    423
    98.8k
      deckingman
      Very interesting. I'm looking at possible alternatives to DCs excellent IR probe which seems to be adversely affected by 3dLac that I've started using. I must investigate further….......
      • Dougal1957undefined
        Dougal1957
        DJ am I right in saying that it uses just one piezo sensor ? and how do you resist the E3d from moving in the mount?
        Doug
        Maplins sell this one http://www.maplin.co.uk/p/3v-ceramic-piezo-transducer-2742-qy13p
        • DjDemonDundefined
          DjDemonD
          Yeah that maplin one would do the trick, the 27mm one, you need a small signal processor board to get a useful trigger signal from a piezo transducer, but Moriquendi on reprap has made some and still has a few available.
          The hotend is solid as the upper and lower parts can be fairly tightly screwed together. The design is such that any force axially up through the hot end causes a tiny flex in the piezo and you get your trigger. Is it as rigid as the hotend fastened into a metal effector with a metal groove mount adaptor - no, but its fairly firm.
          The force required to trigger it is tiny, it barely tickles the bed as it probes. Much less violent than FSR's with none of the wobbly bed that goes with it.
          www.precisionpiezo.co.uk
          • Sakeyundefined
            Sakey
            Did i read that right, your drilled the centre of the piezo sensor disk?
            • DjDemonDundefined
              DjDemonD
              Yes I drilled out a 4mm hole in the centre of the Piezo transducer.
                Piezo bimorph plate is quite tough, we used to cut circular discs out of them with a hole saw when I was building lasers. Don't let the piezo get hot when cutting or drilling it, because too much heat will destroy the piezoelectric properties.
                • DjDemonDundefined
                  DjDemonD
                  Yeah I drilled two, one with a regular twist drill on a piece of wood that one worked, the other with a diamond core drill, not so successful too much heat.
                  It is uncanny how precise the probing is though and how gently it does it.
                    T3P3Tony administrators
                    I wonder if its possible to get plates made to a custom shape.
                    • DjDemonDundefined
                      DjDemonD
                      It would be interesting if a smaller unit with hole already drilled could be made. The 27mm unit is larger than ideal packaging-wise, but works by bending so it might be hard to get the same sensitivity from a smaller disc, although it could be made thinner.
                        what would be awesome would be the ability to get them with mounting holes to screw into the top of the hotend (3x3mm m3 for example) and another set of mounting holes to screw into an effector or carriage. does anyone know how they are made?
                          Dougal1957
                          Found a 20mm Dia one at rs (they also have a 12 mm version)
                          http://uk.rs-online.com/web/p/piezo-buzzer-components/7214940/
                            Interesting to see how well the buzzer works as a sensor, do they manufacture piezo's with different properties ans actuators vs sensors?
                              Dougal1957
                              These are the Murata ones from the same range that was in the original post so should be ok But I think I will get some of the 27mm ones and have a go with this.
                              DJ did you go back to the std E3D Cooler with the 30 mm fan?
                              • DjDemonDundefined
                                DjDemonD
                                I think a slightly smaller one would work but perhaps not a 12mm, once you've cut away 4mm from the centre you will have not much piezo-electric material left to generate a trigger, and it won't bend as much. I don't think there's any feasible version without cutting a hole in the Piezo.
                                I am envisioning a unit with two pieces, one piece with the hot end on, one for mounting to the carriage/effector which slide over one another with perhaps two small bolts to connect them,with the Piezo sandwiched between. For deltas I'd build this into the effector, for cartesians/corexy the best design would be to incorporate this into the x carriage.
                                If anyone wants to pick the ball up and see how far they can run with it I'm behind them all the way. It's a promising sensor on account of it being very sensitive and nozzle based plus the Piezo disc can be fairly tightly compressed reducing the compliance of the whole assembly getting rid of the wobbly nozzle issue you get with fsr's, microswitches etc..
                                • DjDemonDundefined
                                  DjDemonD
                                  Doug, I'm using a 30mm fan e3d cooler with adjustable dual 30mm part fans that I co-designed with Jinx from reprap. http://www.thingiverse.com/thing:1692742
                                  • DjDemonDundefined
                                    DjDemonD
                                    @T3P3Tony:
                                    My understanding is that they are essentially the same thing. Some produce more voltage, a sharp tap with a tool can get 90v out of one of these things according to Mike (leadinglights) but as I have mine setup on the scope it was producing around 1.5v with a light tap.
                                      Dougal1957
                                      Have ordered a batch of discs and the board.
                                      The issue with the 30mm fans is the noise they produce wonder if a redesign of the top of one of DC's 40mm Fan mounts may be in order and attach to the effector by all 6 screws in a radial ring arrangement (Just thinking out loud)
                                      • DjDemonDundefined
                                        DjDemonD
                                        Sounds like a good idea. I find the sunon maglev 30mm fans are quiet, reliable and powerful you can get them from Farnell for around £13 each.
                                          Here's another possible configuration:
                                          1. Drill and tap the top end of an E3D heatsink with 3 small holes, probably M2.5 or possible M3. I hate groove mounts.
                                          2. Take a piezo element with the active element about 20mm diameter. Perhaps this one http://www.digikey.co.uk/product-detail/en/murata-electronics-north-america/7BB-27-4L0/490-7714-ND/4358154. Drill a central hole for the Bowden tube and collet, and 3 smaller holes around it.
                                          3. Attach the disk to the top of heatsink using 3 nylon screws, with a piece of insulation between the piezo and the heatsink. The purpose of the insulation is so that if the heater cartridge develops a short and makes the heatsink live, we don't get a short between the heater and the piezo.
                                          4. Clamp the brass surround of the piezo disc between the effector (which has a hole in it for the top of the heatsink to pass through) and a printed ring.
                                          For the electronics, I would take one of my IR sensors, remove the optical components, and feed the piezo into the analog input. Then program it to produce a nice clean pulse when it detects a shock. Piezos produce a good voltage from a very small mechanical shock if the load resistance is very high.
                                          I'd have a go at this myself, but I don't have a drill press for drilling the top of the E3D heatsink.
                                          • DjDemonDundefined
                                            DjDemonD
                                            That's a good approach and neatens the design. As long as the area of contact between the heatsink and the piezo is fairly small it will flex enough. Maybe a small washer with 4mm ID and 6-8mm OD between the heatsink and the piezo transducer. Good idea with the ir board it seems logical it would work. The board Moriquendi came up with is probably very similar to it but has two pots to adjust the sensitivity to suit various piezo discs. But as a finished product using a known and tested piezo this would be unnecessary. I'm fairly sure these boards can only be supplied in fairly small numbers at present.
                                            My only concern would be the whole hotend is suspended from the piezo unless I'm not visualising what you mean correctly. This might reintroduce the wobbly nozzle issue. My rough design doesn't look nice but it does work and the nozzle is quite firm I think I'll work on making this smaller and neater for now.
                                            Agreed re. groove mounts they are useless. The 90 deg tee I based mine on clamps the hot end hard and effectively turns a groove mount into a flat mount with m4 bolts.
