    Replace fuse for broken fans
    816
    • piperswundefined
      pipersw
      yes you just have to pull it out
      • jontek2undefined
        jontek2
        • piperswundefined
          pipersw
          Test the continuity with ohmmeter if you don't see a cut inside, but it seems blown
            droftarts administrators
            And check your fan wiring connections before turning it on, once you put a new fuse in!
            • jontek2undefined
              jontek2
              I've now replaced the blown fuse with a generic mini fuse 2A and the fans are now working again - thanks everybody!
              May i suggest to the mods that you change the title of this thread to "Replace fuse for broken fans" or something. It may help somebody else in the future.
              • TLASundefined
                TLAS
                Also a shout out to the electrical designers of the cards - thanks for putting this in!
                The fuses are pretty recent addition and I’ve blown them out a good 1/2 dozen times now (got a huge pack off of Amazon...). So very grateful to replace the fuse over a dead board.
                Thanks!
                • TLASundefined
                  TLAS
                  +1....
                  Make that 7 now. 🙂
                  Upping the fuse to 15 Amps based on this thread:
                  https://forum.duet3d.com/topic/1925/max-hot-end-heater-current?_=1574893763955
                  If anyone cares, using PTC heaters may cause unexpected blown fuses. The resistance (and thus current) varies with temperature. As the heater gets over a specific temperature (about 60C effective operation) resistance rapidly increases cutting off power to the heater until it cools down. Great for safety.
                  Downside is that if the heater is cold, the resistance is even lower than normal and can result in a sudden onrush of current before it starts to warm up. Enough to cause a standard 7.5A fuse to blow.
                  piperswundefined 1 Reply Last reply Reply Quote 0
                  • piperswundefined
                    pipersw @TLAS
                    @TLAS it's fan fuse here, not the bed fuse 😉 so 1A is good
                    TLASundefined 1 Reply Last reply Reply Quote 0
                    • TLASundefined
                      TLAS @pipersw
                      @pipersw
                      Blown a few of those too. 🙂
                      Tornado-Like Fans - pulls ~2A each
                      • Vetiundefined
                        Veti @TLAS
                        @TLAS said in Replace fuse for broken fans:
                        thats not for a 3d printer, is it?
                          deckingman @Veti
                          @Veti said in Replace fuse for broken fans:
                          Yes - 252 CFM - it's for blowing the parts off the build plate when the print finishes ☺
                          Vetiundefined TLASundefined 2 Replies Last reply Reply Quote 1
                          • Vetiundefined
                            Veti @deckingman
                            @deckingman
                            i can see the headlines. tornado created by misconfigured 3d printer.
                            • TLASundefined
                              TLAS @deckingman
                              @deckingman said in Replace fuse for broken fans:
                              lol. :). I guess I shouldn’t mention the 450 cfm one I have in there as well...
