M666 tower Y
are you on firmware 2.04? if not please update.
which factor calibration are you running?
whats your reason for wanting to adjust it manually?
the firmware is 2.04.
even after the G32 calibration, the Y tower is outdated by 0.5 degrees -
@Veti said in M666 tower Y:
you did not answer this question
Sorry, but I do not understand!
what do you mean? -
see
https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer
section
Setting up the bed.g file -
thanks! but I don't understand where to go to change.
I am attaching my bed.g. can you help me? -
Its the S parameter on the last command.
i take it you wan the 8 factor calibration? put S8.
i take it you wan the 8 factor calibration? put S8.so i have to replace s6 with s8 right?
sorry but it's my first experience with the duet! -
yes
8-factor: as 6-factor but also adjusts the X and Y tilt angles (M666 A and B parameters).
@Giusva said in M666 tower Y:
but at each print running the G32 t
also there is no need to run G32 every print. you save the paramters in the config.g
see the article about saving
see the article about savingok! so once changed s6 with s8 I redo the g32 and it should be ok?
