Multi colour printing and multi tool printers
Hmmmm ...... interesting. I tried to sort things out during several days of experimenting but eventually gave up and reverted to single nozzle use while sorting out other things. I haven't tried since ... maybe I need to spend some more quality time knocking my head against the wall
Could it be related to me running a 0.8 mm nozzle on a Volcano heat block with an about 800 mm bowden tube?
I have also seen the marks you talk about but that is not a thing I have ever worried about.I am still trying to sort out spider hair like stringing on single colour prints. I print between 0.4 to 0.8 mm layer height and 0.8 mm layer width.
@jens55 I've had a bit of experience doing multi colour prints. Like you. I soon gave up on the idea of using multiple nozzles mounted on the same carriage, and for the same reasons as well as the amount of axis travel that this approach loses. In my experience, I'd say you have 2 options.
a) use a multi input, single output nozzle such as a diamond hot end.
b) Use a tool, changer.The latter gives you ability to print different materials as well as different colours. This is possible using a multi-input, single nozzle approach but only if the materials have fairly similar temperature requirements. e.g. one can just about "mix" PET-G and PLA but PLA and Nylon or Polycarbonate would be a no no. The former (single nozzle) approach eliminates any possibility of nozzle misalignment and negates the time taken to change tools so it's faster and arguably easier to implement.
There a couple of techniques that I have used to print multiple colours on the same layer using a Diamond hot end. One is to advance the tool change point in the gcode file so that the tool (colour change) happens earlier by an amount that is equivalent to the amount of filament that is in the mixing chamber. In the case of the Diamond hot end, that is about 5 mm of filament and I wrote a little Python script which moves the tool changes. The second approach is simply to move the nozzle away and squirt some filament into purge bucket. If it is absolutely critical that there should be no "bleeding" of colour anywhere, then a combination of both approaches works well. It's also possible to use a purge tower but in my case, I simply "draw a line" about 100mm long so the amount of waste is minimal compared to say a Prusa MMU.
Here is a video that I did nearly 3 years ago using the technique of advancing the tool change point to print a Union Jack flag (3 colours on the same layer) https://www.youtube.com/watch?v=0tPtn3urQ3g&t=1s
There is no purge of wipe and you have to look closely to spot the slight amount of "bleeding".Here is a video that I made just under 2 years ago using a "purge bucket" to print 5 colour flags using a "purge bucket". https://www.youtube.com/watch?v=zNNmZCXErYY&t=21s. Because of the purge, there is absolutely no "bleeding" between colours.
I think you oozing is most likely related to using 0.8mm nozzles. I could only suggest that when you finish with one nozzle, do a biggish retract and then wait for that nozzle to cool significantly before continuing the print with the other nozzle.
HTH
Thanks! I will do some more experimenting but it's good to know that it isn't just me having issues with this.
@jens55 said in Multi colour printing and multi tool printers:
Could it be related to me running a 0.8 mm nozzle on a Volcano heat block with an about 800 mm bowden tube?I think there are two key aspects to avoiding oozing in dual nozzle printers. The first is to use the active/standby temperature concept that RRF supports. I was printing PLA at 190 to 195C and I set the standby temperature to 150C. At 150C, PLA does not ooze significantly. The second is to use sufficient retraction of the non-printing filament. My hot ends were PTFE-lined and I was able to use 10mm retraction. The Bowden tubes were about 400mm and I think there was around 6mm retraction happening at the nozzle. All-metal hot ends are far less tolerant of large amounts of retraction.
I have all metal hotends so retraction is a bit of an issue. I think I will order some lined heat breaks to test that out.
@deckingman said in Multi colour printing and multi tool printers:
utilisez une buse à plusieurs entrées et une seule sortie telle qu'une extrémité chaude en diamant.
Hello, first of all, I wanted to salute your various work, I'm a little "the four corners of the web" and I admit that it opens my mind on my various small jobs (very modest compare to yours)!
I still have a small question. You talk about Diamond nozzle. Do you have a reference, mark to put forward, because when I do various research on the sites of sale, I find at all prices without really knowing the final quality?
Thank you !
@jens55 I've had the same experiences. In fact, I've been lightly chasing multicolor multimaterial ever since I got into 3D printing several years back. I believe the industry as a whole just has not figured it out.
Having said that, I believe the industry is on the cusp of some significant progress because of the E3D "De-Facto" standard around kinematic coupling for tool changing. I have decided to pursue this via the "Jubilee" printer design from @poofjunior. More info here: https://github.com/machineagency/jubilee
I've got my build up and running, and have recently had my very first successful two color print. Still lots of tuning and tweaking to go... so we will see if this turns into a reliable solution for multi.
You'll find occasional updates from me here in the Duet3D forums. There is also a Discord for the Jubilee.
(Note: The way discord works, that link will expired 24 hours from Nov 16 2019, 09:45 AM CST).
Les pièces d'origine d'origine sont vendues par reprap.me
Thank you so much...
@Rudy2A said in Multi colour printing and multi tool printers:
Here you go
