    Help with pulse-generating Filament Sensor
    Filament Monitor
    9
    28
    2.3k
      T3P3Tony administrators
      @kordris as dc42 said, you L value is way too low:
      measured sensitivity 6.650mm/pulse
      which may be correct or may be long between pulses. depends on the sensor. what does the sensor manual say about pulses per mm?
      anyway try setting the L parameter in M591 to 6.65
      • kordrisundefined
        kordris
        This is the pdf on the filament sensor, it says use 7mm on marlin for the sensor. But I dont think thats for the pulse. It doenst give much info on what other info for setting for duet stuff. Im having to figure it out for my self.
        PDF File Github Link
          certainly looks like 7 or 6.65 would be a good start point for the L parameter.
          • kordrisundefined
            kordris
            Even if I use that, i still get no postion data. Which then leads to the printer stopping because it says theres to little movement. I dont think it's getting postion data correctly. Is there anything else should I enable in my config.g for the endstop on the extruder side. Since I'm using the extruder endstop E1. When I tried to get calibration data, it's the se way. Theres no postion point. So as soon as I go to enable the filament sensor it's going to error tell me there little or no movement.
              T3P3Tony administrators @kordris
              @kordris run the monitor disabled by using the M591 S0 switch for now so we can gather some data.
              looking at our previous output 6.650mm/pulse, measured minimum 7%, maximum 8% over 2334.0mm that shows that is was sensing something as it measured some minimum and maximum. What does M591 D0 show now?
              I have not tried it myself but I am not sure what position data is displayed for a pulse type sensor. it may just be movement as the pulse sensor does not send position.
              kordrisundefined 1 Reply Last reply Reply Quote 0
                A pulse generating sensor doesn't distinguish between forward and reverse motion, so position cannot be inferred. I'll check why the firmware prints a position.
                  I've checked the code, and I confirm that the "current position" has no meaning for a pulsed filament monitor. I'll remove it from the report in the next firmware build.
                  • kordrisundefined
                    kordris
                    Ok, so when I try to run it with just those lines. I get little movement error. This is why I think that line postion has something to do with the error. Because it expecting to get the position data but its not. This is the last calibration data that I got. I guess until you fix it. I wont be able to use it.
                    Pulse-type filament monitor on endstop input 4, enabled, sensitivity 6.650mm/pulse, allowed movement 60% to 140%, check every 3.0mm, current position 0.0, measured sensitivity 12.004mm/pulse, measured minimum 0%, maximum 111% over 24.0mm
                    • kordrisundefined
                      kordris
                      When I change the E to 7mm distance I get a lot longer print time before it errors out before it wants to give me the problem with no little movement. So I guessing I might be close to the right settings maybe?
                      M591 D0 C4 P7 R60:140 A1 L6.65 E7 S1      ; pulse-generating sensor drive 0 Connected to C4 input, 40% to 130% tolerance, 7mm detection length
                      M591 D0                                   ; display filament sensor parameters for extruder drive 0
                      This is the last one M591 D0
                      Pulse-type filament monitor on endstop input 4, enabled, sensitivity 6.650mm/pulse, allowed movement 60% to 140%, check every 7.0mm, current position 0.0, measured sensitivity 6.886mm/pulse, measured minimum 47%, maximum 104% over 185.9mm
                      • kordrisundefined
                        kordris @T3P3Tony
                        @T3P3Tony said in Help with pulse-generating Filament Sensor:
                        M591 S0
                        To get the Calibration data better do I just run M591 S0 ? I do I run the full M591 command with the S0 on the end like I had and then just check it with M591 D0 command.
                          dc42 administrators @kordris
                          @kordris said in Help with pulse-generating Filament Sensor:
                          M591 S0
                          See https://duet3d.dozuki.com/Wiki/Duet3dFilamentMonitor_LaserVersion#Section_Calibration. It's written for the laser filament monitor, but it's the same for your filament monitor.
                          As it appears that your sensor only generates 1 pulse per approx. 6mm of filament, you will need to set the measurement distance (E parameter) several times greater then 6mm in order to get consistent results.
                          • kordrisundefined
                            kordris @dc42
                            @dc42 Is the position data going to cause any problems or is that just going to just unrelated till you fix in the next firmware fix? I try to set the pulse to higher number. But I kept getting a error about every 5 mins telling little or no movement when I tried to enable the sensor with the S1. So Im guessing I still don't have something just right.
                              No, the position data being reported as zero shouldn't cause any problems. However, I can't guarantee that the code is entirely correct, because it was adapted from the code for Duet3D laser and magnetic filament monitors, so it isn't well-suited to low-resolution sensors. With a window of 60 to 140%, my guess is that you will need at least 20mm measurement length, perhaps even 25mm. A wider window will allow a shorter length, but even then the measurement length should be more than twice the extrusion length per pulse.
                              • lifeformundefined
                                lifeform
                                @kordris would you like to share with me how you plug the cable of the bigtreetech smart filament sensor with duet?
                                keith89undefined 1 Reply Last reply Reply Quote 0
                                • keith89undefined
                                  keith89 @lifeform
                                  @lifeform not sure if you figured out the wiring but if you trace the wires to the sensor, there is a 4 pin connector with only 3 wires. the single wire on the end with no wire next to it is Vin. the middle wire is signal and the wire right next to that is ground.
                                  Back to the original topic, has anyone figured out the correct mm/pulse for this sensor?
                                  • omniundefined
                                    omni
                                    Hi guys,
                                    Has anyone managed to properly set the Bigtreetech smart filament sensor to Duet meanwhile?
                                    I am just finishing my build with Duet 2, and I have connected the sensor - but still haven't done any configuring.
                                    Maybe the settings used in Marlin 2.0 can help?
                                    So if anyone of you managed to set it correctly - please help.
                                    Thanks!
                                      Start with https://duet3d.dozuki.com/Wiki/Gcode#Section_M591_Configure_filament_sensing.
                                      omniundefined 1 Reply Last reply Reply Quote 0
                                      • omniundefined
                                        omni @dc42
                                        Thanks for the answer.
                                        I've tried it yesterday - but it seems that Duet is not recording any data from the sensor.
                                        I configured the sensor as following, just to log data when printing :
                                        M591 D0 P7 C"^e0stop" L0.07853981634 R90:110 E3 S0
                                        but it did not receive any data.
                                        Any ideas on what I can try is highly appreciated.
                                        Thanks again
                                          Phaedrux Moderator @omni
                                          @omni said in Help with pulse-generating Filament Sensor:
                                          S0
                                          S0 is disabled, is it not? Try S1 maybe?
                                          • omniundefined
                                            omni @Phaedrux
                                            @Phaedrux
                                            Hi Phaedrux,
                                            Thanks for the reply.
                                            Yes, it is disabled - meaning it does not stop the process of printing, but it should be receiving and collecting data.
                                            It's because it only works when the printing from the SD card starts, but since it is not gathering any data if I choose S1 it would stop the print.
                                            I just wanted to see if DUET is receiving anything - and it seems it is not.
