    INITIAL HOMING BLUES
    My Duet controlled machine
    704
    • swrightlastundefined
      swrightlast
      MACHINE: FT5-R2 (COREXY)
      FIRMWARE: 2.02
      BOARD: DUET WIFI
      CAN'T SEEM TO GET THE PRINTER TO HOME CORRECTLY FOR X OR Y.
      LOOKING FROM THE FRONT, HOME SHOULD BE AT RIGHT REAR. HOW SHOULD CONFIG.G LOOK? ADDITIONALLY, DO I NEED TO DO ANYTHING IN HOMEX,Y OR HOMEALL?
      FINALLY, ARE THERE ANY SPECIFIC INSTRUCTIONS FOR HOMING INITIALLY, AND OR TESTING THE HOMING? I JUST DON'T UNDERSTAND THE COMMANDS AND WHAT CHANGING PART OR ALL OF A PARTICULAR LINE DOES.
      • Danalundefined
        Danal
        First, all caps on the internet is considered shouting and is considered to be rude.
        Home at right rear, this is where the limit switches are located, correct?
        The steppers need to move so that -x is to the right, and -y is to the rear. Same thing phrased another way: Positive moves in X and Y need to move away from the limit switches.
        Specific instructions for first home:
        • First, test each switch with your finger. The light on the board where that individual limit switch is plugged in should change, and the status in the DWC (Duet Web Control) should also change.
        • Second, when you start a home, be instantly ready to power the machine off if it moves the wrong way, etc. Literally one hand on the mouse and the other on the power switch (or cord).
        • When you do the first home, long before a given axis reaches its switch, press that switch with your finger and be sure that axis stops.
        If any of the above are not true (switches in wrong place, lights/status not changing, carriage moving wrong way, carriage not stopping when switch is triggered), tell us which specific one you are trying, and we'll go from there.
        If the all work.... then the machine should home.
        swrightlastundefined 2 Replies Last reply Reply Quote 0
        • Danalundefined
          Danal
          Also, see: https://duet3d.dozuki.com/Wiki/Connecting_endstop_switches
          Particularly the "Testing endstop switches" topic.
          • Danalundefined
            Danal
            And... last... why right rear origin? You do realize that "standing in front of the bed" that makes all the coordinates "backwards" to your point of view? X will increase to the right (backwards from western language convention). Y will increase towards you (again, backwards to the way almost all people think, and all documents are written, for X/Y coordinate systems).
            This won't matter to the printer or the object being printed... it will be confusing to humans looking at the printer.
            It is much more common for square beds to origin in the lower left, because this makes all the coordinates "normal". Llke reading a book. The coordinates maps to the cartesian plane positive coordinate quadrant. Etc. Etc.
            • fcwiltundefined
              fcwilt @swrightlast
              @swrightlast
              Is the right-rear at X max and Y max?
              Once we know that we can proceed.
              A axis is considered homed once some command specifies the current position of that axis.
              Just executing the command G92 X0 Y0 Z0 will mark all axes homed and set their current position to 0 even though the actual positions could be anything.
              The normal way of homing a axis is to execute a relative G0 command with the H1 parameter.
              The axis parameter (X,Y,Z) determines which axis is being homed and the distance to move to reach the endstop switch.
              The H1 parameter specifies that when the endstop switch is triggered the movement stops and the current position is set to the min or max value specified in M208 for that axis. The configuration of the endstop specifies if it is located at the min or max end of the axis and determines if the min or max value from M208 is used.
              For example (as a bare minimum):
              G92 ; specifies a relative move
              G0 X999 H1 ; move X up to 999mm in the positive direction until the endstop switch is triggered
              Normally homing is a multiple step process:
              G92
              G0 X999 F1000 H1 ; the first move is done at a high speed (F1000) to save time
              G0 X-10 F1000 ; then we back off a small amount
              G0 X11 F100 H1 ; the second move is done at a low speed (F100) which may improve accuracy
              Is that enough to get you started?
                swrightlast @Danal
                @Danal , sorry for the all caps...just a brainfart....certainly didn't mean any rudeness or disrespect.
                • fcwiltundefined
                  fcwilt
                  I just noticed that you listed your machine as a FT5-R2 (COREXY).
                  If you mean a FolgerTech FT5-R2 have you modified it to be a CoreXY machine?
                  A normal FT5 is a Cartesian machine.
                  swrightlastundefined 1 Reply Last reply Reply Quote 0
                  • fcwiltundefined
                    fcwilt @Danal
                    @Danal said in INITIAL HOMING BLUES:
                    I don't think he meant the origin was in the right-rear.
                    I think he is talking about the location of the endstop switches, which on a stock FT-5 are at the axis maxima.
                    swrightlastundefined 1 Reply Last reply Reply Quote 1
                      swrightlast @fcwilt
                      @fcwilt said in INITIAL HOMING BLUES:
                      location of the endstop switches, on a stock FT-5 are at the axis minimum (0,o.0)
                        swrightlast @fcwilt
                        @fcwilt FolgerTech FT5-R2 modified it to be a CoreXY machine. It's in corexy mode in wdc.
                        • weed2allundefined
                          weed2all
                          I always thought that the corexy homing position is front left...that is how I set mine..
                          https://www.thingiverse.com/weed2all/designs
                          • fcwiltundefined
                            fcwilt @swrightlast
                            @swrightlast said in INITIAL HOMING BLUES:
                            Not on mine.
                            I wonder if they made a change.
                            But to be sure we are on the same page, 0,0 is the left front corner, correct?
                              swrightlast @Danal
                              @Danal home is at right rear, looking from front of printer. Homing x, it moves along the y axis, toward the front of printer. By the way, all endstops work when triggered, and show it to be so in wdc.
                                swrightlast @fcwilt
                                @fcwilt I have, and always have had home at 0,0,0. For me that is right rear. Ft5-r2 has always had it home to right rear.
                                • fcwiltundefined
                                  fcwilt @swrightlast
                                  @swrightlast
                                  Where a printer homes is not tied to where 0,0 is.
                                  On my FT-5, facing the machine, the X axis endstop is on the right, the Y axis endstop is at the rear.
                                  In most cases you want these to be the axis maxima.
                                  This allows 0,0 to at the left-front corner of the bed, which is quite common though some folks (like me) prefer to have 0,0 be at the center of the bed.
                                  So don't assume that the endstop switch locations automatically define position 0,0.
                                    Slicers use a right hand coordinate system, with 0,0,0 being front left. Y+ extends back from there, X+ goes to the right, and Z+ goes up. Setting up the firmware to use the same coordinates makes sure your parts come out oriented the same way as they are shown in the slicer and not rotated or worse, mirrored.
                                    The endstop positions can be at the low end (near the 0 points) or they can be at the high end (near the opposite end of 0). That's controlled by the endstop definition and the direction of homing moves in the homing macros.
                                    https://duet3d.dozuki.com/Wiki/Gcode#Section_M574_Set_endstop_configuration
                                    Additionally, motor direction for coreXY printers is important.
                                    https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCoreXYPrinter
                                    Note the movement section to check for proper motor directionality. Also note the examples of the homing files.
                                    This is an excellent write up as well. https://drmrehorst.blogspot.com/2017/08/setting-up-3d-printers-origin.html
                                    So just to reiterate, the 0,0,0 point should be at the front left of the printer. Where the printer homes to is completely independent.
                                    If you post your config.g and homing files we can suggest what to change. But we will need to ensure first that your motor directions are correct. Then it's just a matter of setting the correct endstop position in config.g and setting the correct movement direction in the homing files.
                                    swrightlastundefined 3 Replies Last reply Reply Quote 1
                                      swrightlast @fcwilt
                                      On my FT-5, facing the machine, the X axis endstop is on the right, the Y axis is at the rear.
                                      On my FT-5, facing the machine, the X axis endstop is on the right, the Y axis is at the rear. I said home right rear, 0,0 because thats what my gridded bed shows, with front right, 0,300, and front left 300, 300.
                                      swrightlastundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                                        swrightlast @Phaedrux
                                        @P; Configuration file for Duet WiFi (firmware version 2.03)
                                        ; generated by RepRapFirmware Configuration Tool v2.0.4 on Mon Sep 16 2019 10:02:48 GMT-0700 (Pacific Daylight Time)
                                        M550 P"My Printer" ; set printer name
                                        M667 S1 ; select CoreXY mode
                                        M552 S1 ; enable network
                                        M586 P0 S1 ; enable HTTP
                                        M586 P1 S0 ; disable FTP
                                        M586 P2 S0 ; disable Telnet
                                        M350 X64 Y64 Z64 E32 I1 ; configure microstepping with interpolation
                                        M92 X80.00 Y80.00 Z4000.00 E412.53 ; set steps per mm
                                        M84 S30 ; Set idle timeout
                                        M208 X0 Y0 Z0 S0 ; set axis minima
                                        M208 X300 Y300 Z380 S0 ; set axis maxima
                                        M574 X1 Y1 Z0 S0 ; set active low endstops
                                        M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
                                        M106 P1 S1 I0 F500 H-1 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
                                        haedrux ; Configuration file for Duet WiFi (firmware version 2.03)
                                          ; homex.g
                                          ; called to home the X axis
                                          ; generated by RepRapFirmware Configuration Tool v2 on Sun Aug 25 2019 14:27:06 GMT-0700 (Pacific Daylight Time)
                                          G91 ; relative positioning
                                          G1 S1 X-305 F1800 ; move quickly to X axis endstop and stop there (first pass)
                                          G1 X5 F6000 ; go back a few mm
                                          G1 S1 X-305 F360 ; move slowly to X axis endstop once more (second pass)
                                          G1 Z-5 F6000 S2 ; lower Z again
                                          G90 ; absolute positioning
                                          Phaedrux ; homex.g
                                            ; homex.g
                                            @Phaedrux ; homey.g
                                            ; called to home the Y axis
                                            G1 S1 Y-305 F1800 ; move quickly to Y axis endstop and stop there (first pass)
                                            G1 Y5 F6000 ; go back a few mm
                                            G1 S1 Y-305 F360 ; move slowly to Y axis endstop once more (second pass)
