    CAN-FD hardware
    Hardware wishlist
    1.3k
    • JoergS5undefined
      JoergS5
      I want to experiment with CAN-FD: is it possible to use it to transmit data e.g. for quality control by cameras. I want to build it with hardware which is compatible with Duet 3.
      So far I found some MCP25...FD chips, with the dual CAN-FD MCP25612FD the most interesting (about 5$). Is there experience whether they are compatible with Duet 3, or, if not, is there good hardware for this purpose?
      The new Teensy 4 has CAN-FD also, is this compatible with Duet 3?
      Addition: TCAN4550 seems very promising, it is controller and transceiver and only about 3$.
        dc42 administrators @JoergS5
        We use the MCP2542 chips for driving the CAN bus. They have a separate power pin for the MCU interface, so they can level shift between a 3.3V MCU and still use 5V to drive the CAN bus.
        • Kulitorumundefined
          Kulitorum
          What is the max cable length for the CAN-FD Bus?
          Kulitorum
          • JoergS5undefined
            JoergS5 @dc42
            @dc42 Thank you. I hope the MCP25 family is compatible with each other. If not, I will let you know...
            • JoergS5undefined
              JoergS5 @Kulitorum
              @Kulitorum According to the table in https://www.computer-solutions.co.uk/info/Embedded_tutorials/can_tutorial.htm it is 10 m (ISO 11898-2 2015). Small house 😉
                Max cable length depends on the data rate and the number of devices on the bus. We use 1Mbits/sec as the base data rate. Page 5 of http://www.ti.com/lit/an/slla270/slla270.pdf suggests 1Mbits/sec should be OK to 40m length. The fast data rate will be configurable, https://duet3d.dozuki.com/Wiki/Gcode#Section_M952_Set_CAN_FD_bus_data_rate.
                  T3P3Tony administrators @dc42
                  @Kulitorum 40m.. slighly larger house 😄
                    Kulitorum
                    I was hoping for 150m 🙂
                    Will everything work at 0.25Mbps?
                    Kulitorum
                      Currently it would need a new firmware build to change the base data rate, because everything (including the bootloaders on the expansion boards) needs to know what that data rate is. Using lower speeds might work if the machine isn't tool complex and doesn't print sequences of tiny segments fast, so that we don't need to send movement commands to expansion boards at too great a rate.
                        Kulitorum
                        hehe, shame.
                        I print 1000mm/sec with vertices for every 5mm...
                        So can I amplify the signal every 40 meters? - Do expansion boards daisy chain?
                        • JoergS5undefined
                          JoergS5
                          I saw there exist CAN-FD repeaters, maybe an option.
                          It exists a CAN FD repeater reference design by http://www.ti.com/lit/ug/tidudb5a/tidudb5a.pdf (for an optional extension card maybe).
                          Kulitorumundefined 1 Reply Last reply Reply Quote 0
                            T3P3Tony administrators @Kulitorum
                            @Kulitorum said in CAN-FD hardware:
                            yes, but only physically, they don't amplify/act as an active repeater.
                              Kulitorum @JoergS5
                              @JoergS5 Thanks, looks good.
                                Kulitorum
                                Once I receive the expansion boards, I will experiment with this. Any ETA?
                                  @Kulitorum will be emailing those who expressed an interest in the prototype boards after TCT show next week (you are on the list!)
