    Cura 4.2.1 Config help
    40
    2.4k
      droftarts administrators
      @Shaun This gcode should only be 10mm high, but your axis looks like it has moved a lot further than that.
      Can you send these commands and report the output from the console: M92 and M350
      This should report the steps per mm and microstepping in use.
      Can you also post your current config.g and, because there's an M501 at the end, your current config-override.g
      Measuring how far a Z movement of 10mm moves the axis might be helpful too, as well as a picture of your Z rod with a ruler next to it for scale.
      Shaunundefined 1 Reply Last reply Reply Quote 0
      • Shaunundefined
        Shaun @droftarts
        @droftarts said in Cura 4.2.1 Config help:
        M350
        ; generated by RepRapFirmware Configuration Tool v2.0.3 on Fri Sep 13 2019 19:45:33 GMT+0100 (British Summer Time)
        M550 P"CR10" ; set printer name
        M552 S1 ; enable network
        M586 P0 S1 ; enable HTTP
        M586 P1 S0 ; disable FTP
        M586 P2 S0 ; disable Telnet
        M92 X80.00 Y80.00 Z4000.00 E1222.00 ; set steps per mm
        M566 X900.00 Y900.00 Z6.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
        M201 X500.00 Y500.00 Z10.00 E250.00 ; set accelerations (mm/s^2)
        M906 X950 Y950 Z950 E950 I30 ; set motor currents (mA) and motor idle factor in per cent
        M84 S30 ; Set idle timeout
        M208 X280 Y280 Z350 S0 ; set axis maxima
        ;M557 X10:280 Y35:270 S12.6 ; Define mesh grid for full bed print
        ;G31 X-43.2 Y31.9 Z2.132 P25
        M574 X1 Y1 Z1 S1 ; set active high endstops
        ;M558 P5 X0 Y0 Z1 H7 F500 T4000 ; Set Z Probe to type Switch or Digital output where Z probe connector is used
        ;M31 P25 X0 Y0 Z1 ; Set Z probe trigger value, offset and trigger height
        ;M574 Z1 S2 ; set endstops controlled by probe
        M307 H7 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
        M558 P5 H1 F500 T5000 ; set Z probe type to bltouch and the dive height + speeds
        G31 P25 X8.5 Y-50 Z0.38 ; set Z probe trigger value, offset and trigger height
        M557 X5:205 Y5:205 S10 ; define mesh grid
        M143 H1 S260 ; set temperature limit for heater 1 to 260C
        ;Disable Heater to free up PWM channel
        M307 H7 A-1 C-1 D-1 ; disable heater for BLTouch
        M106 P0 S1 I0 F500 H1 T45 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
        M106 P1 S1 I0 F500 H1 T150 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
        M501
        10:29:39 AMM92
        Steps/mm: X: 80.000, Y: 80.000, Z: 4000.000, E: 1222.000
        M350
        ; config-override.g file generated in response to M500 at 2019-09-13 22:58
        ; Heater model parameters
        M307 H0 A87.8 C796.7 D0.7 S1.00 V12.1 B0
        M307 H1 A419.9 C136.9 D4.1 S1.00 V11.9 B0
        M307 H2 A340.0 C140.0 D5.5 S1.00 V0.0 B0
        M307 H3 A340.0 C140.0 D5.5 S1.00 V0.0 B0
        M307 H4 A340.0 C140.0 D5.5 S1.00 V0.0 B0
        M307 H5 A340.0 C140.0 D5.5 S1.00 V0.0 B0
        M307 H6 A340.0 C140.0 D5.5 S1.00 V0.0 B0
        ;M307 H7 A340.0 C140.0 D5.5 S1.00 V0.0 B0
        G10 L2 P1 X0.00 Y0.00 Z0.00
        G10 L2 P2 X0.00 Y0.00 Z0.00
        G10 L2 P3 X0.00 Y0.00 Z0.00
        G10 L2 P4 X0.00 Y0.00 Z0.00
        G10 L2 P5 X0.00 Y0.00 Z0.00
        G10 L2 P6 X0.00 Y0.00 Z0.00
        G10 L2 P7 X0.00 Y0.00 Z0.00
        G10 L2 P8 X0.00 Y0.00 Z0.00
        G10 L2 P9 X0.00 Y0.00 Z0.00
        Microstepping - X:16(on), Y:16(on), Z:16(on), E:16(on)
        I have checked and when i send a +5 Z moves 5cm up.
        Phaedruxundefined 2 Replies Last reply Reply Quote 0
          Phaedrux Moderator @Shaun
          @Shaun said in Cura 4.2.1 Config help:
          Z4000 for the steps per mm is probably an order of magnitude too high for a CR-10. Z400 is likely the correct value.
            Z+5 should only move 5mm.
            • Shaunundefined
              Shaun
              morning
              I have checked every measurement now. movement is exact. Layer 1 still seems to be 2mm above.
              • wilrikerundefined
                wilriker @Shaun
                @Shaun Can you please post the contents of your homing files then?
                Manuel
                My Tool Collection
                • Shaunundefined
                  Shaun @wilriker
                  @wilriker said in Cura 4.2.1 Config help:
                  ; homex.g
                  ; called to home the X axis
                  G91 ; relative positioning
                  G1 Z2.5 F6000 S2 ; lift Z relative to current position
                  G1 S1 X-305 F1800 ; move quickly to X axis endstop and stop there (first pass)
                  G1 X5 F6000 ; go back a few mm
                  G1 S1 X-305 F360 ; move slowly to X axis endstop once more (second pass)
                  G1 Z-2.5 F6000 S2 ; lower Z again
                  G90 ; absolute positioning
                  ; homey.g
                  ; called to home the Y axis
                  G1 S1 Y-305 F1800 ; move quickly to Y axis endstop and stop there (first pass)
                  G1 Y5 F6000 ; go back a few mm
                  G1 S1 Y-305 F360 ; move slowly to Y axis endstop once more (second pass)
                  ; homez.g
                  ; called to home the Z axis
                  ;G1 Z2.5 F6000 S2 ; lift Z relative to current position
                  G1 S1 Z-405 F1800 ; move Z down until the endstop is triggered
                  G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
                  G1 S2 Z15 F100 ; lift Z relative to current position
                  ; homeall.g
                  ; called to home all axes
                  G1 S1 X-305 Y-305 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
                  G1 S1 X-305 Y-305 F360 ; move slowly to X and Y axis endstops once more (second pass)
                  G1 S1 Z-405 F1800 ; move Z down stopping at the endstop
                  G92 Z0 ; set Z to axis minimum (you may want to adjust this)
                    Your homing files are configured for endstop switch homing and now Z probe homing.
                    https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCartesianPrinter#Section_Homing_Z_using_a_Z_probe
                    Instead of this:
                    You need a G30 command to probe the bed.
                    And your BLTouch command should be updated to this:
                    M558 P9 H5 F100 T5000 R0.5
                    And I assume you've gone through this?
                    https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
                    • Shaunundefined
                      Shaun @Phaedrux
                      @Phaedrux said in Cura 4.2.1 Config help:
                      Instead of this:
                      Thanks for the feedback, think i figured it all out shortly after updating this.
                      I want to use my endstop and not the probe which seems to be working just fine.
                      my issue was that i dont think i hat the hotend touching the bed before starting the calibration. |The result was an offset of 2. i printed the golf marker in rough and super fine without any issues. Will move onto something bigger and update tomorrow.
                      • Shaunundefined
                        Shaun
                        OK found the following which could be contributing to my problems..
                        When i "Home All" Z doesnt stop by hitting the endstop. it doesnt even trigger the endstop. When i "Home Z" the endstop is hit and triggered.
                        ; homeall.g
                        G1 S1 X-305 Y-305 F2000 ; move quickly to X and Y axis endstops and stop there (first pass)
                        G1 S1 Z-405 F2000 ; move Z down stopping at the endstop
                        G1 S2 Z0 F500 ; lift Z relative to current position
                        ; homez.g
                        • Shaunundefined
                          Shaun
                          Silly question, how do i clear any settings saved to the board memory? Ive made so many changes and think starting from 0 would be a good idea.
                          • wilrikerundefined
                            wilriker @Shaun
                            @Shaun Either run M999, push the reset button or power-cycle. In all cases it will reload config.g discarding all changes made since the last start.
                            Manuel
                            My Tool Collection
                            • Shaunundefined
                              Shaun @wilriker
                              @wilriker Thanks. Cant seem to get z to move down and trigger the endstop. I have loaded a clean config.g file. Its as if a setting is telling z to stop when i gets to 0 which isnt the high of the endstop.
                                Can you explain what you mean by that?
