    short-to-ground reported by driver(s) 2 4 9
    651
      If you are getting those errors without even enabling the drivers, it probably means that the SPI communication to those chips is not working.
      3dprintingnutundefined 1 Reply Last reply Reply Quote 0
      • 3dprintingnutundefined
        3dprintingnut @dc42
        @dc42 said in short-to-ground reported by driver(s) 2 4 9:
        yeah, I haven't enabled 2 4 9 drivers, coz I only need 7 axis, and used 2 drivers on duex5, so the rest 3 drivers were removed on board. is there any way to stop popping up the error?
        Error: short-to-ground reported by driver(s) 2 4 9
        Error: over temperature shutdown reported by driver(s) 2 4 9
          3dprintingnut @Veti
          @Veti those chips are not hot, they are not being used. it reports error as soon as power up.
          • Vetiundefined
            Veti
            @3dprintingnut said in short-to-ground reported by driver(s) 2 4 9:
            you physically removed the chips from the board?
              3dprintingnut @Veti
              @Veti yeah, that's right.
                droftarts administrators
                I expect you'll need to disable SPI poling of those chips in the firmware. I don't know how to do this.
                  You can use M569 with parameter R-1 to disable monitoring of a driver.
                  3dprintingnutundefined 2 Replies Last reply Reply Quote 0
                  • Hugo Hiaslundefined
                    Hugo Hiasl
                    When I had this error message it was a broken cable (one of the 4 cables to the stepper).
                    Having it on multiple steppers might be caused by another reason.
                      3dprintingnut @dc42
                      @dc42 it's fixed, thank you very much.👍
                      TLASundefined 1 Reply Last reply Reply Quote 0
                        3dprintingnut @dc42
                        @dc42 another issue, it shows below warning as soon as turn on power, do you know why and how to fix it?
                        • Vetiundefined
                          Veti
                          that is normal for e3d hotends with silicone socks.
                          what hotend do you have?
                            3dprintingnut @Veti
                            @Veti yeah, I use E3D V6 hotend with silicone sleeve, is there any way to close the warning?
                            • TLASundefined
                              TLAS @3dprintingnut
                              @3dprintingnut
                              FYI, I've seen this error when the drivers don't have any power... (on Duex due to a blown fuse)
                                Phaedrux Moderator @3dprintingnut
                                It's simply telling you what you can expect from a runaway heater condition. It can be ignored but it cannot be suppressed.
