    To springsteel or not to springsteel? Removeable heated bed
    My Duet controlled machine
    removeable bed
    1.7k
    • zaptaundefined
      zapta @Nxt-1
      @Nxt-1 said in To springsteel or not to springsteel? Removeable heated bed:
      Loss of magnetic flux due to high bed temperatures.
      There are magnetic sheets that are specified for high temperature (100C+).
      Low hold strength, partially due to rather thick bed stackup.
      If you use those adhesive magnetic sheets above the aluminum bed, the bed thickness doesn't really matter.
      I am using this stack and am very happy with it. I need to remove the top and flex only for large objects. Most of the time I just scarp it gently.
      Insulation (comes with its own adhesive)
      Silicon heater
      3M
      6mm tooling aluminum
      3M
      magnetic sheet
      steel plate
      3M
      1mm PEI.
      Edit: this is the insulation I am using https://www.aliexpress.com/item/32878669055.html?spm=a2g0s.9042311.0.0.27424c4dKwyD8W if your bed is larger you cut cover it with multiple pieces. Easy to cut and apply.
      Nxt-1undefined 1 Reply Last reply Reply Quote 0
      • Nxt-1undefined
        Nxt-1 @zapta
        I started looking at a local-ish store that specializes in magnets. The offer ferrite magnets that should hold up to a working temperature of 230°C, which is more than enough. I must admit I do not know whether the (spring)steel holds its ability to be attracted by magnets at high temperatures or it's just the magnets that are the potential issue.
        @zapta Thanks for the insulation link, I am quite interested in that. It's cheap as well.
        Duet3D and delta printer enthousiast. Buildlog
        Looking for Duet3D configuration support, check out Nxt-3D
          A Former User @Nxt-1
          just magnets
          • zaptaundefined
            zapta
            Whambam for example have magnetic sheets that can sustain 150c. Do you plan to print with higher bed temperatures?
            https://whambamsystems.com/flexible-build-system
            • fmaundefined
              fma
              I'm using a flexible magnetic bed, made out of normal steel (0.5mm or 0.75mm, I don't remember; I can check if you want), and it works great. You don't need to bend it @180° to remove parts, so no worry to permanently deform it.
              I'm using it for more than a year, now, and no problem.
              Frédéric
              • Nxt-1undefined
                Nxt-1 @zapta
                @zapta said in To springsteel or not to springsteel? Removeable heated bed:
                I have seen quite a bit about Whambams in other groups but I find them quite expensive and they largest they offer is still to small for what I need.
                • Nxt-1undefined
                  Nxt-1 @fma
                  @fma said in To springsteel or not to springsteel? Removeable heated bed:
                  Very interesting, do you feel the steel holds its shape well after bending? Also, do you know what grade of steel you are using?
                  fmaundefined 1 Reply Last reply Reply Quote 0
                  • fmaundefined
                    fma @Nxt-1
                    Yes, the steel sheet remains perfectly flat once on the magnetic bed. But as said, I don't bend it much.
                    I don't know what grade it is; I bought it in a big DIY store: I think it is very basic steel!
                    Frédéric
                    • Nxt-1undefined
                      Nxt-1 @fma
                      Must be something in the likes of feritic stainless, otherwise I'd expect rusting, no?
                      • fmaundefined
                        fma
                        Yes, it is galvanized... But it is not a special steel.
                        Frédéric
