    All Drivers give me disconnected reported by driver
    53
    2.1k
      Did it work correctly for your friend before they gave it to you?
      • DruckKlausundefined
        DruckKlaus
        atleast he said i did. he is trustworthy. thats the only reason i try to get it to run and not discard it already.
          What are the specs of the motors you're trying to use?
          DruckKlausundefined 1 Reply Last reply Reply Quote 1
            DruckKlaus @Phaedrux
            @Phaedrux said in All Drivers give me disconnected reported by driver:
            https://cdn-reichelt.de/documents/datenblatt/X200/17HM5424DATASHEET.pdf
            • Vetiundefined
              Veti
              M906 X1400 Y1400 Z1400
              you are running 0.8A motors with 1.4A.
              DruckKlausundefined 1 Reply Last reply Reply Quote 0
                DruckKlaus @Veti
                @Veti theyx running fine on this current. on the back, they got written 2.4A. Before i run them also with 1.4 and all was fine. they are pretty beefy
                • Vetiundefined
                  Veti
                  then you posted the wrong spec sheet.
                  do you have a motor of different make that you can test?
                    DruckKlaus @Veti
                    @Veti said in All Drivers give me disconnected reported by driver:
                    y tested and the same issue
                      DruckKlaus
                      • Vetiundefined
                        Veti
                        can you measure the resistance between the red and blue wire and between the green and black wire?
                          DruckKlaus
                          1.3ohm between each
                          • Vetiundefined
                            Veti
                            can you post a picture of the motor connection on the duet?
                              DruckKlaus
                              ofc, i dont lnow why but ofc
                                DruckKlaus
                                  DruckKlaus
                                  @T3P3Tony u may got any idea ?
                                    Try removing the D2 from the M569 commands in config.g.
                                      DruckKlaus @dc42
                                      @dc42 said in All Drivers give me disconnected reported by driver:
                                      Wont change anything. Started without and just added it as a hope it would help.
                                      • Danalundefined
                                        Danal
                                        Does the white connector and the black connector go to the same model of motor?
                                        If so, one of them has to be wrong.
                                        • The white connector is wired as though Red-Green and Blue-Black are coils.
                                        • The black connector is wired as though Red-Blue and Green-Black are coils.
                                        Those cannot both be true (if the cables are consistent on the other end, and plug into the same model motor).
                                        Please show a photo of where the white cable plugs into the motor and similar photo for the black one.
                                        DruckKlausundefined Deneteusundefined 2 Replies Last reply Reply Quote 1
                                          DruckKlaus @Danal
                                          @Danal said in All Drivers give me disconnected reported by driver:
                                          There is no connector on the motor.
                                            DruckKlaus
                                            This is my test Setup now because i need my printer working.
                                            Using generic 200steps/rev motors.
