    How to wire the smart effector to the duet wifi board.
    Smart effector for delta printers
    800
    • Elvis0zundefined
      Elvis0z
      Hey
      I have the smart effector and duet wifi board. Just a bit confused about what I wire up to the smart effector from the duet wifi board. I have installed the hotend and fan its jus the top wiring of the smart effector that I not sure of.
        Have you seen this? https://duet3d.dozuki.com/Wiki/Smart_effector_and_carriage_adapters_for_delta_printer
        Elvis0zundefined 1 Reply Last reply Reply Quote 0
        • Elvis0zundefined
          Elvis0z @Phaedrux
          @Phaedrux Yep I have seen it just don't understand it.
            Well the step by step assembly section has some pretty good detail on how to get it connected and put together. What step are you on?
            • Elvis0zundefined
              Elvis0z
              I have the hotend installed, and wired up its just the top that I'm stuck on. The 7 pin white plug and the 6pin black plug.
              • Danalundefined
                Danal
                Goto this specific section:
                https://duet3d.dozuki.com/Wiki/Smart_effector_and_carriage_adapters_for_delta_printer#Section_Top_side
                There is a table that shows exactly what wire on the Smart Effector goes to exactly which connector on the Duet. One table for each topside connector.
                • Elvis0zundefined
                  Elvis0z
                  Thanks you
                  • Elvis0zundefined
                    Elvis0z @Danal
                    @Danal Hey still not sure how to wire this up. Do I have to use the same wire for the hotend heater. I have heater wire that came of my old hotend. and just plug it into that Molex plug on the effector, Then into the hotend heater on the control board.
                    • Danalundefined
                      Danal @Elvis0z
                      @Elvis0z said in How to wire the smart effector to the duet wifi board.:
                      Yes. Connect every wire in the table from the effector to the Duet. Then plug the hotend heater into the labeled connector on the BOTTOM of the duet.
                      • dgratundefined
                        dgrat
                        The 6 pin is just power => connect to any fan connectors and the heater
                        The 8 pin are the sensors => z-probe and thermristor
