PT100 and Duet 3
It looks like you will still need a PT100 expansion board to use PT100 sensors with the Duet 3. Does the board used with the Duet Wifi work with the Duet 3?
Also how will PT100 sensors work with the Tool Expansion boards? Has that been figured out yet?
@Miasmictruth Yes, I believe the adapter still works.
With the tool board the plan is to support the PT1000 I think
@jay_s_uk said in PT100 and Duet 3:
All correct.
@dc42 Thanks for the response!
I see, does the PT1000 work better then the PT100 or is it just simpler to implement? I figure if PT100 won't be supported might as well work on switching over now. Thanks again.
PT1000 sensors can be plugged into standard thermistor ports, so no daughter board is needed to support them.
Is it possible to control a heater connected via 1LC using a PT100 connected to a Duet3 6HC w/ daughterboard?
