    Add laser for duet2 wifi
    Laser Cutters
    5.0k
    • yamanundefined
      yaman @Danal
      @Danal
      here are the complete drawing between Laser ; header and the circuit
      do I need to add anything else
      EasyTargetundefined 1 Reply Last reply Reply Quote 0
      • yamanundefined
        yaman @EasyTarget
        @EasyTarget
        never mind it's only 10$ ☺
        • EasyTargetundefined
          EasyTarget @yaman
          @yaman said in Add laser for duet2 wifi:
          Looks good to me; I was going to suggest a switch but I see you have that covered.
          Disaster? The original Printeye is dying with RRF 3.5 (M208 depreciated).
          PrintPy2024 to the rescue!
          MicroPython based; with simple wiring and and no custom PCB.
          • Danalundefined
            Danal
            Looks correct, and the values given will work with a Duet (expansion) at 12V or 24V.
            As with any project, verify as much as possible with a voltmeter or o-scope, every step of the way.
            yamanundefined 1 Reply Last reply Reply Quote 2
            • yamanundefined
              yaman @Danal
              @Danal
              @EasyTarget
              OK so after some work with solder
              the circuit not work exactly but after I make little change the Laser finally work 😇 😇
              youtube for Laser Test
              https://www.youtube.com/watch?v=1KxYv2g96GY
                EasyTarget
                AhHA! a 10V pwm input. Same as mine; when I was looking at this last year I'd noted that 10V pwm/analogue seems to be a bit of a standard in the laser world. It's common in many CO2 lasers.
                • hectorundefined
                  hector
                  Something like this would work?
                  https://www.amazon.com/Voltage-0-100-Linear-Conversion-Transmitter/dp/B00U7GJDVO
                  connected to a fan or heater, take the pwm at 24v and transform it to 0-5V DC
                  yamanundefined 1 Reply Last reply Reply Quote 0
                  • yamanundefined
                    yaman @hector
                    @hector
                    thanks for you replay
                    but this circuit will not work in my case because I don't have Fan 2
                    fan 2 I use it for tool 2
                    I have heater 6 -7 with 5v PWM
                    https://forum.duet3d.com/assets/uploads/files/1570300649740-laser_cable_2.jpg
                    • Danalundefined
                      Danal
                      Sounds like that laser wants 10V in.
                      Some want 5V (TTL), some want 10V. The two versions of the circuit above will work for the respective cases.
                      yamanundefined 1 Reply Last reply Reply Quote 1
                      • yamanundefined
                        yaman @Danal
                        @Danal
                        @EasyTarget
                        @T3P3Tony
                        Thanks for your replay
                        that what I find maybe the real test will be in G code file and let the machine work for hours
                        but first I have to do some work at Firmware
                        Right now I'm at Version 2.0.0-RC2
                        so any Suggestions for good version work fine with 3dprinter and Laser ?
                        • Danalundefined
                          Danal
                          I haven't personally tried laser, so can't comment on releases.
                          I can say I've had very good results using the "latest", including release candidates.
                            EasyTarget @yaman
                            The latest release, always the latest.
                            https://github.com/dc42/RepRapFirmware/releases/latest
                            Duet makes upgrading super easy, there is no real excuse for not upgrading asap and when new releases come out. Currently it is 2.03.
                            This is especially true if doing CNC machine control, Duet3D are pushing heavily in this direction at present and related features are appearing in each new release.
                            If you want to throw caution to the wind, try the latest 2.0x Release candidate, but I would avoid the 3.0 series betas at this time for general users. Though the 3.x series will eventually bring even more CNC related feature goodness.
                            • yamanundefined
                              yaman
                              Laser Engraving picture
                              EasyTargetundefined 1 Reply Last reply Reply Quote 2
                                EasyTarget @yaman
                                @yaman COOL!, it's great when it gets working.
                                Now you have all the tuning fun you could wish for; carving and engraving is much more of a 'craft' than 3d printing, the sheer range of materials and techniques ensures that every job is a one-off. With my printers I strive for reproducibility, but for laser art I want everything to be slightly 'individual', it's part of the charm.
                                • yamanundefined
                                  yaman
                                  video for the Test
                                  • yamanundefined
                                    yaman @EasyTarget
                                    @EasyTarget
                                    thanks for your support ☺
                                    otaku521undefined 1 Reply Last reply Reply Quote 0
                                    • otaku521undefined
                                      otaku521 @yaman
                                      @yaman
                                      mind sharing your laser part of your config.g? are u running on the expansion board? I am trying to mine to work... but my laser have 2 pin 12v and 2 pin ttl... dont know how to plug this up (heater 7 pwn and gnd?)
                                      • gabbieundefined gabbie referenced this topic
