    dc 42 ir sensor problem?
    IR Height Sensor
    2.0k
    • Lc1975undefined
      Lc1975
      03/11/2019, 15:11:59	M98 P"0:/macros/bed"
      G32 bed probe heights: -0.379 -0.377 -0.377 -0.372 -0.376 -0.378 -0.380 -0.375 -0.378 -0.379, mean -0.377, deviation from mean 0.002
      03/11/2019, 15:11:59	M292
      This is the result
      • Vetiundefined
        Veti
        @Lc1975 said in dc 42 ir sensor problem?:
        -0.376
        is that at the position where you homed? it should be close to 0.
        Lc1975undefined 1 Reply Last reply Reply Quote 0
        • Lc1975undefined
          Lc1975 @Veti
          @Veti
          Yes that's the Z0
          After change to a new black card sheet..
          03/11/2019, 15:29:55	G29
          36 points probed, min error -0.364, max error 0.352, mean -0.054, deviation 0.169
          Height map saved to file heightmap.csv
          I think that this is the first time that i have made a G29 without problems....
          • Lc1975undefined
            Lc1975
            My mistake.. Thinking that problem was solved......
            Doing other Bed Leveling with G29 without touching in nothing...
            Bam.. the nozzle hits the bed and no trigger from dc42 ir
            I don't know is is normal...
            When doing the bed leveling the sensor in DWC on the "sensor" rarelly appears numbers even when the light is trigered..
            I saw maybe 3 times "1000" then almost always "0"
            Normal?
            • Vetiundefined
              Veti
              are you using 1000? as a trigger value? if not slow down the probing speed. if so use a lower value.
              • Lc1975undefined
                Lc1975 @Veti
                @Veti
                No...
                I have this:
                M558 X0 Y0 Z1 P8 H5 A2 S0.08 F200 T4000 ; enable Z probe but set dive height, probe speed and travel speed
                G31 P500 X0 Y13 Z0.03 ; trigger the probe
                M671 X50:250 Y60:250 S50 ; define mesh grid
                • Vetiundefined
                  Veti
                  use P1
                  see
                  https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe
                  Mini differential IR sensor by dc42
                  Connect the VCC, GND and OUT pins of the sensor to 3.3V, GND and IN respectively on the Z probe connector, and select mode 1
                  • Lc1975undefined
                    Lc1975 @Veti
                    @Veti
                    tried P1
                    same result...
                    Just triyng to see if other results..
                    • Lc1975undefined
                      Lc1975
                      The first picture was the first probe G29
                      And here the sensor showed "0" in DWC
                      This one was after a 1h +/-
                      This one hit the bed... And the same here.. Showed "0"
                      And after reboot and move axis to the same place and manually Z0 the nozzle the sensor trigered...
                      And doing a G30...
                      Stays ok and the sensor shows "1000"
                      • Vetiundefined
                        Veti
                        have you tried the test without the glass?
                        • Lc1975undefined
                          Lc1975
                          Yes...
                          Same result...
                          Painted with mate black and no paint...
                          This moment has a black mate papper under the glass..
                          • Lc1975undefined
                            Lc1975
                            After a G30
                            I do this:
                            G30 S-1 stopped at height 0.064 mm
                            Then i use the macro that you told me to use.. And the result....
                            Hit the bed!
                            • Vetiundefined
                              Veti
                              does the led blink on the first and not on the second attempt?
                              • Lc1975undefined
                                Lc1975 @Veti
                                @Veti
                                wait a moment.. i made a little video with this order:
                                G28
                                G30
                                G30 S-1
                                Then the macro...
                                And when use the macro hits the bed...
                                Just uploading to ondrive
                                Here is the link of video
                                printer sensor problem
                                As you can see the Z-Probe is always between 5 and 1000 in DWC
                                • Lc1975undefined
                                  Lc1975
                                  G30...
                                  G30 S-1...
                                  G28..
                                  Works well...
                                  Doing G29 or a G32 or the macro
                                  The sensor won't work..
                                  Or it can work..
                                  1 in 10 times 😂
                                  Using
                                  Board: Duet Maestro 1.0
                                  Firmware: RepRapFirmware for Duet 2 Maestro 2.04RC4 (2019-10-19b1)
                                  Duet Web Control 2.0.4
                                  • Vetiundefined
                                    Veti
                                    hmm. other than a bad a crimp i have no idea.
                                    • Lc1975undefined
                                      Lc1975
                                      Almost quit from using this...
                                      Maybe reverse to marlin or quit for good this kind of hobby....
                                      • Vetiundefined
                                        Veti
                                        maybe the ir sensor is faulty. @dc42 what do you think?
                                        • Lc1975undefined
                                          Lc1975
                                          I reduce the speed of Z to 1mm/s with cold bed and then other with 70ºC
                                          have a reading of the Z-Probe 33 times was 469 and 3 times was 539
                                          And until now.. No hiting the bed...
                                          Maybe was the speed the problem...?
                                          to:
                                          M558 X0 Y0 Z1 P1 F50 H5 R2 T4000 A2 S0.08
                                          Result:
                                          03/11/2019, 22:38:31	G29
                                          36 points probed, min error -0.285, max error 0.436, mean 0.029, deviation 0.177
                                          I think that is not very bad...
                                          • oliofundefined
                                            oliof
                                            What does the height map look like?
