Solved Reset button stiff and slow
@matej101 no that is not normal. Can you see if there is anything obviously wrong (solder stuck in, deformed, etc).
@t3p3tony no, the only thing that's different from the photos of other duets is that my switch does not have the gold sticker on the top
@T3P3Tony Can you tell me the name of the switch so I can get a new one and replace it?
@Matej101 it's a LY-A03-02A
@T3P3Tony All shops I can find have a minimum order quantity of 1000. Could I get the switch from you?
@Matej101 said in Reset button stiff and slow:
Sure ping me an email info@duet3d.com
@T3P3Tony Thanks, one more thing. Will I lose the warranty by fixing the switch myself?
@Matej101 if it's still under warranty then better to get a warranty replacement, please contact your supplier.
@T3P3Tony Thank you, I'll try that and if I can't get it resolved I'll contact you about a replacement switch.
I resolved the issue with the retailer, consider this solved. Thank you for all the assistance @T3P3Tony!
