    All Drivers give me disconnected reported by driver
    53
    2.1k
      Chances are the error message is telling you exactly what's wrong. The motor phases are incorrect.
      First you should identify the motor phase pairs and wire them accordingly.
      https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Identifying_the_stepper_motor_phases
      If you've identified the pairs and are sure you have them wired correctly you can do further troubleshooting.
      • DruckKlausundefined
        DruckKlaus
        Ofc i did. As said i first did it like it is supposed to be. It didnt work. And then i tried like everything else possible.
          Does it still report the error on all drivers with only 1 motor connected?
            DruckKlaus
            Short answer is: it reports it anytime. Dont matter if something is connected or not.
              Did it work correctly for your friend before they gave it to you?
                DruckKlaus
                atleast he said i did. he is trustworthy. thats the only reason i try to get it to run and not discard it already.
                  What are the specs of the motors you're trying to use?
                  DruckKlausundefined 1 Reply Last reply Reply Quote 1
                    DruckKlaus @Phaedrux
                    @Phaedrux said in All Drivers give me disconnected reported by driver:
                    https://cdn-reichelt.de/documents/datenblatt/X200/17HM5424DATASHEET.pdf
                    • Vetiundefined
                      Veti
                      M906 X1400 Y1400 Z1400
                      you are running 0.8A motors with 1.4A.
                      DruckKlausundefined 1 Reply Last reply Reply Quote 0
                        DruckKlaus @Veti
                        @Veti theyx running fine on this current. on the back, they got written 2.4A. Before i run them also with 1.4 and all was fine. they are pretty beefy
                        • Vetiundefined
                          Veti
                          then you posted the wrong spec sheet.
                          do you have a motor of different make that you can test?
                            DruckKlaus @Veti
                            @Veti said in All Drivers give me disconnected reported by driver:
                            y tested and the same issue
                              DruckKlaus
                              • Vetiundefined
                                Veti
                                can you measure the resistance between the red and blue wire and between the green and black wire?
                                  DruckKlaus
                                  1.3ohm between each
                                  • Vetiundefined
                                    Veti
                                    can you post a picture of the motor connection on the duet?
                                      DruckKlaus
                                      ofc, i dont lnow why but ofc
                                        DruckKlaus
                                          DruckKlaus
                                          @T3P3Tony u may got any idea ?
                                            Try removing the D2 from the M569 commands in config.g.
