Anet A8 - How Hard is the Hardware Conversion?
Anet A8 comes with 12v fans and 12 psu configuring this is not easy since board only supply's 5v I haven't found a wiring diagram for this in the forums.
Actually, you have an option on supplying the fans with your PSU voltage or with 5V. The jumper for selection is located under the fan connectors (V FAN JUMPER SELECT).
https://d17kynu4zpq5hy.cloudfront.net/igi/duet3d/4k56ZjaaAHrTJI6Z.huge -
@veti - ok, I have finally completed my AM8 conversion. Yes, it took me this long! But, I double and triple checked everything, printed extra parts, etc. Wow, what a huge difference. It's a different beast now - fast, quiet, stable. I've just ordered my Duet and I'll be trying out all the advice and tips you guys provided . . . hopefully within a couple of weeks (traveling at the moment). Anway, I wanted to post here because others reading may want to know how impactful the AM8 upgrade is.
I got my first print with my Duet AM8 (thats what I call it now that my Anet A8 is an AM8 with a Duet processor). Thanks everyone for your advice and help. Especially, @nhof , your basic guide was so helpful. It may seem simplistic to you but topics of polarity are helpful to the novice.
It took me a loooooooooooonnnnnnnnnnnnnnnnnggggggg time but I took it slow as suggested. Also, I converted over to 24 volts in the process which meant new power supply, hot end, heated bed. Never thought I'd be Googling about Ohm's Law.
Learned a lot of things during the process and I hope to be able to help some others with the same conversion. Mostly, thank you all!
Jack
congratulation on building your own printer.
it does not matter that it took long. it matters that you stuck with it and learned new things on the way.
This thread outlines a fascinated journey. A picture will make it even more awesome.
Looks very clean, I mean the printer, not the desk,
and I like your choice of color.
It uses a bowden extruder. I switch recently my printer (non Anet) to a direct extruder and got significant improvement in print quality.
@zapta said in Anet A8 - How Hard is the Hardware Conversion?:
So I won't be showing too much of my desks anytime soon if that is messy!
@jrwaters2 nice! Thanks for sharing your journey here (and also thanks to those on the forum that helped!).
@zapta hahaha - yes, my wife's patience has been amazing. Maybe over the holidays I'll get it cleaned up. Let's see
Want to to a little wiring clean up as well!
@T3P3Tony Roger that. What a great group!
