    Nozzle gets smashed against the bed
    Other control boards
    2.5k
    • MJCTundefined
      MJCT
      I now realise that Z in the machine control dashboard, should be pointing 0.03 in the first case and 0.02 in the second, not 0.3 and 0.2
      Still need your help
        droftarts administrators @MJCT
        @MJCT said in Nozzle gets smashed against the bed:
        G31 P25 X25 Y0 Z0.213 ; set Z probe trigger value, offset and trigger height
        You've gone from a probe trigger height of 3.2mm to 0.213mm, which seems very close. Did you follow the guide here to set the probe offset? https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Calibrate_the_Z_probe_trigger_height
        1. Jog the nozzle down until it is just touching the bed or just gripping a sheet of paper. If the firmware doesn't let you jog it down far enough, send M564 S0 to disable axis limits.
        2. Once you have the nozzle touching the bed, send command G92 Z0 to tell the firmware that the head is at Z=0
        3. Jog the head up by 5 to 10mm
        4. Send command G30 S-1 to report probe offset.
        The first two points set the nozzle at Z=0. The second two determine the probe offset.
        MJCTundefined 1 Reply Last reply Reply Quote 0
        • MJCTundefined
          MJCT @droftarts
          @droftarts
          0.213 was the value reported by G30 S-1 command twice in three attempts. Should I cut one decimal and impute 2.13 at G31?
          And yes, I followed the wiki guide. I always do. The problem is that the guides usually don’t help me much. In this case the guide doesn’t provide any real example, neither it states the units in which the information is provided by the G30 or the units you must input at G31.
          That’s why I am so thankful to this community. You have been fantastic. I´m not lazy, is just that WIKI guides suck big time.
          • fcwiltundefined
            fcwilt @MJCT
            If the reported value was 0.213 that is what you use.
            But that value is only valid if the Z position is correct, meaning Z=0 has the nozzle just touching the bed.
            • MJCTundefined
              MJCT
              Tried “G31 P25 X25 Y0 Z2.13” instead of “G31 P25 X25 Y0 Z0.213” ... no surprises, it smashed the bed again!
              droftartsundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
              • MJCTundefined
                MJCT @fcwilt
                @fcwilt
                Yes I understand that.
                  @MJCT All units are millimetres. You can change to inches with G20, but this is supposed to be used only in gcode files, not for machine calibration.
                  Can you check that, after homing, if you send a command like G1 X100 Y100 Z0, the nozzle is not slamming into the bed? Or that the reported position of the nozzle is sensible. If that's the case, it's a problem with the gcode file. Check you haven't set any Z offset in Cura. Post you gcode file so we can check it.
                  • fcwiltundefined
                    fcwilt @MJCT
                    Is the pin dropping when you issue a G30 command? The probe has to touch the bed and retract for the motion to be halted.
                    • MJCTundefined
                      MJCT @droftarts
                      @droftarts Yes I understand that we are using SI units, supposedly mm, but I not sure of anything right now
                      @droftarts said in Nozzle gets smashed against the bed:
                      Funny (not really), yes it did slammed into the bed. But I did everything by the book (or not). Nozzle at the centre of the bed, just barely touching the bed (paper can still slide under), sent G92 Z0, pull bed down 15mm, sent G30 S-1, changed G31, sent M999.
                      The only thing I didn’t do is the "config-override.g " thing, because I just can’t find that file any ware
                      • MJCTundefined
                        MJCT @fcwilt
                        @fcwilt
                        @fcwilt said in Nozzle gets smashed against the bed:
                        Yes, sent G30 command, the probe deplyed, bed moved up until it touched the probe than stoped.
                        • fcwiltundefined
                          fcwilt @MJCT
                          @MJCT said in [Nozzle gets smashed against
                          OK then at point what is the displayed Z position? Does it appear to be accurate?
                          • MJCTundefined
                            MJCT
                            Where do I find "config-override.g " file, maybe is because of that. Maybe it always overrides my new imputes.
                            fcwiltundefined droftartsundefined 2 Replies Last reply Reply Quote 0
                            • fcwiltundefined
                              fcwilt @MJCT
                              If it exists it is right there next to config.g.
                              • MJCTundefined
                                MJCT @fcwilt
                                @fcwilt
                                Well, to me, it never existed. Still it appears at the wiki
                                “9. Open config-override.g and check that there are no G31 commands in it. If you find any, delete those lines and save the file.”
                                And it’s not the first time that I see the wiki page referring to it, and that’s why I don’t trust wiki
                                  You don't have M501 (read stored parameters) in your config.g, so it won't be loading config-override.g (which is usually in the sys folder, where config.g is). You'll only have a config-override.g if you have sent an M500 to store
                                  How old is your BL Touch? I have heard that after a while they can get 'sticky', with the pin not deploying fully, and giving variable results. I believe you can take them apart and give them a clean.
                                  • MJCTundefined
                                    MJCT
                                    I think I found the reason why I never see a config-override file...
                                    *****“dc42 ADMINISTRATORS 10 Jun 2017, 23:18
                                    If you created your config.g file using configtool, you will have selected whether or not config-override.g is processed.”*****
                                    When I did my config with the config toll I didn’t select the “Read config-override.g file at end of startup process” box at “General”.
                                    One doubt less, but still doesn’t solve my problem
                                    • fcwiltundefined
                                      fcwilt @MJCT
                                      @MJCT
                                      The file config-override is created if you have executed a M500 command.
                                      I don't have one as created it to have access to the two line of code that were generated by heater tuning.
                                      I copied those lines into config.g and deleted config-override.g
                                      • MJCTundefined
                                        MJCT
                                        My BL is new. Version 3.1, the pin deploys fully and the results are consistent.
                                        The problem seems to be that the values that I impute are not taken in to account and the real distance from the nozzle to the bed doesn’t correspond to the distance displayed at the Dashboard for the Z (dashboard always displays a positive value, say 2mm, when the nozzle is already touching the bed).
                                        • fcwiltundefined
                                          fcwilt
                                          After you do a single G30 does the reported value seem to be correct? Does the gap between nozzle and bed seem to match the reported value?
                                          • MJCTundefined
                                            MJCT @fcwilt
                                            @fcwilt ~
                                            Nop, last 2 times that that I sent G30 the nozzle smashed the bed
