Original Hypercube. Flawed?
Hi all,
What's the general opinion on the original Hypercube? It's not what I would build by choice, but may have found a cheap bundle of parts for one.
Comparison to the P3Steels/prusa/other ned slingers?
Regards,
Wesley.
the parts of the original hypercube are close to the blv cube. which is in my opinion the better one.
i prefer the corexy mechanic to Cartesian, because you have no moving bed.
what makes the biggest difference in my opinion are rails. -
The bed slingers always made nervous. For a small (<150mm) square bed I guess it's OK but I don't see how at reasonable speeds the printer just doesn't fly off the table with all that mass to shove around. They're also hard to enclose if you need to. Personally, I like the cubes.
CoreXY is interesting and I've built a modified version of Hypercube Evolution. I'm curious if a Delta would've been the better choice due to less axes. The rod design is just meh. Get the rails and perhaps just switch to a Delta to spare yourself redundant bed-related problems. I haven't owned a Delta, but other types must be a pain with increasing size and so "many" moving interconnected parts in comparison.
At one point I owned three mini-deltas.
I found they were rather difficult to get the same level of performance as my FT-5 & DBOT provided.
They did work and I was able to print decent parts on the deltas but the parts from the FT-5 & DBOT were a better.
I like the elegance of deltas but did not achieve the speed advantages that they are supposed to offer.
Other folks love them.
@fcwilt said in Original Hypercube. Flawed?:
Very hard to get speed with mini deltas. Big deltas excel at this. In fact almost all high-speed industrial pick/place (where the engineers could pick any kinematic they wish, to achieve speed) are delta.
Also, I wouldn't recommend a delta with anything that has to be attached/detached to probe Z. Smareffector is best, retracting probes or IR or Inductance are OK-ish. The point being: One of the keys to enjoyable delta printing is to run a simple calibration within the start gcode of every job.
Example of fast industrial Delta pick/place. Picking batteries from a semi-random belt location (via IR vision) and placing in a retail package tray. Not speeded up.
