    Nozzle gets smashed against the bed
    Other control boards
    2.5k
    • MJCTundefined
      MJCT @fcwilt
      @fcwilt
      It said that the probe didn’t touch the bed, if I’m not mistaken
      I didn’t try the settings changes because I was commuting home. I will try it firs thing in the morning
      • fcwiltundefined
        fcwilt @MJCT
        @MJCT said in Nozzle gets smashed against the bed:
        @fcwilt
        Well the dive height setting likely caused that.
        • MJCTundefined
          MJCT
          Ok, I followed yours instructions and it all worked fine. G30 S-1 gave me 0.212 0.213 0.213 Pretty consistent, right?
          Than run a Mesh Compensation that showed -0.008 to 0.138mm. I guess I can live with that, at least for now.
          Then I started a print. A test cube sliced on Cura 4.2.1 with REPRAP on settings.
          The problem is that it starts to print far above from the bed. The tool position in the status show Z 0.30 which should be all right because my first layer in the slicer was 0.3mm. Then I tried the same cube with 0.2mm in the first layer. The status shows Z 0.2 but again it prints far above the bed.
          What I’m doing wrong this time?
          ; generated by RepRapFirmware Configuration Tool v2.1.3 on Thu Nov 28 2019 16:04:13 GMT+0000 (Hora padrão da Europa Ocidental)
          M550 P"AA 300x300x600" ; set printer name
          M669 K1 ; select CoreXY mode
          M551 P"AA" ; set password
          M552 S1 ; enable network
          M586 P0 S1 ; enable HTTP
          M586 P1 S0 ; disable FTP
          M586 P2 S0 ; disable Telnet
          M92 X80.00 Y80.00 Z4000.00 E96.94 ; set steps per mm
          M906 X1750 Y1750 Z1750 E1750 I30 ; set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M208 X10 Y10 Z0 S1 ; set axis minima
          M208 X300 Y300 Z585 S0 ; set axis maxima
          M574 X1 Y1 S0 ; set active low and disabled endstops
          M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
          M558 P9 H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
          G31 P25 X25 Y0 Z0.213 ; set Z probe trigger value, offset and trigger height
          M557 X30:260 Y30:255 S30 ; define mesh grid
          M143 H0 S110 ; set temperature limit for heater 0 to 110C
          M563 P0 S"Extr 1" D0 H1 F0 ; define tool 0
          T0 ; select first tool
          droftartsundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
          • MJCTundefined
            MJCT
            I now realise that Z in the machine control dashboard, should be pointing 0.03 in the first case and 0.02 in the second, not 0.3 and 0.2
            Still need your help
              droftarts administrators @MJCT
              You've gone from a probe trigger height of 3.2mm to 0.213mm, which seems very close. Did you follow the guide here to set the probe offset? https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Calibrate_the_Z_probe_trigger_height
              1. Jog the nozzle down until it is just touching the bed or just gripping a sheet of paper. If the firmware doesn't let you jog it down far enough, send M564 S0 to disable axis limits.
              2. Once you have the nozzle touching the bed, send command G92 Z0 to tell the firmware that the head is at Z=0
              3. Jog the head up by 5 to 10mm
              4. Send command G30 S-1 to report probe offset.
              The first two points set the nozzle at Z=0. The second two determine the probe offset.
              MJCTundefined 1 Reply Last reply Reply Quote 0
              • MJCTundefined
                MJCT @droftarts
                @droftarts
                0.213 was the value reported by G30 S-1 command twice in three attempts. Should I cut one decimal and impute 2.13 at G31?
                And yes, I followed the wiki guide. I always do. The problem is that the guides usually don’t help me much. In this case the guide doesn’t provide any real example, neither it states the units in which the information is provided by the G30 or the units you must input at G31.
                That’s why I am so thankful to this community. You have been fantastic. I´m not lazy, is just that WIKI guides suck big time.
                • fcwiltundefined
                  fcwilt @MJCT
                  If the reported value was 0.213 that is what you use.
                  But that value is only valid if the Z position is correct, meaning Z=0 has the nozzle just touching the bed.
                  • MJCTundefined
                    MJCT
                    Tried “G31 P25 X25 Y0 Z2.13” instead of “G31 P25 X25 Y0 Z0.213” ... no surprises, it smashed the bed again!
                    droftartsundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                    • MJCTundefined
                      MJCT @fcwilt
                      @fcwilt
                      Yes I understand that.
                        @MJCT All units are millimetres. You can change to inches with G20, but this is supposed to be used only in gcode files, not for machine calibration.
                        Can you check that, after homing, if you send a command like G1 X100 Y100 Z0, the nozzle is not slamming into the bed? Or that the reported position of the nozzle is sensible. If that's the case, it's a problem with the gcode file. Check you haven't set any Z offset in Cura. Post you gcode file so we can check it.
                        • fcwiltundefined
                          fcwilt @MJCT
                          Is the pin dropping when you issue a G30 command? The probe has to touch the bed and retract for the motion to be halted.
                          • MJCTundefined
                            MJCT @droftarts
                            @droftarts Yes I understand that we are using SI units, supposedly mm, but I not sure of anything right now
                            @droftarts said in Nozzle gets smashed against the bed:
                            Funny (not really), yes it did slammed into the bed. But I did everything by the book (or not). Nozzle at the centre of the bed, just barely touching the bed (paper can still slide under), sent G92 Z0, pull bed down 15mm, sent G30 S-1, changed G31, sent M999.
                            The only thing I didn’t do is the "config-override.g " thing, because I just can’t find that file any ware
                            • MJCTundefined
                              MJCT @fcwilt
                              @fcwilt
                              @fcwilt said in Nozzle gets smashed against the bed:
                              Yes, sent G30 command, the probe deplyed, bed moved up until it touched the probe than stoped.
                              • fcwiltundefined
                                fcwilt @MJCT
                                @MJCT said in [Nozzle gets smashed against
                                OK then at point what is the displayed Z position? Does it appear to be accurate?
                                • MJCTundefined
                                  MJCT
                                  Where do I find "config-override.g " file, maybe is because of that. Maybe it always overrides my new imputes.
                                  fcwiltundefined droftartsundefined 2 Replies Last reply Reply Quote 0
                                  • fcwiltundefined
                                    fcwilt @MJCT
                                    If it exists it is right there next to config.g.
                                    • MJCTundefined
                                      MJCT @fcwilt
                                      @fcwilt
                                      Well, to me, it never existed. Still it appears at the wiki
                                      “9. Open config-override.g and check that there are no G31 commands in it. If you find any, delete those lines and save the file.”
                                      And it’s not the first time that I see the wiki page referring to it, and that’s why I don’t trust wiki
                                        You don't have M501 (read stored parameters) in your config.g, so it won't be loading config-override.g (which is usually in the sys folder, where config.g is). You'll only have a config-override.g if you have sent an M500 to store
                                        How old is your BL Touch? I have heard that after a while they can get 'sticky', with the pin not deploying fully, and giving variable results. I believe you can take them apart and give them a clean.
                                        • MJCTundefined
                                          MJCT
                                          I think I found the reason why I never see a config-override file...
                                          *****“dc42 ADMINISTRATORS 10 Jun 2017, 23:18
                                          If you created your config.g file using configtool, you will have selected whether or not config-override.g is processed.”*****
                                          When I did my config with the config toll I didn’t select the “Read config-override.g file at end of startup process” box at “General”.
                                          One doubt less, but still doesn’t solve my problem
                                          • fcwiltundefined
                                            fcwilt @MJCT
                                            @MJCT
                                            The file config-override is created if you have executed a M500 command.
                                            I don't have one as created it to have access to the two line of code that were generated by heater tuning.
                                            I copied those lines into config.g and deleted config-override.g
