                                      Board ID: 08DGM-9T66A-G63SJ-6J1FJ-3SD6M-KS0BA
                                      Used output buffers: 1 of 32 (6 max)
                                      Static ram: 67696
                                      Dynamic ram: 133764 of which 60 recycled
                                      Exception stack ram used: 592
                                      Never used ram: 191104
                                      Tasks: NETWORK(ready,2044) HEAT(blocked,1208) CanReceiv(suspended,3804) CanSender(suspended,1496) CanClock(blocked,1432) TMC(blocked,456) MAIN(running,2060) IDLE(ready,196)
                                      Owned mutexes:
                                      Last reset 01:05:56 ago, cause: power up
                                      Last software reset at 2019-09-19 17:50, reason: Unknown, spinning module Platform, available RAM 191596 bytes (slot 2)
                                      Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task 0x4e49414d
                                      Error status: 0
                                      MCU temperature: min 44.0, current 57.2, max 57.4
                                      Supply voltage: min 22.2, current 24.2, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
                                      Driver 0: standstill, reads 22271, writes 23 timeouts 0, SG min/max 0/1023
                                      Driver 1: standstill, reads 22273, writes 23 timeouts 0, SG min/max 0/1023
                                      Driver 2: standstill, reads 22270, writes 27 timeouts 0, SG min/max 0/184
                                      Driver 3: standstill, reads 22271, writes 27 timeouts 0, SG min/max 0/1023
                                      Driver 4: standstill, reads 22272, writes 27 timeouts 0, SG min/max 0/178
                                      Driver 5: standstill, reads 22281, writes 19 timeouts 0, SG min/max 0/1000
                                      Date/time: 2019-09-20 14:10:57
                                      Slowest loop: 176.43ms; fastest: 0.19ms
                                      Hiccups: 94892, FreeDm: 375, MinFreeDm: 297, MaxWait: 177311ms
                                      === MainDDARing ===
                                      Scheduled moves: 6, completed moves: 6, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
                                      === AuxDDARing ===
                                      Segments left: 0
                                      Movement lock held by null
                                      http is idle in state(s) 0
                                      telnet is idle in state(s) 0
                                      file* is idle in state(s) 0
                                      serial is idle in state(s) 0
                                      aux is idle in state(s) 0
                                      daemon* is ready with "M122" in state(s) 0
                                      queue is idle in state(s) 0
                                      lcd is idle in state(s) 0
                                      spi is idle in state(s) 0
                                      Code queue is empty.
                                      === Network ===
                                      Slowest loop: 16.40ms; fastest: 0.01ms
                                      Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) Telnet(0) Telnet(0)
                                      HTTP sessions: 0 of 8
                                      • Ethernet -
                                        State: 0
                                        === Linux interface ===
                                        State: 0, failed transfers: 0
                                        Last transfer: 88ms ago
                                        RX/TX seq numbers: 6056/6056
                                        SPI underruns 0, overruns 0
                                        Number of disconnects: 1
                                        Buffer RX/TX: 0/0-0
                                        === Duet Control Server ===
                                        Duet Control Server v1.0.3.3
                                        File:
                                        Pending code: G1 X126.818 Y131.288 E0.04478
                                        Pending code: G1 X126.235 Y131.602 E0.02226
                                        Pending code: G1 X125.637 Y131.893 E0.02236
                                        Pending code: G1 X125.026 Y132.161 E0.02243
                                        Pending code: G1 X124.417 Y132.399 E0.02199
                                        Pending code: G1 X123.431 Y132.722 E0.03487
                                        Pending code: G1 X122.487 Y132.975 E0.03285
                                        Pending code: G1 X121.843 Y133.113 E0.02213
                                        Pending code: G1 X121.189 Y133.225 E0.02230
                                        Pending code: G1 X120.536 Y133.307 E0.02213
                                        Pending code: G1 X119.204 Y133.394 E0.04488
                                        Pending code: G1 X118.802 Y133.387 E0.01352
                                        Pending code: G1 X98.914 Y113.500 E0.94545
                                        Pending code: G1 E-0.56250 F3300.00000
                                        Pending code: G1 F9600
                                        Buffered code: G1 F3793
                                        Buffered code: G1 X115.759 Y101.174 E0.91349
                                        Buffered code: G1 X114.852 Y101.362 E0.03114
                                        Buffered code: G1 X114.289 Y101.516 E0.01964
                                        Buffered code: G1 X113.138 Y101.895 E0.04072
                                        Buffered code: G1 X112.018 Y102.359 E0.04074
                                        Buffered code: G1 X111.501 Y102.608 E0.01929
                                        Buffered code: G1 X110.442 Y103.191 E0.04066
                                        Buffered code: G1 X109.428 Y103.848 E0.04062
                                        Buffered code: G1 X108.961 Y104.191 E0.01946
                                        Buffered code: G1 X108.029 Y104.957 E0.04056
                                        Buffered code: G1 X107.601 Y105.350 E0.01955
                                        Buffered code: G1 X106.745 Y106.225 E0.04114
                                        Buffered code: G1 X106.503 Y106.503 E0.01238
                                        Buffered code: G1 X129.437 Y129.437 E1.09030
                                        Buffered code: G1 X128.490 Y130.200 E0.04089
                                        Buffered code: G1 X127.949 Y130.584 E0.02231
                                        => 732 bytes
                                        Code buffer space: 2048
                                        Configured SPI speed: 1000000 Hz
                                        Full transfers per second: 312.28
                                        Processing print job /opt/dsf/sd/gcodes/joel-new-and-improved-without-additional-stuff-in-his-head2_0.16mm_PLA__2h14m.gcode
                                        @CaLviNx caps were on due to working in gcodes with web control. its not that i dont have the inteligance, i just work all day, outside in the heat. am tired at the end of the day, no need to be rude.
                                          The word is intelligence, and trust me, for me I was being extremely nice.
                                            @kraegar please try DSF 1.0.3.5 when you get a chance.
                                            kraegarundefined 1 Reply Last reply Reply Quote 0
