    What could cause this heightmap pattern
    2.1k
    • jens55undefined
      jens55
      It is a CR10S-5 .... whoa .... the original post vanished 🙂
      Anyway, aluminum v rails, aluminum bed, glass plate on bed.
      Ha .. a new question appears 🙂
      Yes, tried rotating, no difference.
      • JoergS5undefined
        JoergS5
        I still think your Z axis is stuck due to different movements of left and right. I would put 0.5 kg additional weight on the hotend temporarily and measure again. This will show you the problem, because it will make it worse or better.
        • jens55undefined
          jens55
          I will see if there is a way of adding some weight to explore that possibility.
          • 4latheundefined
            4lathe
            To joergs5’s point, can you probe the bed from a different direction in any way than you have been? As in always from the right or in the opposite direction in each row from what you have been been doing. That
            might answer the question of whether loading from one side or the other is creating the ridges and troughs.
            • jens55undefined
              jens55 @4lathe
              @4lathe , the printer uses the standard Duet probing method starting at the front left, going to the front right, doing one step over (depending on probing density), starting on the right and probing to the left.
              In other words the probing happens from both sides and no difference is seen in the bed pattern.
              The pattern is seen in the Y direction and short of coding a completely manual scan, I have no idea how to tell Duet to scan 'backwards'.
                Phaedrux Moderator @jens55
                @jens55 said in What could cause this heightmap pattern:
                I guess you could swap your coordinate system to make the rear right corner 0,0
                • 4latheundefined
                  4lathe
                  Great idea Phaedrux. When the probes happen from the opposite direction, if there is indeed a loading or stacking issue, shouldn't the valleys and ridges on the map be reversed?
                  • jens55undefined
                    jens55 @JoergS5
                    @JoergS5 said in What could cause this heightmap pattern:
                    Well it's not happening. I added a 600 gr chunk of lead and it promptly got loose . I only lost my BLTouch mount (thank God) in the process. I am not going to risk the glass plate.
                    • JoergS5undefined
                      JoergS5 @jens55
                      @jens55 Sorry to hear that! I hope, it's not too much damaged.
                      The test was intended for:
                      a) if it gets worse, this may be due to stuck axis because of the difference between the two vertical aluminium extensions are too narrow or too wide. Can you test this manually?
                      b) if it gets better, the reason may be that you have backlash effects. This means, if Z changes, the movement changes the position at your left and right spindle with play. Alternatively, the connector between stepper and spindle is flexible too, it has backlash also. I don't know a different possibility than to make the hotend heavier to find it out without disassambling and replacing the connector.
                      c) is possible also, as David suggested, that measuting by BLtouch has a problem
                      In your last screenshot the left side was lower than the right. You can move the left stepper isolated so that the distance of left and right are smaller (lift left side for about 0.25 mm) like described in https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
                      • jens55undefined
                        jens55 @JoergS5
                        I do not understand what you are trying to say.
                        I do not understand why backlash would only show up at a particular x coordinate.
                        Unlikely as the issue is very specific. A measuring defect would show random errors.
                        Before any mesh map is run, I already do a Z axis equalization (actually 5 times). Z is within 0.005 for the ends of x travel for the given y location where the measurement is happening.
                        JoergS5undefined 2 Replies Last reply Reply Quote 0
                        • JoergS5undefined
                          JoergS5 @jens55
                          @jens55 it's complicated to explain better... Sorry. The backlash could show up at particular coordinates, because some micrometer differences between the vertical axis resulting in different resistance and movement.
                          The article https://all3dp.com/2/best-creality-cr-10-s5-upgrades-and-mods/ talks about some issues in chapter "Better bed mounting", maybe this helps.
                          • JoergS5undefined
                            JoergS5 @jens55
                            @jens55 On reddit are two articles about the Z axis connector between stepper and spindle:
                            https://www.reddit.com/r/CR10/comments/9epw4u/didnt_want_to_do_this_butwtf_zaxis_cr10s/
                            https://www.reddit.com/r/CR10/comments/9mpsl1/cr10_with_dualzaxis_option_unable_to_level_xaxis/
                            which talk about how to fix this.
                            • JoergS5undefined
                              JoergS5
                              The two reddit articles are both interesting. The out of sync of the two Z steppers is a general problem of all those printers: when you turn off the printer, they are often not synched any more, because the position of the full steps can change (up to 4 steps difference!).
                              The other possible reason mentioned are vertical aluminium axes which are not exactly parallel.
                              The third are the connectors between stepper and spindle.
                              • JoergS5undefined
                                JoergS5
                                One more hint is in https://www.cnx-software.com/2017/05/05/creality-cr-10-3d-printer-review-part-2-tips-tricks-octoprint-and-craftware/
                                "Sure enough z axis rod was in a bind. I didn’t even realize this. But one symptom is that before this I was only able to push the z axis down. Now I am mostly able to move up and down with the stepper motors disabled." adding a washer between Z stepper and axis.
                                (maybe different printer than yours)
                                • JoergS5undefined
                                  JoergS5
                                  off topic: you can print a Lamborghini with your printer 😉
                                  https://www.linkedin.com/pulse/lamborghini-aventador-born-out-creality-cr-10s-cr-10-s5-alice-zeng/
