    Autolift with an additional 24V-device
    • fravarundefined
      fravar
      Hallo!
      I run a Hypercube double extruder with a duet wifi board. Two-color printouts are not particularly successful, as the slicer features for double extruder tasks are only an emergency solution. Optimal is an automatic lifting of the extruder during color change. I would like to realize an autolift similar to the Ultimaker 3. For this I have a magnet coil, which is supposed to lift the two extruders alternately. This responds at 24V DC voltage. My question: Where can I connect my coil on the board and where can I set this connection in the configuration when changing extruders?
      Many thanks for your help
      • NitroFreakundefined
        NitroFreak
        Take a look here:
        https://forum.duet3d.com/topic/8987/driving-24v-4a-6ohm-solenoids-selection-of-flyback-diode
        I tackled that problem before.
        • fravarundefined
          fravar
          Thank you for pointing that out. How can I now control the operation of the relay during a tool change?
            dc42 administrators @fravar
            @fravar said in Autolift with an additional 24V-device:
            https://duet3d.dozuki.com/Wiki/Using_servos_and_controlling_unused_IO_pins
            https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCartesianPrinter#Section_Tool_change_files
