Constant layer shift along y-axis
My cube is not straight. Does anyone have a clue why I may get a constant shift along y?
It is definitely not a mechanical issue. -
Some details of your setup would be useful to know. See https://forum.duet3d.com/topic/5909/guide-for-posting-requests-for-help
Here is my config
- ; Drives
- M569 P0 S1 ; physical drive 0 goes forwards
- M569 P1 S1 ; physical drive 1 goes forwards
- M569 P2 S1 ; physical drive 2 goes forwards
- M569 P3 S0 ; physical drive 3 goes forwards
- M584 X0 Y1 Z2 E3 ; set drive mapping
- M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation
- M92 X80.00 Y80.00 Z400.00 E180.00 ; set steps per mm
- M566 X30.00 Y30.00 Z30.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
- M203 X6000.00 Y6000.00 Z1200.00 E1200.00 ; set maximum speeds (mm/min)
- M201 X500.00 Y500.00 Z50.00 E1000.00 ; set accelerations (mm/s^2)
- M906 X1500 Y1700 Z1500 E1700 I30 ; set motor currents (mA) and motor idle factor in per cent
- M84 S30 ; Set idle timeout
- ; Axis Limits
- M208 X0 Y0 Z0 S1 ; set axis minima
- M208 X220 Y220 Z220 S0 ; set axis maxima
- ; Endstops
- M574 X1 Y1 Z2 S1 ; set active low and disabled endstops
- ; Z-Probe
- M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
- M558 P9 H10 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
- G31 P500 X0 Y0 Z3.0 ; set Z probe trigger value, offset and trigger height
- M557 X50:220 Y10:180 S42.5 ; define mesh grid
- ; Heaters
- M305 P0 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 0
- M143 H0 S120 ; set temperature limit for heater 0 to 120C
- M305 P1 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 1
- M143 H1 S280 ; set temperature limit for heater 1 to 280C
- ; Fans
- M106 P0 S0.3 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
- M106 P1 S1 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
- M106 P2 S1 I0 F500 H1 T45
- ; Tools
- M563 P0 D0 H1 F0 ; define tool 0
- G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets
- G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C
and some photos. I use linear rails..
How did you ensure that the Z axis was orthogonal to both X and Y when you built the machine?
your frame or at least your axis are not square to each other. is this the first time the printer has been assembled?
unrelated, but your belt path is also extremely un-parallel to the frame, which will result in different steps/mm depending on position and also belt tension.
Yes it is the first time this printer is assembled in that way. Nevertheless, the belt does not need to be parallel/flat to the extrusion. I rather think that one axis might not be straight, but how this should be possible in a cartesian? Even if y would be tilted 20 degree it would only matter for the first layer.
@dgrat said in Constant layer shift along y-axis:
it does create a small scaling error due to the angle of the belt.
Testprint of 2x2x10 cm cube. The higher the print, the less is the y offset. This is a bit weird. I try to re-check the y axis.
I re-assembled the x-axis ensured it is more or less orthogonal and the error disappeared
The issue appeared again with a 10x10x2cm cube. Y is not straight.
Is there a way to log step losses? Printer is square and I supect an issue with the driver?!
Actually, I never had a similar problem with any of my printers. -
Did you correct the angle of the Y belt? Perhaps it's binding?
Loose pulley, check that the bed is mounted fixed
