    Using G2/G3 but can't use all build area.
    • Penolaundefined
      Penola
      Hi 🙂
      I've been trying to setup a 1/4 circle wipe/purge line on my Delta.
      According to my Config Override G I have a radius of around 135mm
      ; config-override.g file generated in response to M500 at 2019-12-10 17:24
      ; Delta parameters
      M665 L271.500:271.500:271.500 R135.758 H290.197 B105.0 X0.255 Y-0.009 Z0.000
      M666 X0.935 Y-0.279 Z-0.655 A0.00 B0.00
      ; Heater model parameters
      However I get outside machine limit fail if running much more than 100mm offset in G3 (as below).
      ;FLAVOR:Marlin
      ;TIME:822
      ;Filament used: 1.61397m
      ;Layer height: 0.25
      ;MINX:-14
      ;MINY:-14
      ;MINZ:0.2
      ;MAXX:14
      ;MAXY:14
      ;MAXZ:19.65
      ;Generated with Cura_SteamEngine 4.4.0
      M140 S60
      M105
      M190 S60
      M104 S220
      M105
      M109 S220
      M82 ;absolute extrusion mode
      G21 ;metric values
      G28 ; home all axes
      M92 E415 ; Sets the correct E-steps for Bondtech
      M107
      G92 E0 ; reset extrusion distance
      G1 X-100 Y0 Z0.3 F3000 ; move to arc start
      G3 X0 Y-100 I100 J0 E40 F400 ; lay arc stripe 90deg
      G1 X0 Y-50 Z4 E-2 F3000 ; get off the bed
      G90 ;absolute positioning
      ;G92 E0 ;zero the extruded length
      ;G1 F200 E3 ;extrude 3mm of feed stock
      ;G92 E0 ;zero the extruded length again
      G1 F120
      ;Put printing message on LCD screen
      M117 Printing...
      Have any of you tried similar?
      The fault occur on the Duet during start of print only and printer just stops there.
      I know there is a collision check introduced but I'm a little puzzled that there is a difference of 35mm from Delta R-value to max possible offset in G2/G3 command
      • blt3dpundefined
        blt3dp
        I did the same thing, for the I and J you're describing the center of the arc relative to the center of the current coordinate.
        At that position, your I and J parameters should be I0 and J100 if you are describing 0,0
        I don't believe it takes any probe offsets into consideration, just the nozzle position.
        My 3D Printing YouTube Channel
        Better Living Through 3D Printing
        Follow me on Instagram and Twitter
        Instagram
        Twitter
        Penolaundefined 1 Reply Last reply Reply Quote 0
        • Penolaundefined
          Penola @blt3dp
          @blt3dp I have just found another place in "Machine properties - Drive configuration" that +/- 105 in X/Y is the setting here and this matches the check for limits in my problem.
          Now the function works fine and I get the 1/4 circle/arc at the edge of the build plate to ensure good start of print as filament line is purge/primed and ready to work when starting the job.
          So I guess my problem is solved/explained.
          Thanks for the interest here
          • Penolaundefined
            Penola @Penola
            @Penola
            I tried with 104.99 and this works fine so yes the check lies against the 105mm
              droftarts administrators @Penola
              @Penola said in Using G2/G3 but can't use all build area.:
              R135 is your delta radius. B105 is your safe print radius. See delta parameters meanings here: https://duet3d.dozuki.com/Wiki/Gcode#Section_M665_Set_delta_configuration
              • Penolaundefined
                Penola @droftarts
                @droftarts
                Thanks a lot.
                Haven’t noticed the safe radius setting in M665.
                Makes all the sense in the world now
