    dc 42 ir sensor problem?
    IR Height Sensor
    2.0k
    • Vetiundefined
      Veti
      @Lc1975 said in dc 42 ir sensor problem?:
      Same times works others fails...
      how does the macro fail? whats the output of the macro?
      Lc1975undefined 1 Reply Last reply Reply Quote 0
      • Lc1975undefined
        Lc1975 @Veti
        @Veti give me 20m to get home and do that macro..
        What I told until now is what happen since I bought the sensor...
        Worked 1 or 2 times... Then repeat the same process and doesn't work...
        • Lc1975undefined
          Lc1975
          03/11/2019, 15:11:59	M98 P"0:/macros/bed"
          G32 bed probe heights: -0.379 -0.377 -0.377 -0.372 -0.376 -0.378 -0.380 -0.375 -0.378 -0.379, mean -0.377, deviation from mean 0.002
          03/11/2019, 15:11:59	M292
          This is the result
          • Vetiundefined
            Veti
            -0.376
            is that at the position where you homed? it should be close to 0.
            • Lc1975undefined
              Lc1975 @Veti
              @Veti
              Yes that's the Z0
              After change to a new black card sheet..
              03/11/2019, 15:29:55	G29
              36 points probed, min error -0.364, max error 0.352, mean -0.054, deviation 0.169
              Height map saved to file heightmap.csv
              I think that this is the first time that i have made a G29 without problems....
              • Lc1975undefined
                Lc1975
                My mistake.. Thinking that problem was solved......
                Doing other Bed Leveling with G29 without touching in nothing...
                Bam.. the nozzle hits the bed and no trigger from dc42 ir
                I don't know is is normal...
                When doing the bed leveling the sensor in DWC on the "sensor" rarelly appears numbers even when the light is trigered..
                I saw maybe 3 times "1000" then almost always "0"
                Normal?
                • Vetiundefined
                  Veti
                  are you using 1000? as a trigger value? if not slow down the probing speed. if so use a lower value.
                  • Lc1975undefined
                    Lc1975 @Veti
                    @Veti
                    No...
                    I have this:
                    M558 X0 Y0 Z1 P8 H5 A2 S0.08 F200 T4000 ; enable Z probe but set dive height, probe speed and travel speed
                    G31 P500 X0 Y13 Z0.03 ; trigger the probe
                    M671 X50:250 Y60:250 S50 ; define mesh grid
                    • Vetiundefined
                      Veti
                      use P1
                      see
                      https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe
                      Mini differential IR sensor by dc42
                      Connect the VCC, GND and OUT pins of the sensor to 3.3V, GND and IN respectively on the Z probe connector, and select mode 1
                      • Lc1975undefined
                        Lc1975 @Veti
                        @Veti
                        tried P1
                        same result...
                        Just triyng to see if other results..
                        • Lc1975undefined
                          Lc1975
                          The first picture was the first probe G29
                          And here the sensor showed "0" in DWC
                          This one was after a 1h +/-
                          This one hit the bed... And the same here.. Showed "0"
                          And after reboot and move axis to the same place and manually Z0 the nozzle the sensor trigered...
                          And doing a G30...
                          Stays ok and the sensor shows "1000"
                          • Vetiundefined
                            Veti
                            have you tried the test without the glass?
                            • Lc1975undefined
                              Lc1975
                              Yes...
                              Same result...
                              Painted with mate black and no paint...
                              This moment has a black mate papper under the glass..
                              • Lc1975undefined
                                Lc1975
                                After a G30
                                I do this:
                                G30 S-1 stopped at height 0.064 mm
                                Then i use the macro that you told me to use.. And the result....
                                Hit the bed!
                                • Vetiundefined
                                  Veti
                                  does the led blink on the first and not on the second attempt?
                                  • Lc1975undefined
                                    Lc1975 @Veti
                                    @Veti
                                    wait a moment.. i made a little video with this order:
                                    G28
                                    G30
                                    G30 S-1
                                    Then the macro...
                                    And when use the macro hits the bed...
                                    Just uploading to ondrive
                                    Here is the link of video
                                    printer sensor problem
                                    As you can see the Z-Probe is always between 5 and 1000 in DWC
                                    • Lc1975undefined
                                      Lc1975
                                      G30...
                                      G30 S-1...
                                      G28..
                                      Works well...
                                      Doing G29 or a G32 or the macro
                                      The sensor won't work..
                                      Or it can work..
                                      1 in 10 times 😂
                                      Using
                                      Board: Duet Maestro 1.0
                                      Firmware: RepRapFirmware for Duet 2 Maestro 2.04RC4 (2019-10-19b1)
                                      Duet Web Control 2.0.4
                                      • Vetiundefined
                                        Veti
                                        hmm. other than a bad a crimp i have no idea.
                                        • Lc1975undefined
                                          Lc1975
                                          Almost quit from using this...
                                          Maybe reverse to marlin or quit for good this kind of hobby....
                                          • Vetiundefined
                                            Veti
                                            maybe the ir sensor is faulty. @dc42 what do you think?
