    No x move with G1 X1‭47 F6000
    586
      Have you homed X and Y before you try to home Z?
      • PuddingBaer91undefined
        PuddingBaer91
        yes. As i said it worked many days well with these settings. I tested and if i choose G1 X230 F6000 it will move and then i am able to move G1 X167 F6000. Very strange...
          What X and Y coordinates does DWC show? Maybe it thinks it is already at X167 Y157.
          PuddingBaer91undefined 1 Reply Last reply Reply Quote 0
            PuddingBaer91
            hmm i have to try many AAAA values for G1 XAAAA F6000 sometime it will begin to work but then if i try home z it will move back to X=0 and then again i have to play with many AAAA values to get x to move 😞 😞
            aidarundefined 1 Reply Last reply Reply Quote 0
              PuddingBaer91 @dc42
              @dc42 said in No x move with G1 X1‭47 F6000:
              no the coordinates are correct X=0 is real 0 and is shown as 0 in DWC. Also if i move the head the coordinates are correct
                PuddingBaer91
                ok i tried the auto level macro and here the nozzle moves like it should
                Edit: With bltouch disabled it also will not move to the requested x position (always homing z at X=0)
                • aidarundefined
                  aidar @PuddingBaer91
                  @PuddingBaer91 said in No x move with G1 X1‭47 F6000:
                  Please post your homing files
                    PuddingBaer91
                    ; homeall.g
                    ; called to home all axes
                    ; generated by RepRapFirmware Configuration Tool on Wed Oct 24 2018 17:07:50 GMT+0200 (Mitteleuropäische Sommerzeit)
                    G91 ; relative positioning
                    M98 Pdeployprobe.g ; deploy mechanical Z probe
                    G1 S1 X-450 Y450 F3000 ; move quickly to X or Y endstop and stop there (first pass)
                    G1 S1 X-450 ; home X axis
                    G1 S1 Y450 ; home Y axis
                    G1 X5 Y-5 F6000 ; go back a few mm
                    G1 X5 X-5 F6000 ; go back a few mm
                    G1 S1 X-450 F360 ; move slowly to X axis endstop once more (second pass)
                    G1 S1 Y450 ; then move slowly to Y axis endstop
                    G90 ; absolute positioning
                    ;G1 X‭220 Y157 F6000 ; go to first bed probe point and home Z
                    G1 X152 Y150 F6000
                    ;G91 ; relative positioning
                    ;G1 S2 Z5 F100 ; lift Z relative to current position
                    ;G90 ; absolute positioning
                    M98 Pretractprobe.g ; retract mechanical Z probe
                    • aidarundefined
                      aidar
                      What firmware version are you using?
                        PuddingBaer91
                        G1 X152 Y150 F6000
                        with the secons G1 it works. Do you see a difference?
                          PuddingBaer91 @aidar
                          @aidar said in No x move with G1 X1‭47 F6000:
                          tried the latest and downgraded to 2.03 but problem exists on both.
                          • aidarundefined
                            Yes i see, first G1 has ; at the beginning of the line, so its comments line, not command
                            • aidarundefined
                              With firmware 2.02 or later i reccomend to use H1 parameter instead of S1 for homing (see https://duet3d.dozuki.com/Wiki/Gcode#Section_G0_G1_Move ), also you dont need call deployprobe.g and retractprobe.g, firmware will do it for you if your probe is set as bltouch (P9 in M558 command)
                              • aidarundefined
                                Also this line doesnt make sense, X5 and X-5
                                  this is from online config tool. Also don't know why they there. I will try the H1 Paramter thanks for the info
                                    PuddingBaer91
                                    ok i did a complete reconfig with the online tool and firmware 2.03... Now almost is running fine except homing z. If i press home all x axis moves to the correct location x=220 but y moves always to y=30. I can't find the error...
                                    ; homeall.g
                                    ; generated by RepRapFirmware Configuration Tool v2.1.3 on Thu Dec 05 2019 15:32:21 GMT+0100 (Mitteleuropäische Normalzeit)
                                    G1 H1 X-365 F1800 ; move quickly to X axis endstop and stop there (first pass)
                                    G1 H1 Y335 F1800 ; move quickly to Y axis endstop and stop there (first pass)
                                    ;G1 H2 X220 Y157 F6000 ; go to first bed probe point and home Z
                                      PuddingBaer91
                                      M550 P"TronXY X5S" ; set printer name
                                      M667 S1 ; select CoreXY mode
                                      M551 P"" ; set password
                                      M552 S1 ; enable network
                                      M586 P0 S1 ; enable HTTP
                                      M586 P1 S0 ; disable FTP
                                      M586 P2 S0 ; disable Telnet
                                      M569 P2 S0 ; physical drive 2 goes backwards
                                      ;M584 X0 Y1 Z2 E3 ; set drive mapping
                                      M92 X160.00 Y160.00 Z400.00 E411.00 ; set steps per mm
                                      ;M906 X1344 Y1344 Z1900 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent
                                      M906 X1144 Y1144 Z1500 E1500 I30 ; Set motor currents (mA) and motor idle factor in percent
                                      M84 S30 ; Set idle timeout
                                      M208 X-30 Y-17 Z0 S1 ; set axis minima
                                      M208 X330 Y315 Z350 S0 ; set axis maxima
                                      M574 X1 Y2 S0 ; set active high endstops
                                      M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
                                      M558 P9 H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
                                      G31 P500 X-32 Y17 Z2.5 ; set Z probe trigger value, offset and trigger height
                                      ;M557 X-15:215 Y0:195 S20 ; define mesh grid
                                      M557 X20:298 Y20:315 P4:4
                                      M305 P1 T100000 B4725 C7.060000e-8 R4700 ; set thermistor + ADC parameters for heater 1
                                      M143 H1 S260 ; set temperature limit for heater 1 to 260C
                                      M563 P0 S"Extruder" D0 H1 F0 ; define tool 0
                                      ;M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
                                      M307 H1 A241.8 C124.9 D2.6 S1.00 V24.2 B0 ; Extruder PID
                                      M307 H0 A101.4 C1123.0 D10.0 B0 ; Heatbed PID
                                        dc42 administrators @PuddingBaer91
                                        Does it home correctly to Y=+335 before going to Y30 instead of to Y157? If so then I suspect that your M92 Y steps/mm value is incorrect. Try jogging Y 10mm or 50mm at a time in Duet Web Control, and see how far it actually moves.
                                          PuddingBaer91
                                          if i move the head with web control it moves correctly. As you said i move to y=335. After homing is done it shows y=335 at web control. Steps per mm should be correct. Calculated with prusa calculator and these values i used for many months.. X and Y are the same motors and pulleys also the steps/mm should be equal.
                                            Your M558 command indicates that you have a BLTouch. You should remove the M98 Pdeployprobe.g and M98 Pretractprobe.g lines. Also, check that your deployprobe.g and retractprobe.g files are set up correctly for BLTouch.
