    Stuttering and vertical lines in print
    • WillGIamundefined
      WillGIam
      Hey guys,
      after solving nearly all my other problems, I'm coming to the next - and last - one I hope. When printing bigger parts, I was getting some vertical lines in print, first I thought that would be retract, but it wasn't. When printing longer straight moves, the printer is kind of stuttering. He stops very very short and continues the line. In the picture you can see, that he is doing this only on longer lines in solid bottom layers. In the corners with short ways there is no bloob and no problem. In the solid infill you can see the same patterns (where he stuttered) as in the outlines... I tried different jerks and ACC's, I also decreased the current dramatically...
      Maybe someone can help me in here. Have a nice evening!!!IMG_20191116_180440.jpg
      This is my config.g:
      ; generated by RepRapFirmware Configuration Tool v2.0.4 on Thu Oct 17 2019 16:50:41 GMT+0200 (Mitteleuropäische Sommerzeit)
      M550 P"Soldex AM8" ; set printer name
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S1 ; enable Telnet
      M552 P10.115.111.109 ; (0 = DHCP)
      M554 P10.115.111.108 ; Gateway
      M553 P255.255.255.0 ; Netmask
      M569 P1 S0 ; physical drive 1 goes BACKWARDS
      M569 P3 S0 ; physical drive 3 goes BACKWARDS
      M569 P4 S0 ; physical drive 4 goes BACKWARDS
      M584 X0 Y1 Z2 E3:4 ; set drive mapping
      M92 X100.00 Y100.00 Z400.00 E420.00:420.00 ; set steps per mm
      M566 X2000.00 Y2000.00 Z12.00 E300.00:300.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X15000.00 Y15000.00 Z1800.00 E12000.00:12000.00 ; set maximum speeds (mm/min)
      M201 X3000.00 Y3000.00 Z200.00 E1000.00:1000.00 ; set accelerations (mm/s^2)
      M906 X700 Y700 Z1000 E1000:1000 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X220 Y230 Z230 S0 ; set axis maxima
      M574 X1 Y1 S3 ; set endstops controlled by motor stall detection
      M307 H7 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
      M558 P5 H5 F1000 T12000 X0 Y0 Z1 ; set Z probe type to bltouch and the dive height + speeds
      G31 P25 X40 Y0 Z0.983 ; set Z probe trigger value, offset and trigger height
      M557 X40:200 Y30:200 S10 ; define mesh grid
      M851 Z-0.63 ; set Z offset
      M305 P2 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 2
      M143 H2 S280 ; set temperature limit for heater 2 to 280C
      M106 P1 S0 I0 F500 H-1 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P2 S0 I0 F500 H-1 ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M563 P0 S"Extruder links" D0 H1 F0 ; define tool 0
      M563 P1 S"Extruder rechts" D1 H2 F1 ; define tool 1
      G10 P1 X18.11 Y0 Z0 ; set tool 1 axis offsets
      ; Custom settings
      M574 X2 Y1 Z0 S3
      M915 P0 S12 R0 ; Higher values reduce the sensitivity
      M915 P1 S14 R0
      M501
      T1 ; select first tool
        https://forum.duet3d.com/topic/5909/guide-for-posting-requests-for-help
        WillGIamundefined 1 Reply Last reply Reply Quote 0
        • WillGIamundefined
          WillGIam @Phaedrux
          @Phaedrux I'm sorry, forget my config.g
          Is there anything else you need for this problem?
            Are you using mesh bed compensation? If so, then your very low Z jerk value (M566) is probably causing the stuttering.
            • WillGIamundefined
              WillGIam @dc42
              @dc42 Yes I do. Got that. Great hint! Thanks a lot!!!
