    Line skips. Cr 10-s5
    450
    • ziggymanpopoundefined
      ziggymanpopo
      Thanks will give this a try
        ziggymanpopo
        Can you tell le where to set M350 what mode were set at 16 across the board
        • JamesMundefined
          JamesM
          It's under the "Drives" section....this is my entire drives section but do take it as gospel since I have changed some things on my Ender 3 like the direct drive bondtech extruder
          M569 P3 S0 ; Drive 3 goes forwards(changed to backwards)
          M92 X80.00 Y80.00 Z400.00 E408.30 ; Set steps per mm (gregs wade was 604 steps)
          M566 X500.00 Y500.00 Z30.00 E600.00 ; Set maximum instantaneous speed changes (mm/min)
          M203 X10800.00 Y9000.00 Z300.00 E3000.00 ; Set maximum speeds (mm/min)
          M201 X1000.00 Y1000.00 Z500.00 E3000.00 ; Set accelerations (mm/s^2)
          M906 X950.00 Y950.00 Z850.00 E900.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
            ziggymanpopo
            In M906 i typed M906 Y:950 enter and it changed the y to 0 instead of 950. Any idea what i did wrong???
            ziggymanpopoundefined 1 Reply Last reply Reply Quote 0
              ziggymanpopo @ziggymanpopo
              @ziggymanpopo
              And thanks for the info gettting a claerer pickture every day. ๐Ÿ˜
                ziggymanpopo
                Does the entire string of M-code need to be typed when changing current on one steper and why cant i now chainge it back to what it was at 500. I think im missing how to make the enty?????
                • JamesMundefined
                  JamesM
                  After you changed it in the config file did you save it and the duet reboot?
                    ziggymanpopo
                    Well that make me ask this do i make my changes in the config file or thru the gcode console ive ben using the g code console
                    • JamesMundefined
                      JamesM
                      In the config.g file if you want them to stay permanent. If you do it just on the top in the command line it will only be temporary until you turn the unit off or it reboots/resets. Doing changes up top is nice if you want to change something on the fly/mid print or just try something first but it's only temporary.
                        ziggymanpopo
                        Awsome i think you pionted me on the right direction. I am wondering why it wont chainge it in a terminal environmental?? Or does it. Ill let you know shortly ๐Ÿ˜Š๐Ÿ‘
                          ziggymanpopo
                          James. I thank you for For taking the time to teach me
                          I now understand how to make the changes and it worked. Only thing left is to sy thank you and run a test print ๐Ÿ‘๐Ÿ˜Š i have some other small issues ill post later but this gets me up
                          • JamesMundefined
                            JamesM
                            Good luck and take your time.
