(SOLVED) Duet Wifi slow printing
2.8k
    cdl1701yahoo.com
    Hey everyone, I am new to the Duet line of boards and just got mine up and running tonight. So far everything is working great but it is printing very slow. I am not familiar with the config files that much yet and how to edit them or how to understand them rather. Is there some section in the config.g file that controls how fast it prints?
    Here is a short video of how it is printing. It speeds up and slows down which I am not used to and at this point should be printing around 50mm/s.
    https://www.youtube.com/watch?v=OmEX_KbPzXM&feature=youtu.be
      elmoret
      Looks like maybe your acceleration limits are low, can you post config.g here?
        See https://duet3d.com/wiki/Configuring_RepRapFirmware_for_a_Cartesian_printer for information on the config.g file. You can also use the tool at https://configurator.reprapfirmware.org to generate the file for you. I agree with Tim, the acceleration looks too low.
          StephenRC
          Disable or reduce your pressure advance setting.
            cdl1701yahoo.com
            Here is my config.g. I just used what ever was the default that came from the on line configurator.
            M111 S0 ; Debugging off
            G21 ; Work in millimetres
            G90 ; Send absolute coordinates…
            M555 P2 ; Set firmware compatibility to look like Marlin
            M208 X210 Y210 Z170 S0 ; Set axis maxima
            M558 P0 X0 Y0 Z0 H5 F120 T6000 ; Set Z probe type to switch, the axes for which it is used and the probe + travel speeds
            G31 P600 X0 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height
            M92 X157.64 Y157.64 Z5120 E301.54 ; Set steps per mm
            M566 X900 Y900 Z12 E120 ; Set maximum instantaneous speed changes (mm/min)
            M203 X6000 Y6000 Z180 E1200 ; Set maximum speeds (mm/min)
            M201 X500 Y20 Z250 E250 ; Set accelerations (mm/s^2)
            M906 X1200 Y1200 Z1200 E1000 I30 ; Set motor currents (mA) and motor idle factor in per cent
            M84 S30 ; Set idle timeout
            M143 S260 ; Set maximum heater temperature to 260C
            M305 P0 T100000 B3950 C0 R4700 ; Set thermistor + ADC parameters for heater 0
            M305 P1 T100000 B4388 C0 R4700 ; Set thermistor + ADC parameters for heater 1
            M563 P0 D0 H1 ; Define tool 0
            G10 P0 X0 Y0 ; Set tool 0 axis offsets
              cdl1701yahoo.com
              Another question. Do you have to do a reset to get changes in the config.g to take effect? making changes after each print to tweek the speeds but not seeing much change.
              What do you guys use for your accelerations?
                bot
                You have to reset, initiate the config.g file via gcode, or initiate the individual changed gcodes.
                Your accelerations are very low, and inconsistent. See your M201 command. Perhaps you need the low accel for Y, because of lots of moving mass, but this is the reason for your slow movement.
                *not actually a robot
                  InSanity
                  Watching the video I think I would start with:
                  M201 X800 Y800 Z250 E2500 ; Set accelerations (mm/s^2)
                  After that go up in increments of 200 on X and Y only until problems start to surface and then back it down on Y and/or X. Personally I think having equal acceleration is best…but that's just my opinion. You can adjust this while printing, just be careful not to get a typo or you'll have some serious problem potential.
                  I can't really see the extruder well, I just know I run mine at 9000 using a 0.9 deg steppers and MK7 drives.
                  Jeff
                  Duet WiFi Powered FFCP with E3D legends hotend system. BLTouch grid leveling.
                    cdl1701yahoo.com
                    Thanks for the help guys. Did some tweaking tonight and it is starting to get better. Few more test runs and I think I will have it lined out.
                    5 out of 9
