    RepRapFirmware 3.0 first official beta is out
    Beta Firmware
    15
    132
    9.2k
    • tdybare69undefined
      tdybare69 @T3P3Tony
      @T3P3Tony i have plugged it in according to the diagram. black and white on the probe 2 right pins. the red on pin1 , brown on pin 2, and the orange on pin 8.
        tdybare69
        no i mean there is no override file,or deploy.g, or retaract.g. those r just the ones i know about. i am new to this.
        tdybare69undefined 1 Reply Last reply Reply Quote 0
          tdybare69 @tdybare69
          @tdybare69 said in RepRapFirmware 3.0 first official beta is out:
          there is one guy at matter hackers that ben helping but they dont deal with bl touches alot.
            tdybare69 @A Former User
            @bearer said in RepRapFirmware 3.0 first official beta is out:
            Looks good at a glance, minor formatting glitch in the list way at the bottom, has visible [code] tags.
            DuetPi.img 3.2G - this could probably be compressed to save some bandwidth and or time.
            here is my config.g file.
            ; generated by RepRapFirmware Configuration Tool v2.0.4 on Tue Sep 17 2019 19:45:33 GMT-0400 (Eastern Daylight Time)
            M550 P"Turnigy" ; set printer name
            M667 S1 ; select CoreXY mode
            M552 S1 ; enable network
            M586 P0 S1 ; enable HTTP
            M586 P1 S0 ; disable FTP
            M586 P2 S0 ; disable Telnet
            M569 P2 S0 ; physical drive 2 goes backwards
            M92 X80.00 Y80.00 Z400.00 E97.00 ; set steps per mm
            M566 X600.00 Y600.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
            M203 X18000.00 Y18000.00 Z180.00 E1500.00 ; set maximum speeds (mm/min)
            M201 X3000.00 Y3000.00 Z100.00 E10000.00 ; set accelerations (mm/s^2)
            M906 X950 Y950 Z950 E950 I30 ; set motor currents (mA) and motor idle factor in per cent
            M84 S30 ; Set idle timeout
            M208 X330 Y330 Z400 S0 ; set axis maxima
            M574 X1 Y1 Z1 S0 ; set active low and disabled endstops
            M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
            M558 P5 H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
            G31 P500 X73 Y35 Z2.5 ; set Z probe trigger value, offset and trigger height
            M556 S50 X0 Y0 Z0 ; set orthogonal axis compensation parameters
            M106 P2 S1 I0 F500 H-1 ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
            M563 P0 S"HotEnd" D0 H1 F0 ; define tool 0
            • kraegarundefined
              kraegar
              A bit over 20 hours of printing later I'm reporting back that things have been very stable since getting the correct version running. No issues to report!
                dc42 administrators @tdybare69
                Those are settings for RepRapFirmware 2. They (and maybe other things in config.g) need to be changed for RepRapFirmware 3. See https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview.
                  T3P3Tony administrators @kraegar
                  @kraegar said in RepRapFirmware 3.0 first official beta is out:
                  Thanks for the update.
                  • Dougal1957undefined
                    Dougal1957 @T3P3Tony
                    @T3P3Tony I have run the update SW Stuff but mine is still reporting 1.0.3.1 and won't go to 1.0.3.3 or whatever it's supposed to is there any other steps that need to be done first and please KISS for this very uninformed new LINUX User?
                    Doug
                      A Former User @Dougal1957
                      @Dougal1957 said in RepRapFirmware 3.0 first official beta is out:
                      1.0.3.3 is in the unstable repo, which are you using?
                      Official image uses stable repo, so thats limited to 1.0.3.1 until Duet3D put 10.3.3 in that. Or you could add the unstable repo:
                      sudo bash -c "echo deb https://pkg.duet3d.com/ unstable armv7 >> /etc/apt/sources.list.d/duet3d-unstable.list"
                      sudo apt update
                      sudo apt upgrade duetsoftwareframework
                      • smoki3undefined
                        smoki3 @Marco Bona
                        @Marco-Bona said in RepRapFirmware 3.0 first official beta is out:
                        With this build I encounter problems with heater mapping. The values ​​found are -273 with the exception of the heated chamber which is correct.
                        ; 9 _ HEATERS
                        M308 S0 P"bed_temp" Y"thermistor" A"Bed thermistor" T100000 B3950
                        M308 S1 P"spi.cs1" Y"rtd-max31865" P"spi.cs1" A"RTD1"
                        M308 S2 P"spi.cs2" Y"rtd-max31865" A"RTD2"
                        M308 S3 P"e2_temp" Y"thermistor" A"Chamber thermistor" T100000 B4725 C7.06e-8
                        M950 H0 C"bed_heat" T0
                        M950 H1 C"e0_heat" T1
                        M950 H2 C"e1_heat" T2
                        M950 H3 C"duex.e2heat" T3
                        @smoki3 said in RepRapFirmware 3.0 first official beta is out:
                        I have problems with the thermistors on this build on my Duet2Wifi. T0,T1 and Bed shows -273 °C. The thermistors on the duex5 are fine. They are defines as:
                        ; Thermal Sensors
                        M308 S0 P"bed_temp" Y"thermistor" T100000 B3950 R4700                    	; Set thermistor + ADC parameters for heater 0
                        M308 S1 P"e0_temp" Y"thermistor" T100000 B4725 C7.060000e-8 R4700       	; Set thermistor + ADC parameters for heater 1
                        M308 S2 P"e1_temp" Y"thermistor" T100000 B4725 C7.060000e-8 R4700       	; Set thermistor + ADC parameters for heater 2
                        M308 S3 P"e2_temp" Y"thermistor" T100000 B4725 C7.060000e-8 R4700       	; Set thermistor + ADC parameters for heater 3
                        M308 S4 P"e3_temp" Y"thermistor" T100000 B4725 C7.060000e-8 R4700       	; Set thermistor + ADC parameters for heater 4
                        ; Hardware
                        M950 H3 C"!exp.heater3" T3
                        M950 H4 C"!exp.heater4" T4
                        If I ask for the Statuts with M308 S1I get correct values:
                        M308 S1
                        Sensor 1 type Thermistor using pin e0temp, reading 22.1, last error: success, T:100000.0 B:4725.0 C:7.06e-8 R:4700.0 L:0 H:0
                        Is there any solution to fix thermistor on Duet 2 Wifi?
                        smoki3undefined dc42undefined 2 Replies Last reply Reply Quote 0
                          Dougal1957 @A Former User
                          sudo apt update
                          Thankyou that's the bit I was missing now sorted
                          • smoki3undefined
                            smoki3 @smoki3
                            ; 9 _ HEATERS
                            ; Thermal Sensors
                            ; Hardware
                            M308 S1
                            since this commit :
                            commit
                            the temp sensors on duet 2 wifi are broken. The sensors on the duex5 are still working
                              dc42 administrators @smoki3
                              ; 9 _ HEATERS
                              ; Thermal Sensors
                              ; Hardware
                              M308 S1
                              Strange, it's working on my Duet WiFi-powered delta. The hot end uses a PT100 but the bed uses a thermistor.
                              If you run M98 Pconfig.g do you get any error messages?
                              smoki3undefined 1 Reply Last reply Reply Quote 0
                              • smoki3undefined
                                smoki3 @dc42
                                @dc42 Just warnings for overpowered heaters.
                                I compiled a build before the mentioned commit. There everything workings as it should. starting with this commit it's broken.
                                Oddly all my duex5 thermistors are working.
                                EDIT:
                                I get this on the new build:
                                Error: M307: Heater 1 not found
                                Error: M307: Heater 2 not found
                                Warning: M307: heater 3 appears to be over-powered. If left on at full power, its temperature is predicted to reach 741C.
                                Warning: M307: heater 4 appears to be over-powered. If left on at full power, its temperature is predicted to reach 592C.
                                  I've just remembered, someone else reported a bug whereby if you get an over-powered message warning then it fails to set the heater model. I thought I fixed this before the beta 10 release not after, but I could be wrong.
                                  • smoki3undefined
                                    smoki3 @dc42
                                    @dc42 I found the issue:
                                    I have to declare the heaters with
                                    M950 H0 C"bedheat" T0
                                    instead off
                                    But according to documentation both should work
                                      instead off
                                      Thanks, I found the problem in the source code. Will be fixed in next commit.
                                      PS - the same bug was present when using M950 to declare a fan.
                                        tdybare69 @dc42
                                        @dc42 I AM USING 2.03
                                          A Former User @tdybare69
                                          You did read the title of this thread before posting right?
                                            @CaLviNx YOU MUST HAVE MISSED THE PART OF I AM NEW TO ALL THIS.
                                            T3P3Tonyundefined A Former User? 2 Replies Last reply Reply Quote 0
