    CoreXY movement calibration
    73
    6.8k
    • fcwiltundefined
      fcwilt @marnog
      @marnog
      And the position of the flat spots remains the same?
      marnogundefined 1 Reply Last reply Reply Quote 0
      • marnogundefined
        marnog @fcwilt
        @fcwilt said in CoreXY movement calibration:
        Always at the MAX Y and MIN Y of the circles.
        • antlestxpundefined
          antlestxp
          Maybe I missed it somewhere but how do your squares print. Have you printed some sort of calibration square both aligned with your axis and one at 45 degrees from x/y?
          • marnogundefined
            marnog @antlestxp
            @antlestxp I printed an octagon with a diameter of 140mm. This gives me an object with 140mm in X, Y, A, and B. With the most recent ones that I have printed I got the following run-out / deviation over 140mm:
            A (diagonal): +0.015
            B (diagonal): +0.011
            X: +0.121
            Y: -0.177
            • Vetiundefined
              Veti
              can you scale it down to 50% to see if the deviation stay constant or scale down as well.
              marnogundefined 2 Replies Last reply Reply Quote 0
              • marnogundefined
                marnog @Veti
                @Veti said in CoreXY movement calibration:
                I'll give it a try. I hope that I can get accurate measurements. The smallest deviation is 0.011mm. Differences on that scale would result in large jumps in percentages. I'll try, and report back.
                • marnogundefined
                  marnog
                  I am no photographer. Below are 2 of my own prints: 20mm diameter cylinders. Both printed in an anti-clockwise direction. On the left is the cylinder printed in vase mode (spiralized outer contour), and on the right is the cylinder printed in sequential 0.2mm layers. Unfortunately I cannot get a photo that looks like what I see. Hopefully you can see the flat spots and eliptical deformation that I'm referring to.
                  • fcwiltundefined
                    fcwilt
                    Do those non-standard rails have any side-to-side play?
                    • Vetiundefined
                      Veti
                      they must have otherwise they would not be able to slide as no ball bearings are involved.
                      • fcwiltundefined
                        fcwilt @Veti
                        Enough to create the apparent backlash that seems to be the source of the problem?
                        • Vetiundefined
                          Veti
                          that is the question.
                          i just want to see if the backlash stays the same on the smaller print.
                          0.1mm is a movement you will be hard time identifying by inspection.
                          maybe disconnect the x carriage on one side and measure the angle you can twist the carriage in either direction.
                          • DaBitundefined
                            DaBit
                            Maybe put this in a gcode file:
                            G28
                            G90 G1 X100 Y100 Z1 F6000
                            G91 F30
                            G1 Y0.1
                            G1 Y-0.1
                            G1 Y0.1
                            G1 Y-0.1
                            (Repeat the above sequence many, many times)
                            G1 Y0.1
                            G1 Y-0.1
                            M30
                            And watch everything mechanical carefully.
                            • marnogundefined
                              marnog @fcwilt
                              They do, by which I mean they must. But not noticeable. And then @Veti said in CoreXY movement calibration:
                              Do you think that play in the X direction would cause the defect and run-out / deviation in the Y direction? I would like to think that the CoreXY configuration would keep that kind of play in check. I printed my "calibration octagon" at 50% scale. I'll measure it and report back.
                              @DaBit said in CoreXY movement calibration:
                              @DaBit I'm going to try this, and also in the X direction to see what it does. See if there is as much noticeable play in the X direction.
                              • fcwiltundefined
                                fcwilt @marnog
                                @marnog said in CoreXY movement calibration:
                                ... I would like to think that the CoreXY configuration would keep that kind of play in check.
                                There are several discussions of the pros and cons of CoreXY machines. You may want to search them out.
                                • marnogundefined
                                  marnog @Veti
                                  And here I have the (embarrassing) results:
                                  Run-out / deviation over 140mm:
                                  X: +0.121
                                  Y: -0.177
                                  Run-out / deviation over 70mm (50% scale):
                                  A (diagonal): -0.273 = (model scale: 49.800% / deviation scale: -1764.655%)
                                  B (diagonal): +0.326 = (model scale: 50.229% / deviation scale: 2840.116%)
                                  X: +0.071 = (model scale: 50.008% / deviation scale: 58.866%)
                                  Y: -0.488 = (model scale: 49.715% / deviation scale: 275.546%)
                                  The same model (just scaled to 50%), the same print settings, and the same filament.
                                  Next I'm clamping a dialgauge to the X axis measuring on the frame, and running @DaBit's GCode to see if I can measure any play/slop/backlash in the X axis that might be as a result of the Y axis linear guides.
                                  (To be honest, at this stage I'm feeling like just throwing money at the problem and replacing the Igus rails with Hiwin rails. Up to now they are the only parts of the printer that I am not completely confident in, and I have no idea what else it could be.)
                                  • DaBitundefined
                                    DaBit
                                    Measure twice, cut once. Also valid for these kind of issues; I would think twice before just replacing the rails and hoping for the best. I am not using that much Igus stuff so not an expert, but so far their stuff has been performing well.
                                    If there is slop in the Igus rails you should be able to measure that, especially when you have a dial gauge at your disposal. Make moves that you understand using the console or by putting motion commands in a .gcode file, and use the dial gauge and a marker pen to verify that all the components of the stage are doing what they are supposed to do.
                                    You are probably overlooking one simple small issue, so do not be smart and cut corners, but structurally measure everything there is to measure, even if you know or can safely assume that it will not cause the problem. Take notes. And if you have a friend that knows vaguely how al this is supposed to work, ask him over. A different point of view helps with walking in circles too.
                                    The beauty of engineering. All the complex things go well at first try, it is the simple issues that take ages to find and correct. Good luck!
                                    • Edgars Batnaundefined
                                      Edgars Batna
                                      It didn't occur to me at first, but just wanted to add that I also had this issue when originally trying to use igus Drylin LMXUU bearings. What you're seeing is the axes trying to overcome the standstill friction. From what I learned so far, CoreXY is very susceptible to this since play in X and Y carriages allows the axes to momentarily shear instead of moving in the desired direction.
                                      If you grab the belts on both sides with motors de-energized you should feel equal amounts of resistance while moving the belts by hand in all combinations and there should be no noticeable standstill friction when changing direction. I found that one of the symptoms that stuff is too tight is that the print head may entirely or momentarily move straight instead of diagonal when moving just one motor by hand.
                                      Needless to say, I switched to el cheapo Chinesium LMXUU and got instant results...
                                      • marnogundefined
                                        marnog @DaBit
                                        This I know all too well. Thank you very much for your input! I'm continuing to measure and compare and apply mathematics to try to understand this issue. I'm trying to overlook Occam's razor in order to understand the problem and to solve it, and not just try easy solutions hoping that it would work. Once I'm done measuring I'll report my findings.
                                        @Edgars-Batna said in CoreXY movement calibration:
                                        This is exactly what I was thinking, and what I meant by "binding". The standstill friction at the point where the linear guide changes direction, and the elastic response in the belts when the friction is overcome would explain the flat spots followed by a "sharper" change in direction which gives the circles the elliptical appearance. Just for sh!ts and giggles I'm going to apply a small amount of silicone oil to the Igus rails and slides, just to see what it does...
                                        • DaBitundefined
                                          DaBit
                                          Be careful with oils. Not sure about the Iglidur materials, but oils often cause dimensional change. Swelling usualy, but shrinkage is not uncommon too. Engine oils are often formulated with different esters and glycols to result in a net 0% change in elastomers and rigid plastics.
                                          Furthermore: the issue with silicones is that they are close to impossible to remove if you want to get rid of them.
                                          Just plain water or a chemically compatible hydrocarbon is often sufficient for testing. You know, 'slippery when wet'.
                                          • marnogundefined
                                            marnog @DaBit
                                            @DaBit I've got WD40's Specialist Silicone spray (https://www.wd40.com/products/silicone-lubricant/) that I thought of using. I use it on my micrometers, and it claims to be "Safe on metal and non-metal surfaces including rubber, plastic, and vinyl." Otherwise I could try some KY. I might have some lying around the house somewhere...
