    Thermocouple issue with Duet3 6HC-3HC
    825
    • steevebeckerundefined
      steevebecker
      I try to connect thermocouples type K on a Duet3 6HC, value read is always 2000°C.
      I have one Thermocouple daughter board (V1.1) on the Duet3 6HC
      The config.g is like that :
      M308 S1 P"spi.cs0" Y"thermocouple-max31856" K"K"
      Note : same problem with the 3HC
      M308 S1 P"1.spi.cs0" Y"thermocouple-max31856" K"K"
      read 2000°C too.
      I tried 2 different Thermocouple daughter board and 3 thermocouples.
      Any idea ?
      PS : RRF3 3.0 rc1 on both 6HC and 3HC
      plant your ideas, water suggestions and questions, collect progress and do great things.
        Try sending those M308 lines from the console, to see if any errors are reported.
        You can also send M308 S1 with no other parameters, and that should tell you the last error for that sensor.
          steevebecker
          18/12/2019 à 21:40:15 M308 S1 P"0.spi.cs0" Y" thermocouple-max31856" K"k"
          No error reported
          18/12/2019 à 21:41:01 M308 S1
          Sensor 1 type Thermocouple (MAX31856) using pin (spi.cs0,serial3.rx), reading 37.5, last error: success, thermocouple type K, reject 50Hz
            dc42 administrators @steevebecker
            @steevebecker said in Thermocouple issue with Duet3 6HC-3HC:
            No error reported
            Looks like it's working then. Where are you seeing the 2000C readings? If you add a sensor name to the M308 command (A parameter) then you will be able to see the sensor temperature in the Extras tab of DWC, without having to assign a heater to use it.
              steevebecker
              Yes, I read 2000°C in DWC:
              Tried that :
              M308 S1 P"spi.cs0" A"TC0" Y"thermocouple-max31856" K"k"
              It works!
              I installed the thermocouple card on the EXP3HC (with the thermocouples wired) and ran a :
              M308 S1 P"1.spi.cs0" A"TC0" Y"thermocouple-max31856" K"k"
              I get that :
              M308 S1 :
              Sensor 1 type Thermocouple (MAX31856) using pin 1.spi.cs0, last error: sensor short to other wiring, thermocouple type K, reject 50Hz
              Strange, it is the same TC board and same wiring...
                steevebecker
                How... Sorry...
                I thought that the limitation of the thermocouple that must be on the same card as the heater was fixed in version 3.0RC1
                It seems not.
                It works with Thermistor but not with TC.
                If I setup the TC on 6HC and the heater on 6HC too, it works, DWC show the temperature.
                  steevebecker
                  Do you have any idea when this is going to be implemented?
                  (just to know if I'll have to change the TCs by Thermistors to do my tests at the beginning of the year)
                    How... Sorry...
                    It seems not.
                    For safety reasons, I recommend that temperature sensors are connected to the same board as the heater. Currently, I believe a heater on the main board using a sensor on an expansion board works, but not the other way round.
                      steevebecker
                      I'm sorry, I misspoke. Actually, I want to use 2 heaters and 2 thermocouples with the EXP3HC card.
                      Do you think it should work?
                        T3P3Tony administrators @steevebecker
                        @steevebecker yes, if you have a prototype 3HC though most of them did not have the modification to make to temperature daughter boards work.
                          steevebecker
                          M308 S1 A"TC0" P"1.spi.cs0" Y"thermocouple-max31856" K"k"
                          Give no error but read 2000°C.
                          M308 S1
                          Yes, it is a prototype... bought in October.
                          Can I made the modification myself ?
                            Yes, here are the details.
                            Duet3Expansion1-v09-SPI-mod.odt .
                              steevebecker
                              It works fine, thank you...
                              The last thing is the Z Probe connected to the expansion board.
                              Do you have an idea when it will be supported ?
                                What type of Z probe is it?
                                  steevebecker
                                  It is a ZProbe we made ourself.
                                  An electromagnet takes out a rod, on this rod is fixed a blade which hides or not a standard optical endstop.
