    H-Bot Endstop problem
    1.1k
    • NL61undefined
      NL61 @Veti
      @Veti
      thank you, I tried this. If I trigger x, only x is stopped
      • Vetiundefined
        Veti
        Please very that you are running 2.04. because the commands in your homing file contain statements that would not cause a stop in previous versions.
        post the output of M115
        NL61undefined 1 Reply Last reply Reply Quote 0
        • NL61undefined
          NL61 @Veti
          @Veti
          M115
          FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.04 ELECTRONICS: Duet Ethernet 1.02 or later FIRMWARE_DATE: 2019-11-01b1
            droftarts administrators
            Don't use G1 H2 ... moves in your home.g files. These make the motors move individually, which you don't want. See https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCoreXYPrinter#Section_Homing_files
            • NL61undefined
              NL61 @droftarts
              @droftarts
              Hi Ian, thanks, I tried this out already. Always the same.
              My homex looks like this now:
              G91 ; relative positioning
              G1 S2 Z5 F1800 ; lift Z relative to current position
              G1 S1 X-395 F1800 ; move quickly to X axis endstop and stop there (first pass)
              G1 S2 X5 F9000 ; go back a few mm
              G1 S1 X-395 F360 ; move slowly to X axis endstop once more (second pass)
              G1 S2 Z-5 F1800 ; lower Z again
              G90 ; absolute positioning
              • Vetiundefined
                Veti
                this looks ok.
                please verify that you are changing the files in the sys folder and not in the macro folder
                  The link to the CoreXY homing files page needs updating; better to use G1 H#..., not G1 S#..., as use of the 'S' parameter for homing is deprecated (though still works in RRF2.x); see G1.
                  You shouldn't be using H2/S2. This moves the individual motor, so the nozzle will move diagonally. Just use H1. You don't need to specify H/S on the Z moves at all, unless it's likely to be near the endstop.
                  What does it actually do during homing X? Step through the Gcode line by line (send each line via the console) and report what happens.
                    deckingman @NL61
                    @NL61 said in H-Bot Endstop problem:
                    Comments in bold.
                    G91 ; relative positioning - this is OK
                    G1 S2 Z5 F1800 ; lift Z relative to current position - this is OK too but you should use H2 here for the single Z motor
                    G1 S1 X-395 F1800 ; move quickly to X axis endstop and stop there (first pass) - this is OK but again, use H instead of S
                    G1 S2 X5 F9000 ; go back a few mm - before this move, the axis has already been homed so you don't need the S2 parameter - remove it.
                    G1 S1 X-395 F360 ; move slowly to X axis endstop once more (second pass) - this is OK.
                    G1 S2 Z-5 F1800 ; lower Z again - this should be OK but use H instead of S.
                    G90 ; absolute positioning - this Ok
                    Alternatively, you could put M564 H0 at the start of the homing file and take out all the S2 or H2 parameters. Then put M564 H1 at the end.
                    • NL61undefined
                      NL61 @deckingman
                      @deckingman
                      I changed everything as you wrote. It still crashes into the frame.
                      • Vetiundefined
                        Veti
                        can you execute the commands from deckingman in the console one by one manually
                        • NL61undefined
                          NL61 @Veti
                          @Veti
                          I did so. After G1 H1 X-395 F1800 it crashed.
                          droftartsundefined Vetiundefined 2 Replies Last reply Reply Quote 0
                            droftarts administrators @NL61
                            @NL61 Do you have a probe set up in config.g? Please post your whole config.g.
                            • NL61undefined
                              NL61 @droftarts
                              @droftarts
                              Here it is:
                              M550 P"Olli3" ; set printer name
                              M669 K1 ; switch to CoreXY mode
                              M552 S1 P172.21.163.110 ; enable network
                              M553 P255.255.255.0
                              M554 P 172.21.163.2
                              M586 P0 S1 ; enable HTTP
                              M586 P1 S0 ; disable FTP
                              M586 P2 S0 ; disable Telnet
                              M569 P1 S0 ; physical drive 1 goes forwards
                              M569 P2 S1 ; physical drive 2 goes backwards
                              M569 P3 S0 ; physical drive 3 goes forwards
                              M92 X32.00 Y32.00 Z640.00 E460.00 ; set steps per mm
                              M906 X1600 Y1600 Z500 E500 I30 ; set motor currents (mA) and motor idle factor in per cent
                              M84 S30 ; Set idle timeout
                              M208 X390 Y290 Z100 S0 ; set axis maxima
                              M574 X1 Y1 Z2 S0 ; set active high endstops
                              M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
                              M140 H-1 ; disable heated bed
                              M305 P1 T100000 B4725 C7.060000e-8 R4700 ; set thermistor + ADC parameters for heater 1
                              M911 S20 R22 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
                              • Vetiundefined
                                Veti @NL61
                                this is VERY strange.
                                if M119 says the endstop is triggered the G1 H1 command should stop when the endstop is triggered.
                                The Firmware version is the correct one.
                                  I agree, very strange. Typical causes of this type of problem would be:
                                  • Endstops pulling the input low enough to light the LED, but not low enough to register as a low input to the processor. But in that case, M119 wouldn't show the endstops as triggered when you test them.
                                  • X and Y endstop connections swapped
                                  • Axis movement incorrect (easy to do on a CoreXY machine), for example G1 H1 X-395 is actually moving the Y axis, or is moving X away from the endstop switch.
                                  • NL61undefined
                                    NL61 @dc42
                                    thanks for answering,
                                    I tried M119 serveral times for each axis, it always shows if triggered or not.
                                    the endstops are not swapped and the movement goes to the correct direction.
                                      deckingman
                                      One thing that keeps leaping out at me from the config.g file, is the steps per mm for X and Y but I don't see what this would have bearing on the end stop triggering. But with a 16 tooth pulley, 2mm pitch, and 0.9 degree motors, the value is around 80 so having the steps per mm set to 32 would imply something like a 50 tooth pulley which is pretty huge. 32 steps @16x micro stepping is 2 full steps per mm or 100 mm per motor revolution using 1.8 degree motors.
                                        dc42 administrators @NL61
                                        1. Can you confirm that the homex.g file looks exactly like the one you posted above when you open it in Duet Web Control?
                                        2. If you try to home just X (by pressing the Home X button in Duet Web Control, or by sending G28 X), does movement stop if you trigger either the X or Y homing sensors manually?
                                        Until you have homing working, you may wish to reduce the motor currents.
                                        • NL61undefined
                                          NL61 @dc42
                                          once again the homex.g file:
                                          ; homex.g
                                          ; called to home the X axis
                                          ; generated by RepRapFirmware Configuration Tool v2.1.2 on Mon Nov 11 2019 14:44:06 GMT+0100 (Mitteleuropäische Normalzeit)
                                          G1 H2 Z5 F1800 ; lift Z relative to current position
                                          G1 H1 X-395 F1800 ; move quickly to X axis endstop and stop there (first pass)
                                          G1 X5 F1800 ; go back a few mm
                                          G1 H2 Z-5 F1800 ; lower Z again
                                          I tried to home X and triggered both, X and Y Endstop. No reaction
                                            Could you try swapping your NPN sensor for a microswitch, just to check it's working correctly?
