Fan: switched GND to switched positive
@Nxt-1 said in Fan: switched GND to switched positive:
Any specific reason why a simple optocoupler (see my above post) might not work? I have a bag of optocoupler still laying around so that would be the easy route for me
None other than still needing a PNP output from the optocoupler which is less common, and what output current you need.
@bearer said in Fan: switched GND to switched positive:
Mind sketching a diagram one would wire the transistor (with or without the opto)?
either get an optocoupler with an internal PNP instead of the common NPN type, or the link I posted has the plenty of relevant schematics.
what is you opto model number
@poohzaza said in Fan: switched GND to switched positive:
I have a bag of these laying around and just found some old salvaged pnp's. At the moment, my plan is to use the output npn of the opto to drive the pnp transistor as high side switch. I am currently brushing up my bjt knowledge though
This is what I have in mind atm, I figured the opto coupler does not add a benefit. I also simplified the internal part Duet on the diagram to a simple switch. I decided it is easier to take the 5V output from the driver board instead of a resistive voltage divider from the Duet's V_fan.
I have yet to figure out what current limiting resistors need to be placed in the circuit.
this viedo may help you figure out current limiting resistors
https://www.youtube.com/watch?v=WRm2oUw4owE&list=PLAROrg3NQn7cyu01HpOv5BWo217XWBZu0&index=22&t=0s -
So I assumed a collector current of 50mA, which for the bjt I used, resulted in a ~22K base resistor (if I got it right
). This left me with a working high side switch, pulsing ~0-5V, succes! Sadly hooking the signal to the driver board did not do what I wanted it to. The motor ramped up to max speed and stayed there. My assumption is that the Duet's default 250Hz pwm frequency is not what the driver expects.
Therefore I decided to add an aggressive low pass filter to the output and remove the driver board solder bridge (so it expects an analogue voltage 0-5V as speed control). For some unknown reason the output voltage at the cap increased to 5V at the cap charged and stayed there, no matter what pan speed I selected.
Kind of reaching end of my patience for just getting speed control working sadly
I should add that I tried changing the Duet fan frequency to 25kHz as well, without success.
you can have a look at
1.did you jumper use external control signal
2.remove low pass fliter and conect pwm siginal then conect jumper for pwm controlcan i have a look at esc datasheet
or cheak that pwm work correctly by conect mutimeter in volt mode you shoud see variable voltage when you adjust the fan siginal
The problem is that C1 has nowhere to discharge except through the device that you connect the output to. Here are a few suggestions:
In your PNP high side driver circuit, increase R2 to 10K and connect a 1K resistor from the transistor collector to ground. I also recommend adding a 10K resistor between base and emitter of the transistor.
Instead of using a PNP transistor etc. use a 74HCT02 gate connected to an expansion board heater output, gated with +3.3V, as we suggest for driving a laser PWM pin. Then connect your RC network to the output of the 74HCT02.
Use a PWM to 0-10V VFD converter (readily available on eBay), then a voltage divider to reduce the 0-10V to 0-5V.
I did remove the jumper for external control signal. I also tested in pwm mode and tried some pwm frequencies, without success. Sadly with these cheapo controllers, no datasheet is available (at least that I could find).
@dc42 said in Fan: switched GND to switched positive:
I changed the circuit as you suggested and we seem to have a winner. I did lower the LPF capacitance to 10ยตF, as the rise and fall time was unnecessarily long. I did notice my upper voltage limit is ~3,7V instead of the ideal 5V, but this is not really an issue as 3,7V already corresponds to a very large airflow.
Now I just need to move the components from the breadboard and neatly arrange them on a piece of protoboard.
