    Fan: switched GND to switched positive
    1.2k
    • Nxt-1undefined
      Nxt-1
      The problem has evolved from converting voltage levels to something else, so I have updated the thread title as well.
      The BLDC driver board that I am using has multiple GND pins, and seem internally connected. The main GND pin (next to Vcc) is directly connected to my main PSU's negative terminal. When the 2nd ground and 5V signal is connected to the logic signal side of the board, it basically just adds a permanent 5V source. Normally the Duet would switch the fan output's GND pin, but that has no use in this case.
      Any ideas on how to convert a negative switched signal and convert it to positive switched?
      Duet3D and delta printer enthousiast. Buildlog
      Looking for Duet3D configuration support, check out Nxt-3D
      poohzazaundefined A Former User? 2 Replies Last reply Reply Quote 0
      • poohzazaundefined
        poohzaza @Nxt-1
        @Nxt-1
        I have an ideas why not hijack the fan mosfet conector and conect it to external mosfet board useing M106 I1 to invert the fan signal or take a look at M950 command there an option to invert siginal
        and you can do any thing with the signal bare in mind that the logic will be 3.3 volt you can use opto coupler to convet logic
        • fcwiltundefined
          fcwilt
          What is the idea behind using HDD motors?
          I use 12 VDC 40x40x20 mm blowers on the normal Duet fan outputs and they work just fine.
          Nxt-1undefined 1 Reply Last reply Reply Quote 0
            A Former User @Nxt-1
            @Nxt-1 said in Fan: switched GND to switched positive:
            You'd essentially need to throw a pnp bjt or p-channel mosfet in to do high side switching.
            this might give you some insight if you sift out all the irrelevant bits
            https://www.baldengineer.com/pwm-3-pin-pc-fan-arduino.html
            • Nxt-1undefined
              Nxt-1 @fcwilt
              @fcwilt said in Fan: switched GND to switched positive:
              Well first of all, hdd motors and abundant and cheap. Second, I was intrigued by Mark's Rehorst's design, so I decided to play around with it.
              @poohzaza said in Fan: switched GND to switched positive:
              @Nxt-1
              No need to attach directly to the mosfet connector I would say? I am interested in going the optocoupler way. Drive the coupler with the fan output and switch the 5V path to the driver board, maybe with somthing like a 10k resistor in series to limit current.
              • Nxt-1undefined
                Nxt-1 @A Former User
                @bearer said in Fan: switched GND to switched positive:
                Any specific reason why a simple optocoupler (see my above post) might not work? I have a bag of optocoupler still laying around so that would be the easy route for me ๐Ÿ™‚
                  A Former User
                  None other than still needing a PNP output from the optocoupler which is less common, and what output current you need.
                  • Nxt-1undefined
                    Mind sketching a diagram one would wire the transistor (with or without the opto)? ๐Ÿ™‚
                      A Former User
                      either get an optocoupler with an internal PNP instead of the common NPN type, or the link I posted has the plenty of relevant schematics.
                      • poohzazaundefined
                        poohzaza
                        what is you opto model number
                        • Nxt-1undefined
                          Nxt-1 @poohzaza
                          I have a bag of these laying around and just found some old salvaged pnp's. At the moment, my plan is to use the output npn of the opto to drive the pnp transistor as high side switch. I am currently brushing up my bjt knowledge though ๐Ÿ™‚
                          • Nxt-1undefined
                            Nxt-1
                            This is what I have in mind atm, I figured the opto coupler does not add a benefit. I also simplified the internal part Duet on the diagram to a simple switch. I decided it is easier to take the 5V output from the driver board instead of a resistive voltage divider from the Duet's V_fan.
                            I have yet to figure out what current limiting resistors need to be placed in the circuit.
                            • poohzazaundefined
                              poohzaza
                              this viedo may help you figure out current limiting resistors
                              https://www.youtube.com/watch?v=WRm2oUw4owE&list=PLAROrg3NQn7cyu01HpOv5BWo217XWBZu0&index=22&t=0s
                              • Nxt-1undefined
                                Nxt-1
                                So I assumed a collector current of 50mA, which for the bjt I used, resulted in a ~22K base resistor (if I got it right ๐Ÿ™‚ ). This left me with a working high side switch, pulsing ~0-5V, succes! Sadly hooking the signal to the driver board did not do what I wanted it to. The motor ramped up to max speed and stayed there. My assumption is that the Duet's default 250Hz pwm frequency is not what the driver expects.
                                Therefore I decided to add an aggressive low pass filter to the output and remove the driver board solder bridge (so it expects an analogue voltage 0-5V as speed control). For some unknown reason the output voltage at the cap increased to 5V at the cap charged and stayed there, no matter what pan speed I selected.
                                Kind of reaching end of my patience for just getting speed control working sadly ๐Ÿ˜ž
                                • Nxt-1undefined
                                  Nxt-1
                                  I should add that I tried changing the Duet fan frequency to 25kHz as well, without success.
                                  • poohzazaundefined
                                    poohzaza
                                    you can have a look at
                                    1.did you jumper use external control signal
                                    2.remove low pass fliter and conect pwm siginal then conect jumper for pwm control
                                    can i have a look at esc datasheet
                                    or cheak that pwm work correctly by conect mutimeter in volt mode you shoud see variable voltage when you adjust the fan siginal
                                      The problem is that C1 has nowhere to discharge except through the device that you connect the output to. Here are a few suggestions:
                                      1. In your PNP high side driver circuit, increase R2 to 10K and connect a 1K resistor from the transistor collector to ground. I also recommend adding a 10K resistor between base and emitter of the transistor.
                                      2. Instead of using a PNP transistor etc. use a 74HCT02 gate connected to an expansion board heater output, gated with +3.3V, as we suggest for driving a laser PWM pin. Then connect your RC network to the output of the 74HCT02.
                                      3. Use a PWM to 0-10V VFD converter (readily available on eBay), then a voltage divider to reduce the 0-10V to 0-5V.
                                      • Nxt-1undefined
                                        Nxt-1 @poohzaza
                                        I did remove the jumper for external control signal. I also tested in pwm mode and tried some pwm frequencies, without success. Sadly with these cheapo controllers, no datasheet is available (at least that I could find).
                                        @dc42 said in Fan: switched GND to switched positive:
                                        I changed the circuit as you suggested and we seem to have a winner. I did lower the LPF capacitance to 10ยตF, as the rise and fall time was unnecessarily long. I did notice my upper voltage limit is ~3,7V instead of the ideal 5V, but this is not really an issue as 3,7V already corresponds to a very large airflow.
                                        Now I just need to move the components from the breadboard and neatly arrange them on a piece of protoboard.
