INITIAL HOMING BLUES
My Duet controlled machine
703
    swrightlast @fcwilt
    @fcwilt FolgerTech FT5-R2 modified it to be a CoreXY machine. It's in corexy mode in wdc.
      weed2all
      I always thought that the corexy homing position is front left...that is how I set mine..
      https://www.thingiverse.com/weed2all/designs
        fcwilt @swrightlast
        @swrightlast said in INITIAL HOMING BLUES:
        @fcwilt said in INITIAL HOMING BLUES:
        location of the endstop switches, on a stock FT-5 are at the axis minimum (0,o.0)
        Not on mine.
        I wonder if they made a change.
        But to be sure we are on the same page, 0,0 is the left front corner, correct?
        undefined 1 Reply Last reply 9 Oct 2019, 03:26 Reply Quote 0
          swrightlast @Danal
          @Danal home is at right rear, looking from front of printer. Homing x, it moves along the y axis, toward the front of printer. By the way, all endstops work when triggered, and show it to be so in wdc.
            swrightlast @fcwilt
            @fcwilt I have, and always have had home at 0,0,0. For me that is right rear. Ft5-r2 has always had it home to right rear.
            undefined 1 Reply Last reply 9 Oct 2019, 03:37 Reply Quote 0
              fcwilt @swrightlast
              @swrightlast
              Where a printer homes is not tied to where 0,0 is.
              On my FT-5, facing the machine, the X axis endstop is on the right, the Y axis endstop is at the rear.
              In most cases you want these to be the axis maxima.
              This allows 0,0 to at the left-front corner of the bed, which is quite common though some folks (like me) prefer to have 0,0 be at the center of the bed.
              So don't assume that the endstop switch locations automatically define position 0,0.
              undefined 1 Reply Last reply 9 Oct 2019, 03:51 Reply Quote 0
                Slicers use a right hand coordinate system, with 0,0,0 being front left. Y+ extends back from there, X+ goes to the right, and Z+ goes up. Setting up the firmware to use the same coordinates makes sure your parts come out oriented the same way as they are shown in the slicer and not rotated or worse, mirrored.
                The endstop positions can be at the low end (near the 0 points) or they can be at the high end (near the opposite end of 0). That's controlled by the endstop definition and the direction of homing moves in the homing macros.
                https://duet3d.dozuki.com/Wiki/Gcode#Section_M574_Set_endstop_configuration
                Additionally, motor direction for coreXY printers is important.
                https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCoreXYPrinter
                Note the movement section to check for proper motor directionality. Also note the examples of the homing files.
                This is an excellent write up as well. https://drmrehorst.blogspot.com/2017/08/setting-up-3d-printers-origin.html
                So just to reiterate, the 0,0,0 point should be at the front left of the printer. Where the printer homes to is completely independent.
                If you post your config.g and homing files we can suggest what to change. But we will need to ensure first that your motor directions are correct. Then it's just a matter of setting the correct endstop position in config.g and setting the correct movement direction in the homing files.
                undefined 3 Replies Last reply 9 Oct 2019, 03:55 Reply Quote 1
                  swrightlast @fcwilt
                  On my FT-5, facing the machine, the X axis endstop is on the right, the Y axis is at the rear.
                  On my FT-5, facing the machine, the X axis endstop is on the right, the Y axis is at the rear. I said home right rear, 0,0 because thats what my gridded bed shows, with front right, 0,300, and front left 300, 300.
                  undefined undefined 2 Replies Last reply 9 Oct 2019, 04:01 Reply Quote 0
                    swrightlast @Phaedrux
                    @P; Configuration file for Duet WiFi (firmware version 2.03)
                    ; generated by RepRapFirmware Configuration Tool v2.0.4 on Mon Sep 16 2019 10:02:48 GMT-0700 (Pacific Daylight Time)
                    M550 P"My Printer" ; set printer name
                    M667 S1 ; select CoreXY mode
                    M552 S1 ; enable network
                    M586 P0 S1 ; enable HTTP
                    M586 P1 S0 ; disable FTP
                    M586 P2 S0 ; disable Telnet
                    M350 X64 Y64 Z64 E32 I1 ; configure microstepping with interpolation
                    M92 X80.00 Y80.00 Z4000.00 E412.53 ; set steps per mm
                    M84 S30 ; Set idle timeout
                    M208 X0 Y0 Z0 S0 ; set axis minima
                    M208 X300 Y300 Z380 S0 ; set axis maxima
                    M574 X1 Y1 Z0 S0 ; set active low endstops
                    M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
                    M106 P1 S1 I0 F500 H-1 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
                    haedrux ; Configuration file for Duet WiFi (firmware version 2.03)
                    undefined 1 Reply Last reply 9 Oct 2019, 05:25 Reply Quote 0
                      ; homex.g
                      ; called to home the X axis
                      ; generated by RepRapFirmware Configuration Tool v2 on Sun Aug 25 2019 14:27:06 GMT-0700 (Pacific Daylight Time)
                      G91 ; relative positioning
                      G1 S1 X-305 F1800 ; move quickly to X axis endstop and stop there (first pass)
                      G1 X5 F6000 ; go back a few mm
                      G1 S1 X-305 F360 ; move slowly to X axis endstop once more (second pass)
                      G1 Z-5 F6000 S2 ; lower Z again
                      G90 ; absolute positioning
                      Phaedrux ; homex.g
                        ; homex.g
                        @Phaedrux ; homey.g
                        ; called to home the Y axis
                        G1 S1 Y-305 F1800 ; move quickly to Y axis endstop and stop there (first pass)
                        G1 Y5 F6000 ; go back a few mm
                        G1 S1 Y-305 F360 ; move slowly to Y axis endstop once more (second pass)
                          swrightlast @swrightlast
                          ; homey.g
                          @swrightlast ; homez.g
                          ; called to home the Z axis
                          ; generated by RepRapFirmware Configuration Tool v2 on Sun Aug 25 2019 14:27:07 GMT-0700 (Pacific Daylight Time)
                          G1 X15 Y15 F6000 ; go to first probe point
                          ;G91 ; relative positioning
                          ;G1 S2 Z5 F100 ; lift Z relative to current position
                          ;G90 ; absolute positioning
                            Phaedrux Moderator @swrightlast
                            This orientation can be maintained if you wish. Just note that parts printed will be rotated 180 degrees from the preview in the slicer. Provided of course that we get the rest of the config setup.
                            Were you able to perform this test yet?
                            For a CoreXY or H-Bot machine, RepRapFirmware assumes that the motor connected to the X motor output moves the head in the +X and +Y directions when it runs forwards, and that the Y motor moves the head in +X and -Y directions when it runs forwards. [Note: firmware 1.18 and earlier assumes that the motor connected to the Y motor output moves the head in the -X and +Y directions when it runs forwards].
                            So you can start with these M569 commands in config.g:
                            M569 P0 S0 ; X motor runs forwards
                            M569 P1 S0 ; Y motor runs forwards
                            Then test for the correct X motor movement by sending these commands from the console:
                            G91
                            G1 S2 X10 F3000
                            If the head moves diagonally in the +X and +Y directions, all is well. If it moves in the -X and -Y directions, change the S parameter to S1 in the M569 P0 command. If it moves towards +X and -Y, or towards -X and +Y, turn the power off and swap the X and Y motor connections.
                            When you have the X motor moving correctly, test the Y motor by sending from the console:
                            G91
                            G1 S2 Y10 F3000
                            For firmware 1.19 and later: If the head moves diagonally in the +X and -Y directions, all is well. If it moves in the -X and +Y directions, change the S parameter in the M569 P1 command to S1.
                            Important: make sure that you have chosen a right-hand axis system. That is, looking down on the printer the +Y direction should be 90 degrees anticlockwise from the +X direction. If instead it is 90 degrees clockwise, you have a left-hand axis system, which will give you mirror-image prints.
                              So this says that you have the endstops on the low end, which according to your bed decals is correct. And you use active low endstop switches.
                              If you wanted to change this to a right hand coordinate system with 0,0 in the front left, you'd need to change it to be M574 X2 Y2 Z0 S0 which tells it that the switches are located at the high end of travel.
                              This is correct movement direction for low end endstop position. Same for your homey commands.
                              If you wanted to change to a right hand coordinate system, the directions of the movements would have to be reversed. Ex:
                              G1 S1 X305
                              G1 X-5
                              G1 S1 X305
                              So this leaves just my previous question about testing for correct motor direction movement. The test as described above assumes a right hand coordinate system. So I'm interested to see what you report.
                              When you tell it to home X, which direction does the print head move? It should be moving to the right as it's currently configured.
                              undefined 1 Reply Last reply 9 Oct 2019, 16:13 Reply Quote 2
                                @Phaedrux When homing x, it moves toward the front in the y direction.
                                  Please do the motor direction test I posted above.
                                  19 out of 25
