    feedrate confusions
    1.2k
    • georgepaulundefined
      georgepaul
      M584 X0 Y1 Z2 E3:4:5:6 ; drive remapping
      M569 P0 S1 ; Physical drive 0 goes forwards
      M569 P1 S0 ; Physical drive 1 goes forwards
      M569 P2 S0 ; Physical drive 2 goes backwards
      M569 P3 S1 ; Physical drive 3 goes forwards
      M569 P4 S0 ; Physical drive 4 goes forwards
      M350 X128 Y128 Z128 E128:128:128:128 I1 ; Configure microstepping without interpolation
      M92 X640.00 Y640.00 Z3200.00 E3200:3200:3200:3200 ; Set steps per mm
      M566 X900.00 Y900.00 Z12.00 E120.00 ; Set maximum instantaneous speed changes (mm/min)(E120)
      M203 X12000.00 Y12000.00 Z500.00 E3000.00 ; Set maximum speeds (mm/min)
      M201 X1000.00 Y1000.00 Z100.00 E5000.00 ; Set accelerations (mm/s^2)
      M906 X855.00 Y855.00 Z1000.00 E855.00:855.00:855.00:855.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      • wilrikerundefined
        wilriker @georgepaul
        @georgepaul said in feedrate confusions:
        You need to repeat the values for each extruder as you did in the other commands as well with these ones. Otherwise they will most likely get a default value.
        EDIT: My fault. They will auto-repeat.
        Manuel
        My Tool Collection
          georgepaul
          M566 X900.00 Y900.00 Z12.00 E120.00:120.00:120.00:120.00 ; Set maximum instantaneous speed changes (mm/min)(E120)
          M203 X12000.00 Y12000.00 Z500.00 E3000:3000:3000:3000 ; Set maximum speeds (mm/min)
          M201 X1000.00 Y1000.00 Z100.00 E5000.00:5000.00:5000.00:5000.00 ; Set accelerations (mm/s^2)
          I tried this also
            georgepaul
            M563 P0 D0:1:2:3 H1 ; Define tool 0
            • wilrikerundefined
              @georgepaul Did you also just try
              G1 E100 F100
              Since your tool is configured to have 4 extruders and probably no mixing ratio (M567 ) this should already be sufficient to move all extruder steppers. What happens then in regards to duration?
              Manuel
              My Tool Collection
              georgepaulundefined 1 Reply Last reply Reply Quote 0
                georgepaul @wilriker
                @wilriker when i send G1 E100 F100, the first extruder(E0) moves and it rotates for 1 minute.
                • wilrikerundefined
                  @georgepaul OK, then next question: does it work correctly if you define an equal mixing ratio like
                  M567 P0 E1:1:1:1
                  and then just use
                  G1 E100 F100
                  Manuel
                  My Tool Collection
                    georgepaul
                    @wilriker said in feedrate confusions:
                    M567 P0 E1:1:1:1
                    i tried this.. it still took 2 minutes
                    • wilrikerundefined
                      @georgepaul OK, we need more information. Can you please run the following commands on your machine and post the output:
                      M115
                      M201
                      M203
                      M566
                      M92
                      M350
                      M906
                      This will print what the machine currently takes as configured values plus the current firmware version.
                      Manuel
                      My Tool Collection
                        georgepaul
                        100
                        M115
                        FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.0(RTOS) ELECTRONICS: Duet WiFi 1.02 or later + DueX5 FIRMWARE_DATE: 2018-06-05b3
                        M201
                        Accelerations: X: 1000.0, Y: 1000.0, Z: 100.0, E: 5000.0:5000.0:5000.0:5000.0
                        M203
                        Maximum feedrates: X: 12000.0, Y: 12000.0, Z: 500.0, E: 3000.0:3000.0:3000.0:3000.0
                        M566
                        Maximum jerk rates: X: 900.0, Y: 900.0, Z: 12.0, E: 120.0:120.0:120.0:120.0
                        M92
                        Steps/mm: X: 640.000, Y: 640.000, Z: 3200.000, E: 3200.000:3200.000:3200.000:3200.000
                        M350
                        Microstepping - X:128(on), Y:128(on), Z:128(on), E:128(on):128(on):128(on):128(on)
                        M906
                        Motor current (mA) - X:855, Y:855, Z:1000, E:855:855:855:855, idle factor 30%
                          As a first step perhaps try upgrading the firmware to latest and see if there has been a bug fix or change that makes a difference. Check the Whats New change log as well.
                          And does it occur the same with x16 microstepping?
                          georgepaulundefined 2 Replies Last reply Reply Quote 0
                            georgepaul @Phaedrux
                            @Phaedrux
                            I haven't tried with varying micro-stepping yet.. I don't think it should make a difference because for one motor E100 F100 is perfect.
                              @Phaedrux i just tried with 1/16 microstepping... still 2 minutes😲
                                georgepaul
                                I just updated my firmware from 2.00 to 2.03 and ran the same tests.
                                M115
                                FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.03 ELECTRONICS: Duet WiFi 1.02 or later + DueX5 FIRMWARE_DATE: 2019-06-13b2
                                Now with M567 P0 E1:1:1:1
                                • G1 E100 F100 / G1 E100:0:0:0 F100 all four motors turn in 1 minute.
                                • G1 E100: 100:0:0 F100 two motors turn in 2 minute.
                                • G1 E100: 100: 100:0 F100 three motors turn in 3 minute.
                                • G1 E100: 100: 100: 100 F100 four motors turn in 4 minute.
                                And without M567 P0 E1:1:1:1
                                • G1 E100 F100 / G1 E100:0:0:0 F100 first motors turn in 1 minute.
                                • G1 E100:100 F100 two motors turn in 2 minute.
                                • G1 E100: 100:100 F100 three motors turn in 3 minute.
                                • G1 E100: 100: 100:100 F100 four motors turn in 4 minute.
                                  georgepaul
                                  now that the timing has changed by itself(after updates), i am sure its nothing to do with my config.g file
                                  • wilrikerundefined
                                    wilriker
                                    Thinking about it that makes even sense because: with the G1 E100:100:100:100 F100 you command to extrude a total of 400mm of filament (distributed over for extruders) with a feedrate of 100mm/min. That takes four minutes.
                                    Manuel
                                    My Tool Collection
                                      @wilriker
                                      That's what I thought too.. so i tried with X and Y axis also,
                                      G1 X100 E100 F100 ;the move took 1minute
                                      G1 Y100 E100 F100 ;the move took 1minute
                                      G1 X100 Y100 E100 F100 ;the move took 1minute 25 seconds
                                        georgepaul
                                        i am just curious to know what the printer is doing behind my back😛
                                        there must be some formulae running in the background. What are the variables and constants that define these movements and feedrates?
                                          @wilriker This logic makes sense because i tried, G1 E100:50:50:100 F100 and it took 3 minutes
                                            deckingman @georgepaul
                                            @wilriker
                                            That looks fine. The first command means move the X axis 100mm at a feedrate of 100mm/minute while extruding 100mm of filament. The second command is the same but for the Y axis. The third command means move in both the X and Y directions by 100mm. That's a diagonal move so the length of that diagonal is longer (by the square root of 2 so about 1.4 times longer). 60 seconds x 1.4 is about 84 seconds so near enough 1 minute and 25.
                                            Edit. Be careful with feedrate. If you do G1 F50 then G1 X100 F100, the move will start at 50mm/minute and end at 100mm/minute so it will ramp up to speed over that move and thus take longer. https://duet3d.dozuki.com/Wiki/Gcode#Section_G0_G1_Move
                                            wilrikerundefined georgepaulundefined 2 Replies Last reply Reply Quote 0
