    No x move with G1 X1‭47 F6000
    586
    • PuddingBaer91undefined
      PuddingBaer91 @aidar
      @aidar said in No x move with G1 X1‭47 F6000:
      What firmware version are you using?
      tried the latest and downgraded to 2.03 but problem exists on both.
      aidarundefined 1 Reply Last reply Reply Quote 0
      • aidarundefined
        aidar @PuddingBaer91
        @PuddingBaer91 said in No x move with G1 X1‭47 F6000:
        with the secons G1 it works. Do you see a difference?
        Yes i see, first G1 has ; at the beginning of the line, so its comments line, not command
        • aidarundefined
          With firmware 2.02 or later i reccomend to use H1 parameter instead of S1 for homing (see https://duet3d.dozuki.com/Wiki/Gcode#Section_G0_G1_Move ), also you dont need call deployprobe.g and retractprobe.g, firmware will do it for you if your probe is set as bltouch (P9 in M558 command)
          • aidarundefined
            G1 X5 X-5 F6000 ; go back a few mm
            Also this line doesnt make sense, X5 and X-5
            PuddingBaer91undefined 1 Reply Last reply Reply Quote 0
              this is from online config tool. Also don't know why they there. I will try the H1 Paramter thanks for the info
                PuddingBaer91
                ok i did a complete reconfig with the online tool and firmware 2.03... Now almost is running fine except homing z. If i press home all x axis moves to the correct location x=220 but y moves always to y=30. I can't find the error...
                ; homeall.g
                ; called to home all axes
                ; generated by RepRapFirmware Configuration Tool v2.1.3 on Thu Dec 05 2019 15:32:21 GMT+0100 (Mitteleuropäische Normalzeit)
                G91 ; relative positioning
                M98 Pdeployprobe.g ; deploy mechanical Z probe
                G1 H1 X-365 F1800 ; move quickly to X axis endstop and stop there (first pass)
                G1 H1 Y335 F1800 ; move quickly to Y axis endstop and stop there (first pass)
                G90 ; absolute positioning
                ;G1 H2 X220 Y157 F6000 ; go to first bed probe point and home Z
                M98 Pretractprobe.g ; retract mechanical Z probe
                  PuddingBaer91
                  M550 P"TronXY X5S" ; set printer name
                  M667 S1 ; select CoreXY mode
                  M551 P"" ; set password
                  M552 S1 ; enable network
                  M586 P0 S1 ; enable HTTP
                  M586 P1 S0 ; disable FTP
                  M586 P2 S0 ; disable Telnet
                  M569 P2 S0 ; physical drive 2 goes backwards
                  ;M584 X0 Y1 Z2 E3 ; set drive mapping
                  M92 X160.00 Y160.00 Z400.00 E411.00 ; set steps per mm
                  ;M906 X1344 Y1344 Z1900 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent
                  M906 X1144 Y1144 Z1500 E1500 I30 ; Set motor currents (mA) and motor idle factor in percent
                  M84 S30 ; Set idle timeout
                  M208 X-30 Y-17 Z0 S1 ; set axis minima
                  M208 X330 Y315 Z350 S0 ; set axis maxima
                  M574 X1 Y2 S0 ; set active high endstops
                  M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
                  M558 P9 H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
                  G31 P500 X-32 Y17 Z2.5 ; set Z probe trigger value, offset and trigger height
                  ;M557 X-15:215 Y0:195 S20 ; define mesh grid
                  M557 X20:298 Y20:315 P4:4
                  M305 P1 T100000 B4725 C7.060000e-8 R4700 ; set thermistor + ADC parameters for heater 1
                  M143 H1 S260 ; set temperature limit for heater 1 to 260C
                  M563 P0 S"Extruder" D0 H1 F0 ; define tool 0
                  ;M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
                  M307 H1 A241.8 C124.9 D2.6 S1.00 V24.2 B0 ; Extruder PID
                  M307 H0 A101.4 C1123.0 D10.0 B0 ; Heatbed PID
                    dc42 administrators @PuddingBaer91
                    Does it home correctly to Y=+335 before going to Y30 instead of to Y157? If so then I suspect that your M92 Y steps/mm value is incorrect. Try jogging Y 10mm or 50mm at a time in Duet Web Control, and see how far it actually moves.
                      PuddingBaer91
                      if i move the head with web control it moves correctly. As you said i move to y=335. After homing is done it shows y=335 at web control. Steps per mm should be correct. Calculated with prusa calculator and these values i used for many months.. X and Y are the same motors and pulleys also the steps/mm should be equal.
                        Your M558 command indicates that you have a BLTouch. You should remove the M98 Pdeployprobe.g and M98 Pretractprobe.g lines. Also, check that your deployprobe.g and retractprobe.g files are set up correctly for BLTouch.
