    RepRapFirmware 3.0 first official beta is out
    Beta Firmware
    15
    132
    9.2k
    • kraegarundefined
      kraegar
      I've had multiple days of completed prints, thought I was out of the woods, but then had another stop and report it's 100% only part way through the file. Checked the file's gcode, and it did upload all 100mm of the print, but it stopped at 41.6mm. No error or heater fault reported, both heaters shut off when it stopped.
      M122
      RepRapFirmware for Duet 3 v0.5 version 3.0beta10 running on Duet 3 prototype v0.5
      Board ID: 08DGM-9T66A-G63SJ-6J1FJ-3SD6M-KS0BA
      Used output buffers: 1 of 32 (6 max)
      Static ram: 67696
      Dynamic ram: 133764 of which 60 recycled
      Exception stack ram used: 592
      Never used ram: 191104
      Tasks: NETWORK(ready,2044) HEAT(blocked,1208) CanReceiv(suspended,3804) CanSender(suspended,1496) CanClock(blocked,1432) TMC(blocked,456) MAIN(running,2060) IDLE(ready,196)
      Owned mutexes:
      Last reset 01:05:56 ago, cause: power up
      Last software reset at 2019-09-19 17:50, reason: Unknown, spinning module Platform, available RAM 191596 bytes (slot 2)
      Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task 0x4e49414d
      Error status: 0
      MCU temperature: min 44.0, current 57.2, max 57.4
      Supply voltage: min 22.2, current 24.2, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
      Driver 0: standstill, reads 22271, writes 23 timeouts 0, SG min/max 0/1023
      Driver 1: standstill, reads 22273, writes 23 timeouts 0, SG min/max 0/1023
      Driver 2: standstill, reads 22270, writes 27 timeouts 0, SG min/max 0/184
      Driver 3: standstill, reads 22271, writes 27 timeouts 0, SG min/max 0/1023
      Driver 4: standstill, reads 22272, writes 27 timeouts 0, SG min/max 0/178
      Driver 5: standstill, reads 22281, writes 19 timeouts 0, SG min/max 0/1000
      Date/time: 2019-09-20 14:10:57
      Slowest loop: 176.43ms; fastest: 0.19ms
      Hiccups: 94892, FreeDm: 375, MinFreeDm: 297, MaxWait: 177311ms
      === MainDDARing ===
      Scheduled moves: 6, completed moves: 6, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
      === AuxDDARing ===
      Segments left: 0
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file* is idle in state(s) 0
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon* is ready with "M122" in state(s) 0
      queue is idle in state(s) 0
      lcd is idle in state(s) 0
      spi is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 16.40ms; fastest: 0.01ms
      Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) Telnet(0) Telnet(0)
      HTTP sessions: 0 of 8
      • Ethernet -
        State: 0
        === Linux interface ===
        State: 0, failed transfers: 0
        Last transfer: 88ms ago
        RX/TX seq numbers: 6056/6056
        SPI underruns 0, overruns 0
        Number of disconnects: 1
        Buffer RX/TX: 0/0-0
        === Duet Control Server ===
        Duet Control Server v1.0.3.3
        File:
        Pending code: G1 X126.818 Y131.288 E0.04478
        Pending code: G1 X126.235 Y131.602 E0.02226
        Pending code: G1 X125.637 Y131.893 E0.02236
        Pending code: G1 X125.026 Y132.161 E0.02243
        Pending code: G1 X124.417 Y132.399 E0.02199
        Pending code: G1 X123.431 Y132.722 E0.03487
        Pending code: G1 X122.487 Y132.975 E0.03285
        Pending code: G1 X121.843 Y133.113 E0.02213
        Pending code: G1 X121.189 Y133.225 E0.02230
        Pending code: G1 X120.536 Y133.307 E0.02213
        Pending code: G1 X119.204 Y133.394 E0.04488
        Pending code: G1 X118.802 Y133.387 E0.01352
        Pending code: G1 X98.914 Y113.500 E0.94545
        Pending code: G1 E-0.56250 F3300.00000
        Pending code: G1 F9600
        Buffered code: G1 F3793
        Buffered code: G1 X115.759 Y101.174 E0.91349
        Buffered code: G1 X114.852 Y101.362 E0.03114
        Buffered code: G1 X114.289 Y101.516 E0.01964
        Buffered code: G1 X113.138 Y101.895 E0.04072
        Buffered code: G1 X112.018 Y102.359 E0.04074
        Buffered code: G1 X111.501 Y102.608 E0.01929
        Buffered code: G1 X110.442 Y103.191 E0.04066
        Buffered code: G1 X109.428 Y103.848 E0.04062
        Buffered code: G1 X108.961 Y104.191 E0.01946
        Buffered code: G1 X108.029 Y104.957 E0.04056
        Buffered code: G1 X107.601 Y105.350 E0.01955
        Buffered code: G1 X106.745 Y106.225 E0.04114
        Buffered code: G1 X106.503 Y106.503 E0.01238
        Buffered code: G1 X129.437 Y129.437 E1.09030
        Buffered code: G1 X128.490 Y130.200 E0.04089
        Buffered code: G1 X127.949 Y130.584 E0.02231
        => 732 bytes
        Code buffer space: 2048
        Configured SPI speed: 1000000 Hz
        Full transfers per second: 312.28
        Processing print job /opt/dsf/sd/gcodes/joel-new-and-improved-without-additional-stuff-in-his-head2_0.16mm_PLA__2h14m.gcode
      • tdybare69undefined
        tdybare69 @A Former User
        @CaLviNx caps were on due to working in gcodes with web control. its not that i dont have the inteligance, i just work all day, outside in the heat. am tired at the end of the day, no need to be rude.
          A Former User @tdybare69
          @tdybare69 said in RepRapFirmware 3.0 first official beta is out:
          The word is intelligence, and trust me, for me I was being extremely nice.
            T3P3Tony administrators @kraegar
            @kraegar please try DSF 1.0.3.5 when you get a chance.
            kraegarundefined 1 Reply Last reply Reply Quote 0
            • kraegarundefined
              kraegar @T3P3Tony
              This post is deleted!
              • kraegarundefined
                kraegar
                Updated, then had the thought to check M122. Once again it's showing I'm running 1.0.3.3 even though the pi reflects 1.0.3.5.
                apt list 2>/dev/null | grep duet | awk -F'[/ ]' '{print $1" "$3 }'
                duetcontrolserver 1.0.3.5
                duetruntime 1.0.3.5
                duetsd 1.0.2
                duetsoftwareframework 1.0.3.5
                duettools 1.0.3.5
                duetwebcontrol 2.0.0-4
                duetwebserver 1.1.0.0
                Full transfers per second: 220.03
                I'll force the full update.
                  @kraegar stupid question but you are stopping the service and then restarting it?
                  • kraegarundefined
                    kraegar
                    I did not stop the service manually when I updated. If that's in the instructions I apologize, I winged it since I recall you'd said you were adding stopping the services to the apt scripts. 🙂
                    • kraegarundefined
                      kraegar
                      For clarification, I'm doing an sudo apt-get update; sudo apt get upgrade
                      Perhaps something odd is happening that's preventing it from upgrading for me?
                      • kraegarundefined
                        kraegar
                        Just checked, doesn't look like that's in the instructions, so I didn't skip it 🙂
                        I can provide more info on my pi, but literally the only thing I've installed has been the duet software. I've left it completely "stock" other than that. It's a pi4 running the "lite" install of Buster.
                        • gtj0undefined
                          gtj0
                          @kraegar This should do it...
                          sudo systemctl restart duetcontrolserver
                          sudo systemctl restart duetwebserver
                            yes its not in the instructions - fair one.
                            • kraegarundefined
                              kraegar @gtj0
                              @gtj0 Sure. But using apt-get that shouldn't be necessary. Upgrade scripts should stop services if required. I have no problem doing it manually, either.
                              • kraegarundefined
                                kraegar
                                Very strangely reprinting the same file today as failed yesterday, while it's running and looks like it will complete, has plummeted in print quality. The only change at all was to update the duetsoftware framework on the pi. Same spool of filament, etc.
                                I'll test some other slices, but that was unexpected.
                                • smoki3undefined
                                  smoki3
                                  Does it matter on RRF3 if I connect my Z Probe to Duet2Wifi or Duex5? I know on RRF2 there was a difference in the latency.
                                  Is this still the same here?
                                  • kraegarundefined
                                    kraegar
                                    No changes other than updating the duet software and restarting the printer. The one from 1.0.3.3 on the right (that failed part way through), 1.0.3.5 on the left. I was tuning a new slicer (PrusaSlicer), so the first had some cooling issues, but the new one is something else entirely. I don't use pressure advance or firmware retracts, nothing like that.
                                    • smoki3undefined
                                      smoki3
                                      Seems there is a bug with the endstops on the duet2.
                                      My Z probe (normal micro switch) is randomly not working.
                                      On the one hand sometimes it is showing in DWC Z-Probe status 1000 even when then probe is not triggered. Without touching the printer I do a emergency stop than the probe status is 0.
                                      On the other hand sometimes it is not detected if the probe is triggered and my printer is crashing.
                                      The microswitch is connected to my duex5.
                                      Its defined with this code:
                                      M574 Z0 C"nil" 		                       ; no Z endstop switch, free up Z endstop input
                                      M558 P5 C"!duex.e2stop" H3 F180 T25000 	       ; Z probe connected to Z endstop input
                                      G31 X-14 Y0 Z0.00 P500          	       ; Set Z probe offset + naher ran - weiter weg
                                      M557 X0:300 Y0:190 S50:47.5                    ; Define mesh grid
                                      UPDATE: seems like it make a huge difference if I take the pins directly on the duet instead of the duex5.
                                      • smoki3undefined
                                        smoki3
                                        I also have another wire behavior with stall detection on my corexy machine with the duet2.
                                        If I start homing the machine executes the homey.g (also happens for X axis) as it should. But the randomly I get the massage homing failed. But no crash or something else. Everything is as it should just the message homing failed and the axis is not marked es homes.
                                        I tried so many stall parameters but I don't this it has something to do with this, because the stall is working fine and the home is done fine. Just the axis get not marked as home then I get homing failed.
                                        Is there a way to debug?
                                          dc42 administrators @smoki3
                                          The Homing Failed message means that the homing switch was not triggered before the move completed. If using stall detection, it means no stall was detected.
                                          smoki3undefined 1 Reply Last reply Reply Quote 0
                                          • smoki3undefined
                                            smoki3 @dc42
                                            @dc42 said in RepRapFirmware 3.0 first official beta is out:
                                            But it is detected because it move to the end position and then it do the rest of the script (move a bit away from the end position end so on). Otherwise the printer should crash normally because it have to go another 400mm if the stall is not detected
