Bed levelling (and also print surface discussion).
Example setups and prints
20
76
14.9k
    T3P3Tony administrators
    Ian… sorry for hijacking your thread!
      bot
      I just want to chime in and say that using very thick PEI is, IMO, much superior to the thin stuff.
      I use a 3.2 mm sheet on several printers, for almost two years now. Sometimes the thicker pieces do have a bow to them, but they can be held flat easily with a clamp or simply binder clips. The thicker sheet does not at all insulate the bed too much, in terms of heat. I use a 12v 280mm PCB heater, and it can get the bed to 120 no problem (other than being at the max rating of the PCB heater). The surface temp of the PEI is about 5 degrees lower than the reading at the PCB heater, with a 3mm mirror and a 1.27mm aluminium heat spreader sandwiched between it all.
      The advantage of the thick sheet is that it does not need to be adhered to whatever makes the bed flat, it only needs to be clamped. Also, it can be sanded over and over again (when needed) to give extra print adhesion and to renew the surface texture on the surface.
      The downside is cost – but consider the savings of not having to purchase adhesive to adhere a thin sheet of PEI, as well as never having to replace it (thin sheets become damaged much more easily) I think the thicker sheets are the way to go.
      *not actually a robot
        Bot thanks, that really helpful - good point about the binder clips.
          Simspeed
          I posted an earlier reply to you comment Bot….just disappeared?? I said I appreciated hearing from someone like you with a positive experience with the thicker PEI sheet. That's encouraging...I think I'll go ahead and take a chance on a sheet for my build. Thanks....TP.
          Custom C-Beam H-Bot - Hard mount 560mm x 800mm MIC 6 bed plate - 3mm PEI print surface- 120v mains silicone bed heater (3 zones) - 800mm Z axis - polycarbonate enclosure - (4) .09° Nema 23s (Z) - .09° Nema 17s (XY) - Bondtech extruders - E3D Cyclops hotend, 24V power supply
            deckingman
            I'm wondering what PrintBite actually is. I'd sort of assumed that it was PEI stuck to something. It has a very fine texture to it - like very finely etched parallel lines. so maybe it isn't. Whatever it is, my measurements tell me that there is 13 deg C temperature difference between the top surface and the bed, whereas with plain glass the temperature difference is around 2 deg C so from that I deduced that the PrintBite was insulating by 11 deg C. So in theory, if I run the bed at 70 deg C instead of 50, it should work (for PLA). I wonder if I just got unlucky and it's a bad batch? I got mine on 8th November 2016 and it was the first a new batch. Did anyone buy any at around that time or after, and if so, does it work?
              DjDemonD
              I got a tiny piece for my micro delta just 100mm diameter, probably around early December which is the best piece I've had so far, abs stays bonded down to 56 deg C. My large sheet on the kossel Xl releases abs at about 85 deg C.
              As for what it's made of it has a sort of fibreglass like texture and weave. But I don't know what it's made from.
              You do need to be achieving 60 on top of the printbite for pla and 110 for abs which I find is 70 or 120 set temp.
              www.precisionpiezo.co.uk
                Dougal1957
                The stuff I have is an early one that came without any backing adhesive or grid marking's on it?
                Mine is attached directly to my Ecocast plate and just works.
                @simspeed do you have a link to that Chinese PEI Supplier please?
                Doug
                  bot
                  PrintBite seems to be a type of G-10/FR-4 sheet, allegedly with a treatment done to it. I think it is simply an off-the-shelf G-10 sheet with branding applied and price marked up.
                    deckingman
                    Well I don't know I'm sure. I dug out my piece of glass with PrintBite on it. Gave it a clean with soapy water as recommended. Heated the bed to 85 deg C, checked the temperature on the surface and it was at 71 as measured with a thermocouple stuck on with 3 layers of Kapton tape. Tried printing something with PLA - nothing - zilch - nada - might as well have been trying to print ice. All I've got is another birds nest. SO I wacked the hot end up from 195 to 225 (no print cooling fan). Cleaned the PrintBite again - this time with Acetone. Dropped Z homing by another 0.1mm. Tried again. The only difference was that this time it was a wider, flatter string of filament that didn't stick. For whatever reason, this stuff just isn't going to work for me.
                    However, one useful thing has come out of this exercise. I've found how to remove it from the glass is you need to. You just need to pry up a corner with a strong flat blade being careful not to bend it too far (I used a gasket scraper). Once you have a little gap, pour Acetone into it - this dissolves the adhesive. Continue widening the gap and pouring in more Acetone and voila! I now have another piece of glass that I can use for testing something else (or at least I will have when I get the rest of the adhesive off).
                      Simspeed
                      @Dougal1957:
                      @simspeed do you have a link to that Chinese PEI Supplier please?Doug
                      Hi Doug….here is the link. Address your comments to Cun Zhang and mention me (Terry Peterson) if you don't mind. They quoted me $106 for a 560mm X 773 x 3mm sheet of PEI 1000. I am revising the size to 803mm long for repricing so I'm sure it will be a little more. I plan to place my order when the repricing hits my inbox. Best of luck...
                      https://gz-ideal.en.alibaba.com/product/60489979785-213203887/Transparent_Ultem_PEI_Sheet_25mm.html?spm=a2700.7803228.1998738836.186.EXHxWd
                        bot
                        Nice price on a piece that size. I've never tried a piece larger than a 280 mm octagon (measured from edge to edge) with just clamping, so if the piece comes with a natural bow you may have to fasten/adhere it in some fashion.
                          Dougal1957
                          @ Simspeed
                          Thanks for the Link now what is interesting is that they start at 1mm thick and go up to 100mm but they also do it in Black now don't know if that will impact on how it performs as a print surface or not?
                          also std size of 500x500 is interesting and even 1000x1000.
                          I will drop an enquiry in a little later and see what comes back?
                          Doug
                            The black one would probably be ideal to use with the IR sensor.
                              Dougal1957
                              That's what I was thinking David.
                                deckingman
                                Doug,
                                Did your PrintBite without adhesive have a top surface and bottom surface? i.e. did it matter which side you applied the adhesive? Just wondering if mine was supplied with the adhesive applied to the wrong surface.
                                P.S. If anyone want a 400mm x 400mm sheet of PrintBite it's going free for collection. You'd need to get the sticky goo off the back but otherwise it's intact. PM me if interested but I'm not willing to post it - it'd have to be collected from just south of Northampton UK.
                                  Dougal1957
                                  @deckingman:
                                  Doug,
                                  No it was the same both sides?
                                    deckingman
                                    @Dougal1957:
                                    That blows that theory then….......
                                      lignumaqua
                                      Just to add my vote for using thicker sheet PEI. I use 2mm PEI on one printer and 3mm on another. Both perform beautifully for all the reasons bot posts above. I hate that thin 3M tape and always had issues with it. Now I don’t use it at all, and instead clip the thick PEI sheet directly on top of a glass plate.
                                      The PEI sheet tends to have a natural bow in one direction, probably related to the manufacturing process. Making sure the bow is facing downwards on the bed so that contact is first made in the center means that clipping the edges flattens it out very nicely.
                                      Yes, it cost more to begin with but I'm getting much better life and consistency out of it than I did with the thin PEI film. I've re-sanded the surface a couple of times but still have a long way to go!
                                      I use a DC42 IR sensor on one machine, and that one I've sprayed the PEI black on the back. No problems.
                                        bot
                                        Glad to hear the experience is consistent. Can I ask the size of bed you're using? I'm planning on going to a 300 mm square instead of 280 mm octagon, and I'm wondering it the extreme corners will be a bit wavy. Any experience?
                                        My wife has a lulzbot mini with the thin PEI sheets, and they get destroyed pretty easily compared to the thick sheets I run. I can crash my head into the bed, full force, and drag it around for a bit with not much damage done – marks can be sanded away. (Not that I ever crash the head into the bed... ahem... :P)
                                          deckingman
                                          @bot:
                                          …............. Can I ask the size of bed you're using? I'm planning on going to a 300 mm square instead of 280 mm octagon, and I'm wondering it the extreme corners will be a bit wavy. Any experience? ...........................
                                          I'd be interested to know that too as my bed is 400mm x 400mm. So I'm a bit worried about this "bowing" that people mention.
                                          40 out of 76
