    Cura 4.2.1 Config help
    40
    2.4k
      Phaedrux Moderator @Shaun
      @Shaun said in Cura 4.2.1 Config help:
      M92 X80.00 Y80.00 Z4000.00 E1222.00 ; set steps per mm
      Z4000 for the steps per mm is probably an order of magnitude too high for a CR-10. Z400 is likely the correct value.
        I have checked and when i send a +5 Z moves 5cm up.
        Z+5 should only move 5mm.
        • Shaunundefined
          Shaun
          morning
          I have checked every measurement now. movement is exact. Layer 1 still seems to be 2mm above.
          • wilrikerundefined
            wilriker @Shaun
            @Shaun Can you please post the contents of your homing files then?
            Manuel
            My Tool Collection
            Shaunundefined 1 Reply Last reply Reply Quote 0
            • Shaunundefined
              Shaun @wilriker
              @wilriker said in Cura 4.2.1 Config help:
              ; homex.g
              ; called to home the X axis
              ; generated by RepRapFirmware Configuration Tool v2.0.3 on Fri Sep 13 2019 19:45:33 GMT+0100 (British Summer Time)
              G91 ; relative positioning
              G1 Z2.5 F6000 S2 ; lift Z relative to current position
              G1 S1 X-305 F1800 ; move quickly to X axis endstop and stop there (first pass)
              G1 X5 F6000 ; go back a few mm
              G1 S1 X-305 F360 ; move slowly to X axis endstop once more (second pass)
              G1 Z-2.5 F6000 S2 ; lower Z again
              G90 ; absolute positioning
              ; homey.g
              ; called to home the Y axis
              G1 S1 Y-305 F1800 ; move quickly to Y axis endstop and stop there (first pass)
              G1 Y5 F6000 ; go back a few mm
              G1 S1 Y-305 F360 ; move slowly to Y axis endstop once more (second pass)
              ; homez.g
              ; called to home the Z axis
              ;G1 Z2.5 F6000 S2 ; lift Z relative to current position
              G1 S1 Z-405 F1800 ; move Z down until the endstop is triggered
              G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
              G1 S2 Z15 F100 ; lift Z relative to current position
              ; homeall.g
              ; called to home all axes
              G1 S1 X-305 Y-305 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
              G1 S1 X-305 Y-305 F360 ; move slowly to X and Y axis endstops once more (second pass)
              G1 S1 Z-405 F1800 ; move Z down stopping at the endstop
              G92 Z0 ; set Z to axis minimum (you may want to adjust this)
                Your homing files are configured for endstop switch homing and now Z probe homing.
                https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCartesianPrinter#Section_Homing_Z_using_a_Z_probe
                Instead of this:
                You need a G30 command to probe the bed.
                And your BLTouch command should be updated to this:
                M558 P9 H5 F100 T5000 R0.5
                And I assume you've gone through this?
                https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
                • Shaunundefined
                  Shaun @Phaedrux
                  @Phaedrux said in Cura 4.2.1 Config help:
                  Instead of this:
                  Thanks for the feedback, think i figured it all out shortly after updating this.
                  I want to use my endstop and not the probe which seems to be working just fine.
                  my issue was that i dont think i hat the hotend touching the bed before starting the calibration. |The result was an offset of 2. i printed the golf marker in rough and super fine without any issues. Will move onto something bigger and update tomorrow.
                  • Shaunundefined
                    Shaun
                    OK found the following which could be contributing to my problems..
                    When i "Home All" Z doesnt stop by hitting the endstop. it doesnt even trigger the endstop. When i "Home Z" the endstop is hit and triggered.
                    ; homeall.g
                    G1 S1 X-305 Y-305 F2000 ; move quickly to X and Y axis endstops and stop there (first pass)
                    G1 S1 Z-405 F2000 ; move Z down stopping at the endstop
                    G1 S2 Z0 F500 ; lift Z relative to current position
                    ; homez.g
                    • Shaunundefined
                      Shaun
                      Silly question, how do i clear any settings saved to the board memory? Ive made so many changes and think starting from 0 would be a good idea.
                      • wilrikerundefined
                        wilriker @Shaun
                        @Shaun Either run M999, push the reset button or power-cycle. In all cases it will reload config.g discarding all changes made since the last start.
                        Manuel
                        My Tool Collection
                        • Shaunundefined
                          Shaun @wilriker
                          @wilriker Thanks. Cant seem to get z to move down and trigger the endstop. I have loaded a clean config.g file. Its as if a setting is telling z to stop when i gets to 0 which isnt the high of the endstop.
                            Can you explain what you mean by that?
